MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /** 00002 * imoab_phAtm_ocn_coupler.cpp 00003 * 00004 * This imoab_phAtm_ocn_coupler test will simulate coupling between 3 components 00005 * meshes will be loaded from 3 files (atm, ocean, and phys atm), and 00006 * Atm and ocn will be migrated to coupler pes and compute intx on them 00007 * then, intx will be performed between migrated meshes 00008 * and weights will be generated, such that a field from phys atm will be transferred to ocn 00009 * currently, the phys atm will send some data to be projected to ocean 00010 * 00011 * first, intersect atm and ocn, and recompute comm graph 1 between atm phys and atm_cx, for ocn 00012 * intx maybe repeat the same for land 00013 */ 00014 00015 #include "moab/Core.hpp" 00016 #ifndef MOAB_HAVE_MPI 00017 #error mbtempest tool requires MPI configuration 00018 #endif 00019 00020 // MPI includes 00021 #include "moab_mpi.h" 00022 #include "moab/ParallelComm.hpp" 00023 #include "MBParallelConventions.h" 00024 00025 #include "moab/iMOAB.h" 00026 #include "TestUtil.hpp" 00027 #include "moab/CpuTimer.hpp" 00028 #include "moab/ProgOptions.hpp" 00029 #include <iostream> 00030 #include <sstream> 00031 00032 #include "imoab_coupler_utils.hpp" 00033 00034 using namespace moab; 00035 00036 //#define VERBOSE 00037 00038 #ifndef MOAB_HAVE_TEMPESTREMAP 00039 #error The climate coupler test example requires MOAB configuration with TempestRemap 00040 #endif 00041 00042 #define ENABLE_ATMOCN_COUPLING 00043 // for land coupling with phys atm, we do not have to "compute" intersection 00044 // it is enough to know that the ids are the same, we can project from atm to land that way, using a 00045 // computed graph 00046 #define ENABLE_ATMLND_COUPLING 00047 00048 int main( int argc, char* argv[] ) 00049 { 00050 int ierr; 00051 int rankInGlobalComm, numProcesses; 00052 MPI_Group jgroup; 00053 std::string readopts( "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION;PARALLEL_RESOLVE_SHARED_ENTS" ); 00054 std::string readoptsPhysAtm( "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION" ); 00055 00056 // Timer data 00057 moab::CpuTimer timer; 00058 double timer_ops; 00059 std::string opName; 00060 00061 int repartitioner_scheme = 0; 00062 #ifdef MOAB_HAVE_ZOLTAN 00063 repartitioner_scheme = 2; // use the graph partitioner in that case 00064 #endif 00065 00066 MPI_Init( &argc, &argv ); 00067 MPI_Comm_rank( MPI_COMM_WORLD, &rankInGlobalComm ); 00068 MPI_Comm_size( MPI_COMM_WORLD, &numProcesses ); 00069 00070 MPI_Comm_group( MPI_COMM_WORLD, &jgroup ); // all processes in jgroup 00071 00072 std::string atmFilename = TestDir + "unittest/wholeATM_T.h5m"; // we should use only mesh from here 00073 std::string atmPhysMesh = 00074 TestDir + "unittest/AtmPhys_01.h5m"; // it has some data associated to vertices, T_ph, u_ph, v_ph 00075 // we will eventually project that data to ocean mesh, after intx atm/ocn 00076 00077 // on a regular case, 5 ATM, 6 CPLATM (ATMX), 17 OCN , 18 CPLOCN (OCNX) ; 00078 // intx atm/ocn is not in e3sm yet, give a number 00079 // 6 * 100+ 18 = 618 : atmocnid 00080 // 9 LND, 10 CPLLND 00081 // 6 * 100 + 10 = 610 atmlndid: 00082 // cmpatm is for atm on atm pes 00083 // cmpocn is for ocean, on ocean pe 00084 // cplatm is for atm on coupler pes 00085 // cplocn is for ocean on coupler pes 00086 // atmocnid is for intx atm / ocn on coupler pes 00087 // 00088 00089 int cmpatm = 5, 00090 cplatm = 6; // component ids are unique over all pes, and established in advance; 00091 int cmpPhysAtm = 105; // different from atm spectral ? 00092 #ifdef ENABLE_ATMOCN_COUPLING 00093 std::string ocnFilename = TestDir + "unittest/recMeshOcn.h5m"; 00094 int rankInOcnComm = -1; 00095 int cmpocn = 17, cplocn = 18, 00096 atmocnid = 618; // component ids are unique over all pes, and established in advance; 00097 #endif 00098 #ifdef ENABLE_ATMLND_COUPLING 00099 std::string lndFilename = TestDir + "unittest/wholeLnd.h5m"; 00100 int cpllnd = 10, 00101 cmplnd = 9; // component ids are unique over all pes, and established in advance; 00102 #endif 00103 00104 int rankInCouComm = -1; 00105 00106 int nghlay = 0; // number of ghost layers for loading the file 00107 00108 int startG1 = 0, startG2 = 0, endG1 = numProcesses - 1, endG2 = numProcesses - 1, startG3 = startG1, endG3 = endG1; 00109 int startG4 = startG1, endG4 = endG1; // these are for coupler layout 00110 int context_id = -1; // used now for freeing buffers 00111 00112 // default: load atm on 2 proc, ocean on 2, land on 2; migrate to 2 procs, then compute intx 00113 // later, we need to compute weight matrix with tempestremap 00114 00115 ProgOptions opts; 00116 opts.addOpt< std::string >( "atmosphere,t", "atm mesh filename (source)", &atmFilename ); 00117 #ifdef ENABLE_ATMOCN_COUPLING 00118 opts.addOpt< std::string >( "ocean,m", "ocean mesh filename (target)", &ocnFilename ); 00119 #endif 00120 00121 #ifdef ENABLE_ATMLND_COUPLING 00122 opts.addOpt< std::string >( "land,l", "land mesh filename (target)", &lndFilename ); 00123 #endif 00124 00125 opts.addOpt< std::string >( "physgrid,q", "physics grid file", &atmPhysMesh ); 00126 00127 opts.addOpt< int >( "startAtm,a", "start task for atmosphere layout", &startG1 ); 00128 opts.addOpt< int >( "endAtm,b", "end task for atmosphere layout", &endG1 ); 00129 #ifdef ENABLE_ATMOCN_COUPLING 00130 opts.addOpt< int >( "startOcn,c", "start task for ocean layout", &startG2 ); 00131 opts.addOpt< int >( "endOcn,d", "end task for ocean layout", &endG2 ); 00132 #endif 00133 00134 #ifdef ENABLE_ATMLND_COUPLING 00135 opts.addOpt< int >( "startLnd,e", "start task for land layout", &startG3 ); 00136 opts.addOpt< int >( "endLnd,f", "end task for land layout", &endG3 ); 00137 #endif 00138 00139 opts.addOpt< int >( "startCoupler,g", "start task for coupler layout", &startG4 ); 00140 opts.addOpt< int >( "endCoupler,j", "end task for coupler layout", &endG4 ); 00141 00142 opts.addOpt< int >( "partitioning,p", "partitioning option for migration", &repartitioner_scheme ); 00143 00144 opts.parseCommandLine( argc, argv ); 00145 00146 char fileWriteOptions[] = "PARALLEL=WRITE_PART"; 00147 00148 if( !rankInGlobalComm ) 00149 { 00150 std::cout << " atm file: " << atmFilename << "\n on tasks : " << startG1 << ":" << endG1 << 00151 #ifdef ENABLE_ATMOCN_COUPLING 00152 "\n ocn file: " << ocnFilename << "\n on tasks : " << startG2 << ":" << endG2 << 00153 #endif 00154 #ifdef ENABLE_ATMLND_COUPLING 00155 "\n land file: " << lndFilename << "\n on tasks : " << startG3 << ":" << endG3 << 00156 #endif 00157 00158 "\n atm phys file: " << atmPhysMesh << "\n on tasks : " << startG1 << ":" << endG1 << 00159 00160 "\n partitioning (0 trivial, 1 graph, 2 geometry) " << repartitioner_scheme << "\n "; 00161 } 00162 00163 // load files on 3 different communicators, groups 00164 // first groups has task 0, second group tasks 0 and 1 00165 // coupler will be on joint tasks, will be on a third group (0 and 1, again) 00166 MPI_Group atmPEGroup; 00167 MPI_Comm atmComm; 00168 ierr = create_group_and_comm( startG1, endG1, jgroup, &atmPEGroup, &atmComm ); 00169 CHECKIERR( ierr, "Cannot create atm MPI group and communicator " ) 00170 00171 #ifdef ENABLE_ATMOCN_COUPLING 00172 MPI_Group ocnPEGroup; 00173 MPI_Comm ocnComm; 00174 ierr = create_group_and_comm( startG2, endG2, jgroup, &ocnPEGroup, &ocnComm ); 00175 CHECKIERR( ierr, "Cannot create ocn MPI group and communicator " ) 00176 #endif 00177 00178 #ifdef ENABLE_ATMLND_COUPLING 00179 MPI_Group lndPEGroup; 00180 MPI_Comm lndComm; 00181 ierr = create_group_and_comm( startG3, endG3, jgroup, &lndPEGroup, &lndComm ); 00182 CHECKIERR( ierr, "Cannot create lnd MPI group and communicator " ) 00183 #endif 00184 00185 // we will always have a coupler 00186 MPI_Group couPEGroup; 00187 MPI_Comm couComm; 00188 ierr = create_group_and_comm( startG4, endG4, jgroup, &couPEGroup, &couComm ); 00189 CHECKIERR( ierr, "Cannot create cpl MPI group and communicator " ) 00190 00191 // now, create the joint communicators atm_coupler, ocn_coupler, lnd_coupler 00192 // for each, we will have to create the group first, then the communicator 00193 00194 // atm_coupler 00195 MPI_Group joinAtmCouGroup; 00196 MPI_Comm atmCouComm; 00197 ierr = create_joint_comm_group( atmPEGroup, couPEGroup, &joinAtmCouGroup, &atmCouComm ); 00198 CHECKIERR( ierr, "Cannot create joint atm cou communicator" ) 00199 00200 #ifdef ENABLE_ATMOCN_COUPLING 00201 // ocn_coupler 00202 MPI_Group joinOcnCouGroup; 00203 MPI_Comm ocnCouComm; 00204 ierr = create_joint_comm_group( ocnPEGroup, couPEGroup, &joinOcnCouGroup, &ocnCouComm ); 00205 CHECKIERR( ierr, "Cannot create joint ocn cou communicator" ) 00206 #endif 00207 00208 #ifdef ENABLE_ATMLND_COUPLING 00209 // lnd_coupler 00210 MPI_Group joinLndCouGroup; 00211 MPI_Comm lndCouComm; 00212 ierr = create_joint_comm_group( lndPEGroup, couPEGroup, &joinLndCouGroup, &lndCouComm ); 00213 CHECKIERR( ierr, "Cannot create joint ocn cou communicator" ) 00214 #endif 00215 00216 ierr = iMOAB_Initialize( argc, argv ); // not really needed anything from argc, argv, yet; maybe we should 00217 CHECKIERR( ierr, "Cannot initialize iMOAB" ) 00218 00219 int cmpAtmAppID = -1; 00220 iMOAB_AppID cmpAtmPID = &cmpAtmAppID; // atm 00221 int cplAtmAppID = -1; // -1 means it is not initialized 00222 iMOAB_AppID cplAtmPID = &cplAtmAppID; // atm on coupler PEs 00223 00224 #ifdef ENABLE_ATMOCN_COUPLING 00225 int cmpOcnAppID = -1; 00226 iMOAB_AppID cmpOcnPID = &cmpOcnAppID; // ocn 00227 int cplOcnAppID = -1, cplAtmOcnAppID = -1; // -1 means it is not initialized 00228 iMOAB_AppID cplOcnPID = &cplOcnAppID; // ocn on coupler PEs 00229 iMOAB_AppID cplAtmOcnPID = &cplAtmOcnAppID; // intx atm -ocn on coupler PEs 00230 #endif 00231 00232 #ifdef ENABLE_ATMLND_COUPLING 00233 int cmpLndAppID = -1; 00234 iMOAB_AppID cmpLndPID = &cmpLndAppID; // lnd 00235 int cplLndAppID = -1; //, cplAtmLndAppID=-1;// -1 means it is not initialized 00236 iMOAB_AppID cplLndPID = &cplLndAppID; // land on coupler PEs 00237 // iMOAB_AppID cplAtmLndPID=&cplAtmLndAppID; // intx atm - lnd on coupler PEs not needed anymore 00238 #endif 00239 00240 int cmpPhysAtmID = -1; 00241 iMOAB_AppID cmpPhAtmPID = &cmpPhysAtmID; // phys atm; we do not need to move it to cpl! 00242 00243 if( couComm != MPI_COMM_NULL ) 00244 { 00245 MPI_Comm_rank( couComm, &rankInCouComm ); 00246 // Register all the applications on the coupler PEs 00247 ierr = iMOAB_RegisterApplication( "ATMX", &couComm, &cplatm, 00248 cplAtmPID ); // atm on coupler pes 00249 CHECKIERR( ierr, "Cannot register ATM over coupler PEs" ) 00250 #ifdef ENABLE_ATMOCN_COUPLING 00251 ierr = iMOAB_RegisterApplication( "OCNX", &couComm, &cplocn, 00252 cplOcnPID ); // ocn on coupler pes 00253 CHECKIERR( ierr, "Cannot register OCN over coupler PEs" ) 00254 #endif 00255 00256 #ifdef ENABLE_ATMLND_COUPLING 00257 ierr = iMOAB_RegisterApplication( "LNDX", &couComm, &cpllnd, 00258 cplLndPID ); // lnd on coupler pes 00259 CHECKIERR( ierr, "Cannot register LND over coupler PEs" ) 00260 #endif 00261 } 00262 00263 if( atmCouComm != MPI_COMM_NULL ) 00264 { 00265 ierr = iMOAB_RegisterApplication( "ATM1", &atmComm, &cmpatm, cmpAtmPID ); 00266 CHECKIERR( ierr, "Cannot register ATM App" ) 00267 } 00268 00269 #ifdef ENABLE_ATMOCN_COUPLING 00270 if( ocnComm != MPI_COMM_NULL ) 00271 { 00272 MPI_Comm_rank( ocnComm, &rankInOcnComm ); 00273 ierr = iMOAB_RegisterApplication( "OCN1", &ocnComm, &cmpocn, cmpOcnPID ); 00274 CHECKIERR( ierr, "Cannot register OCN App" ) 00275 } 00276 #endif 00277 00278 // atm 00279 ierr = 00280 setup_component_coupler_meshes( cmpAtmPID, cmpatm, cplAtmPID, cplatm, &atmComm, &atmPEGroup, &couComm, 00281 &couPEGroup, &atmCouComm, atmFilename, readopts, nghlay, repartitioner_scheme ); 00282 CHECKIERR( ierr, "Cannot load and migrate atm mesh" ) 00283 00284 MPI_Barrier( MPI_COMM_WORLD ); 00285 00286 #ifdef ENABLE_ATMOCN_COUPLING 00287 // ocean 00288 ierr = 00289 setup_component_coupler_meshes( cmpOcnPID, cmpocn, cplOcnPID, cplocn, &ocnComm, &ocnPEGroup, &couComm, 00290 &couPEGroup, &ocnCouComm, ocnFilename, readopts, nghlay, repartitioner_scheme ); 00291 CHECKIERR( ierr, "Cannot load and migrate ocn mesh" ) 00292 #ifdef VERBOSE 00293 if( couComm != MPI_COMM_NULL ) 00294 { 00295 char outputFileTgt3[] = "recvOcn2.h5m"; 00296 ierr = iMOAB_WriteMesh( cplOcnPID, outputFileTgt3, fileWriteOptions ); 00297 CHECKIERR( ierr, "cannot write ocn mesh after receiving" ) 00298 } 00299 #endif 00300 00301 #endif 00302 00303 MPI_Barrier( MPI_COMM_WORLD ); 00304 00305 // load phys atm mesh, with some data on it already 00306 if( atmComm != MPI_COMM_NULL ) 00307 { 00308 ierr = iMOAB_RegisterApplication( "PhysAtm", &atmComm, &cmpPhysAtm, cmpPhAtmPID ); 00309 CHECKIERR( ierr, "Cannot register Phys Atm App " ) 00310 00311 // load the next component mesh 00312 ierr = iMOAB_LoadMesh( cmpPhAtmPID, atmPhysMesh.c_str(), readoptsPhysAtm.c_str(), &nghlay ); 00313 CHECKIERR( ierr, "Cannot load Atm Phys mesh on atm pes" ) 00314 00315 int nverts[3], nelem[3]; 00316 ierr = iMOAB_GetMeshInfo( cmpPhAtmPID, nverts, nelem, 0, 0, 0 ); 00317 CHECKIERR( ierr, "failed to get mesh info" ); 00318 printf( "Phys Atm Component Mesh: %d vertices and %d elements\n", nverts[0], nelem[0] ); 00319 } 00320 00321 MPI_Barrier( MPI_COMM_WORLD ); 00322 00323 #ifdef ENABLE_ATMLND_COUPLING 00324 // land 00325 if( lndComm != MPI_COMM_NULL ) 00326 { 00327 ierr = iMOAB_RegisterApplication( "LND1", &lndComm, &cmplnd, cmpLndPID ); 00328 CHECKIERR( ierr, "Cannot register LND App " ) 00329 } 00330 ierr = setup_component_coupler_meshes( cmpLndPID, cmplnd, cplLndPID, cpllnd, &lndComm, &lndPEGroup, &couComm, 00331 &couPEGroup, &lndCouComm, lndFilename, readoptsPhysAtm, nghlay, 00332 repartitioner_scheme ); 00333 if( couComm != MPI_COMM_NULL ) 00334 { 00335 char outputFileLnd[] = "recvLnd2.h5m"; 00336 00337 ierr = iMOAB_WriteMesh( cplLndPID, outputFileLnd, fileWriteOptions ); 00338 CHECKIERR( ierr, "cannot write lnd mesh after receiving" ) 00339 } 00340 00341 #endif // 00342 00343 MPI_Barrier( MPI_COMM_WORLD ); 00344 00345 #ifdef ENABLE_ATMOCN_COUPLING 00346 if( couComm != MPI_COMM_NULL ) 00347 { 00348 // now compute intersection between OCNx and ATMx on coupler PEs 00349 ierr = iMOAB_RegisterApplication( "ATMOCN", &couComm, &atmocnid, cplAtmOcnPID ); 00350 CHECKIERR( ierr, "Cannot register ocn_atm intx over coupler pes " ) 00351 } 00352 #endif 00353 00354 const char* weights_identifiers[2] = { "scalar", "scalar-pc" }; 00355 int disc_orders[3] = { 4, 1, 1 }; 00356 const char* disc_methods[3] = { "cgll", "fv", "pcloud" }; 00357 const char* dof_tag_names[3] = { "GLOBAL_DOFS", "GLOBAL_ID", "GLOBAL_ID" }; 00358 #ifdef ENABLE_ATMOCN_COUPLING 00359 if( couComm != MPI_COMM_NULL ) 00360 { 00361 00362 ierr = iMOAB_ComputeMeshIntersectionOnSphere( 00363 cplAtmPID, cplOcnPID, 00364 cplAtmOcnPID ); // coverage mesh was computed here, for cplAtmPID, atm on coupler pes 00365 // basically, atm was redistributed according to target (ocean) partition, to "cover" the 00366 // ocean partitions check if intx valid, write some h5m intx file 00367 CHECKIERR( ierr, "cannot compute intersection" ) 00368 } 00369 00370 if( atmCouComm != MPI_COMM_NULL ) 00371 { 00372 // the new graph will be for sending data from atm comp to coverage mesh; 00373 // it involves initial atm app; cmpAtmPID; also migrate atm mesh on coupler pes, cplAtmPID 00374 // results are in cplAtmOcnPID, intx mesh; remapper also has some info about coverage mesh 00375 // after this, the sending of tags from atm pes to coupler pes will use the new par comm 00376 // graph, that has more precise info about what to send for ocean cover ; every time, we 00377 // will 00378 // use the element global id, which should uniquely identify the element 00379 00380 ierr = iMOAB_CoverageGraph( &atmCouComm, cmpAtmPID, cplAtmPID, cplAtmOcnPID, &cmpatm, &cplatm, 00381 &cplocn ); // it happens over joint communicator 00382 CHECKIERR( ierr, "cannot recompute direct coverage graph for ocean" ) 00383 } 00384 00385 // need to compute graph between phys atm and atm/ocn intx coverage 00386 if( atmCouComm != MPI_COMM_NULL ) 00387 { 00388 int typeA = 2; // point cloud 00389 int typeB = 1; // quads in coverage set 00390 ierr = iMOAB_ComputeCommGraph( cmpPhAtmPID, cplAtmOcnPID, &atmCouComm, &atmPEGroup, &couPEGroup, &typeA, &typeB, 00391 &cmpatm, &atmocnid ); 00392 } 00393 #endif 00394 00395 #ifdef ENABLE_ATMLND_COUPLING 00396 // we will compute comm graph between atm phys and land, directly; we do not need any 00397 // intersection later, we will send data from atm phys to land on coupler; then back to land 00398 // comp; 00399 if( atmCouComm != MPI_COMM_NULL ) 00400 { 00401 int typeA = 2; // point cloud 00402 int typeB = 2; // point cloud for land on coupler, too 00403 ierr = iMOAB_ComputeCommGraph( cmpPhAtmPID, cplLndPID, &atmCouComm, &atmPEGroup, &couPEGroup, &typeA, &typeB, 00404 &cmpatm, &cpllnd ); 00405 } 00406 #endif 00407 MPI_Barrier( MPI_COMM_WORLD ); 00408 00409 int fMonotoneTypeID = 0, fVolumetric = 0, fValidate = 1, fNoConserve = 0, fNoBubble = 1, fInverseDistanceMap = 0; 00410 00411 #ifdef ENABLE_ATMOCN_COUPLING 00412 #ifdef VERBOSE 00413 if( couComm != MPI_COMM_NULL ) 00414 { 00415 char serialWriteOptions[] = ""; // for writing in serial 00416 std::stringstream outf; 00417 outf << "intxAtmOcn_" << rankInCouComm << ".h5m"; 00418 std::string intxfile = outf.str(); // write in serial the intx file, for debugging 00419 ierr = iMOAB_WriteMesh( cplAtmOcnPID, intxfile.c_str(), serialWriteOptions ); 00420 CHECKIERR( ierr, "cannot write intx file result" ) 00421 } 00422 #endif 00423 00424 if( couComm != MPI_COMM_NULL ) 00425 { 00426 PUSH_TIMER( "Compute the projection weights with TempestRemap" ) 00427 ierr = iMOAB_ComputeScalarProjectionWeights( cplAtmOcnPID, weights_identifiers[0], disc_methods[0], 00428 &disc_orders[0], disc_methods[1], &disc_orders[1], &fNoBubble, 00429 &fMonotoneTypeID, &fVolumetric, &fInverseDistanceMap, &fNoConserve, 00430 &fValidate, dof_tag_names[0], dof_tag_names[1] ); 00431 CHECKIERR( ierr, "cannot compute scalar projection weights" ) 00432 POP_TIMER( couComm, rankInCouComm ) 00433 } 00434 00435 #endif 00436 00437 MPI_Barrier( MPI_COMM_WORLD ); 00438 00439 int tagIndex[2]; 00440 int tagTypes[2] = { DENSE_DOUBLE, DENSE_DOUBLE }; 00441 int atmCompNDoFs = disc_orders[0] * disc_orders[0], ocnCompNDoFs = 1 /*FV*/; 00442 00443 const char* bottomFields = 00444 "Sa_z:Sa_topo:Sa_u:Sa_v:Sa_tbot:Sa_ptem:Sa_shum:Sa_pbot:Sa_dens:Sa_uovern:Sa_pslv:Sa_co2prog:Sa_co2diag:Faxa_" 00445 "rainc:Faxa_rainl:Faxa_snowc:Faxa_snowl:Faxa_lwdn:Faxa_swndr:Faxa_swvdr:Faxa_swndf:Faxa_swvdf:Faxa_swnet:Faxa_" 00446 "bcphidry:Faxa_bcphodry:Faxa_bcphiwet:Faxa_ocphidry:Faxa_ocphodry:Faxa_ocphiwet:Faxa_dstwet1:Faxa_dstwet2:Faxa_" 00447 "dstwet3:Faxa_dstwet4:Faxa_dstdry1:Faxa_dstdry2:Faxa_dstdry3:Faxa_dstdry4"; 00448 const char* bottomFieldsExt = 00449 "Sa_z_ext:Sa_topo_ext:Sa_u_ext:Sa_v_ext:Sa_tbot_ext:Sa_ptem_ext:Sa_shum_ext:Sa_pbot_ext:Sa_dens_ext:Sa_uovern_" 00450 "ext:Sa_pslv_ext:Sa_co2prog_ext:Sa_co2diag_ext:Faxa_rainc_ext:Faxa_rainl_ext:Faxa_snowc_ext:Faxa_snowl_ext:" 00451 "Faxa_lwdn_ext:Faxa_swndr_ext:Faxa_swvdr_ext:Faxa_swndf_ext:Faxa_swvdf_ext:Faxa_swnet_ext:Faxa_bcphidry_ext:" 00452 "Faxa_bcphodry_ext:Faxa_bcphiwet_ext:Faxa_ocphidry_ext:Faxa_ocphodry_ext:Faxa_ocphiwet_ext:Faxa_dstwet1_ext:" 00453 "Faxa_dstwet2_ext:Faxa_dstwet3_ext:Faxa_dstwet4_ext:Faxa_dstdry1_ext:Faxa_dstdry2_ext:Faxa_dstdry3_ext:Faxa_" 00454 "dstdry4_ext"; 00455 00456 if( couComm != MPI_COMM_NULL ) 00457 { 00458 ierr = iMOAB_DefineTagStorage( cplAtmPID, bottomFieldsExt, &tagTypes[0], &atmCompNDoFs, &tagIndex[0] ); 00459 CHECKIERR( ierr, "failed to define the field tags T16_ph:u16_ph:v16_ph " ); 00460 #ifdef ENABLE_ATMOCN_COUPLING 00461 00462 ierr = iMOAB_DefineTagStorage( cplOcnPID, bottomFields, &tagTypes[1], &ocnCompNDoFs, &tagIndex[1] ); 00463 CHECKIERR( ierr, "failed to define the field tags T_proj:u_proj:v_proj" ); 00464 #endif 00465 00466 #ifdef ENABLE_ATMLND_COUPLING 00467 // need to define tag storage for land; will use the same T_proj, u_proj, v_proj name, 00468 // because it will be used to send between point clouds ! use the same ndof and same size as 00469 // ocnCompNDoFs (1) !! 00470 ierr = iMOAB_DefineTagStorage( cplLndPID, bottomFields, &tagTypes[1], &ocnCompNDoFs, &tagIndex[1] ); 00471 CHECKIERR( ierr, "failed to define the bottomFields tag on coupler land" ); 00472 #endif 00473 } 00474 // need to make sure that the coverage mesh (created during intx method) received the tag that 00475 // need to be projected to target so far, the coverage mesh has only the ids and global dofs; 00476 // need to change the migrate method to accommodate any GLL tag 00477 // now send a tag from original atmosphere (cmpAtmPID) towards migrated coverage mesh 00478 // (cplAtmPID), using the new coverage graph communicator 00479 00480 // make the tag 0, to check we are actually sending needed data 00481 { 00482 if( cplAtmAppID >= 0 ) 00483 { 00484 int nverts[3], nelem[3], nblocks[3], nsbc[3], ndbc[3]; 00485 /* 00486 * Each process in the communicator will have access to a local mesh instance, which 00487 * will contain the original cells in the local partition and ghost entities. Number of 00488 * vertices, primary cells, visible blocks, number of sidesets and nodesets boundary 00489 * conditions will be returned in numProcesses 3 arrays, for local, ghost and total 00490 * numbers. 00491 */ 00492 ierr = iMOAB_GetMeshInfo( cplAtmPID, nverts, nelem, nblocks, nsbc, ndbc ); 00493 CHECKIERR( ierr, "failed to get num primary elems" ); 00494 int numAllElem = nelem[2]; 00495 std::vector< double > vals; 00496 int storLeng = atmCompNDoFs * numAllElem * 37; 00497 vals.resize( storLeng ); 00498 for( int k = 0; k < storLeng; k++ ) 00499 vals[k] = 0.; 00500 int eetype = 1; 00501 ierr = iMOAB_SetDoubleTagStorage( cplAtmPID, bottomFieldsExt, &storLeng, &eetype, &vals[0] ); 00502 CHECKIERR( ierr, "cannot make tags nul" ) 00503 // set the tag to 0 00504 } 00505 } 00506 00507 #ifdef ENABLE_ATMOCN_COUPLING 00508 PUSH_TIMER( "Send/receive data from atm component to coupler in ocn context" ) 00509 if( atmComm != MPI_COMM_NULL ) 00510 { 00511 // as always, use nonblocking sends 00512 // this is for projection to ocean: 00513 ierr = iMOAB_SendElementTag( cmpPhAtmPID, bottomFields, &atmCouComm, &atmocnid ); 00514 CHECKIERR( ierr, "cannot send tag values" ) 00515 #ifdef VERBOSE 00516 int is_sender = 1; 00517 int context = atmocnid; // used to identity the parcommgraph in charge 00518 iMOAB_DumpCommGraph( cmpPhAtmPID, &context, &is_sender, "PhysAtmA2OS", ); 00519 #endif 00520 } 00521 if( couComm != MPI_COMM_NULL ) 00522 { 00523 // receive on atm on coupler pes, that was redistributed according to coverage 00524 ierr = iMOAB_ReceiveElementTag( cplAtmOcnPID, bottomFieldsExt, &atmCouComm, &cmpatm ); 00525 CHECKIERR( ierr, "cannot receive tag values" ) 00526 #ifdef VERBOSE 00527 int is_sender = 0; 00528 int context = cmpatm; // used to identity the parcommgraph in charge 00529 iMOAB_DumpCommGraph( cplAtmOcnPID, &context, &is_sender, "PhysAtmA2OR", ); 00530 #endif 00531 } 00532 POP_TIMER( MPI_COMM_WORLD, rankInGlobalComm ) 00533 00534 // we can now free the sender buffers 00535 if( atmComm != MPI_COMM_NULL ) 00536 { 00537 ierr = iMOAB_FreeSenderBuffers( cmpPhAtmPID, &atmocnid ); // context is for ocean 00538 CHECKIERR( ierr, "cannot free buffers used to resend atm tag towards the coverage mesh" ) 00539 } 00540 /* 00541 #ifdef VERBOSE 00542 if (couComm != MPI_COMM_NULL) { 00543 char outputFileRecvd[] = "recvAtmCoupOcn.h5m"; 00544 ierr = iMOAB_WriteMesh(cplAtmPID, outputFileRecvd, fileWriteOptions, 00545 strlen(outputFileRecvd), strlen(fileWriteOptions) ); 00546 } 00547 #endif 00548 */ 00549 00550 if( couComm != MPI_COMM_NULL ) 00551 { 00552 /* We have the remapping weights now. Let us apply the weights onto the tag we defined 00553 on the source mesh and get the projection on the target mesh */ 00554 PUSH_TIMER( "Apply Scalar projection weights" ) 00555 ierr = 00556 iMOAB_ApplyScalarProjectionWeights( cplAtmOcnPID, weights_identifiers[0], bottomFieldsExt, bottomFields ); 00557 CHECKIERR( ierr, "failed to compute projection weight application" ); 00558 POP_TIMER( couComm, rankInCouComm ) 00559 00560 char outputFileTgt[] = "fOcnOnCpl7.h5m"; 00561 ierr = iMOAB_WriteMesh( cplOcnPID, outputFileTgt, fileWriteOptions ); 00562 } 00563 // send the projected tag back to ocean pes, with send/receive tag 00564 if( ocnComm != MPI_COMM_NULL ) 00565 { 00566 int tagIndexIn2; 00567 ierr = iMOAB_DefineTagStorage( cmpOcnPID, bottomFields, &tagTypes[1], &ocnCompNDoFs, &tagIndexIn2 ); 00568 CHECKIERR( ierr, "failed to define the field tags for receiving back the atm tags on ocn pes" ); 00569 } 00570 // send the tag to ocean pes, from ocean mesh on coupler pes 00571 // from couComm, using common joint comm ocn_coupler 00572 // as always, use nonblocking sends 00573 // original graph (context is -1_ 00574 if( couComm != MPI_COMM_NULL ) 00575 { 00576 context_id = cmpocn; 00577 ierr = iMOAB_SendElementTag( cplOcnPID, bottomFields, &ocnCouComm, &context_id ); 00578 CHECKIERR( ierr, "cannot send tag values back to ocean pes" ) 00579 } 00580 00581 // receive on component 2, ocean 00582 if( ocnComm != MPI_COMM_NULL ) 00583 { 00584 context_id = cplocn; 00585 ierr = iMOAB_ReceiveElementTag( cmpOcnPID, bottomFields, &ocnCouComm, &context_id ); 00586 CHECKIERR( ierr, "cannot receive tag values from ocean mesh on coupler pes" ) 00587 } 00588 MPI_Barrier( MPI_COMM_WORLD ); 00589 00590 if( couComm != MPI_COMM_NULL ) 00591 { 00592 context_id = cmpocn; 00593 ierr = iMOAB_FreeSenderBuffers( cplOcnPID, &context_id ); 00594 } 00595 if( ocnComm != MPI_COMM_NULL ) 00596 { 00597 char outputFileOcn[] = "OcnWithProj2.h5m"; 00598 ierr = iMOAB_WriteMesh( cmpOcnPID, outputFileOcn, fileWriteOptions ); 00599 } 00600 00601 #endif 00602 00603 #ifdef ENABLE_ATMLND_COUPLING 00604 // start land proj: 00605 00606 // we used this to compute 00607 // ierr = iMOAB_ComputeCommGraph(cmpPhAtmPID, cplLndPID, &atmCouComm, &atmPEGroup, &couPEGroup, 00608 // &typeA, &typeB, &cmpatm, &cpllnd); 00609 00610 // end copy 00611 PUSH_TIMER( "Send/receive data from phys comp atm to coupler land, using computed graph" ) 00612 if( atmComm != MPI_COMM_NULL ) 00613 { 00614 00615 // as always, use nonblocking sends 00616 // this is for projection to land: 00617 ierr = iMOAB_SendElementTag( cmpPhAtmPID, bottomFields, &atmCouComm, &cpllnd ); 00618 CHECKIERR( ierr, "cannot send tag values towards cpl on land" ) 00619 } 00620 if( couComm != MPI_COMM_NULL ) 00621 { 00622 // receive on lnd on coupler pes 00623 ierr = iMOAB_ReceiveElementTag( cplLndPID, bottomFields, &atmCouComm, &cmpatm ); 00624 CHECKIERR( ierr, "cannot receive tag values on land on coupler" ) 00625 } 00626 POP_TIMER( MPI_COMM_WORLD, rankInGlobalComm ) 00627 00628 // we can now free the sender buffers 00629 if( atmComm != MPI_COMM_NULL ) 00630 { 00631 ierr = iMOAB_FreeSenderBuffers( cmpPhAtmPID, &cpllnd ); 00632 CHECKIERR( ierr, "cannot free buffers used to send atm tag towards the land on coupler" ) 00633 } 00634 00635 #ifdef VERBOSE 00636 if( couComm != MPI_COMM_NULL ) 00637 { 00638 char outputFileTgtLnd[] = "fLndOnCpl.h5m"; 00639 ierr = iMOAB_WriteMesh( cplLndPID, outputFileTgtLnd, fileWriteOptions ); 00640 } 00641 #endif 00642 00643 // end land proj 00644 // send the tags back to land pes, from land mesh on coupler pes 00645 // send from cplLndPID to cmpLndPID, using common joint comm 00646 // as always, use nonblocking sends 00647 // original graph 00648 // int context_id = -1; 00649 // the land might not have these tags yet; it should be a different name for land 00650 // in e3sm we do have different names 00651 if( lndComm != MPI_COMM_NULL ) 00652 { 00653 int tagIndexIn2; 00654 ierr = iMOAB_DefineTagStorage( cmpLndPID, bottomFields, &tagTypes[1], &ocnCompNDoFs, &tagIndexIn2 ); 00655 CHECKIERR( ierr, "failed to define the field tag for receiving back the tag T_proj:u_proj:v_proj on lnd pes" ); 00656 } 00657 if( couComm != MPI_COMM_NULL ) 00658 { 00659 context_id = cmplnd; 00660 ierr = iMOAB_SendElementTag( cplLndPID, bottomFields, &lndCouComm, &context_id ); 00661 CHECKIERR( ierr, "cannot send tag values back to land pes" ) 00662 } 00663 // receive on component 3, land 00664 if( lndComm != MPI_COMM_NULL ) 00665 { 00666 context_id = cpllnd; // receive from coupler on land 00667 ierr = iMOAB_ReceiveElementTag( cmpLndPID, bottomFields, &lndCouComm, &context_id ); 00668 CHECKIERR( ierr, "cannot receive tag values from land mesh on coupler pes" ) 00669 } 00670 00671 MPI_Barrier( MPI_COMM_WORLD ); 00672 if( couComm != MPI_COMM_NULL ) 00673 { 00674 context_id = cmplnd; 00675 ierr = iMOAB_FreeSenderBuffers( cplLndPID, &context_id ); 00676 } 00677 if( lndComm != MPI_COMM_NULL ) 00678 { 00679 char outputFileLnd[] = "LndWithProj2.h5m"; 00680 ierr = iMOAB_WriteMesh( cmpLndPID, outputFileLnd, fileWriteOptions ); 00681 } 00682 00683 #endif // ENABLE_ATMLND_COUPLING 00684 00685 #ifdef ENABLE_ATMOCN_COUPLING 00686 if( couComm != MPI_COMM_NULL ) 00687 { 00688 ierr = iMOAB_DeregisterApplication( cplAtmOcnPID ); 00689 CHECKIERR( ierr, "cannot deregister app intx AO" ) 00690 } 00691 #endif 00692 00693 #ifdef ENABLE_ATMLND_COUPLING 00694 if( lndComm != MPI_COMM_NULL ) 00695 { 00696 ierr = iMOAB_DeregisterApplication( cmpLndPID ); 00697 CHECKIERR( ierr, "cannot deregister app LND1" ) 00698 } 00699 #endif // ENABLE_ATMLND_COUPLING 00700 if( atmComm != MPI_COMM_NULL ) 00701 { 00702 ierr = iMOAB_DeregisterApplication( cmpPhAtmPID ); 00703 CHECKIERR( ierr, "cannot deregister app PhysAtm " ) 00704 } 00705 #ifdef ENABLE_ATMOCN_COUPLING 00706 if( ocnComm != MPI_COMM_NULL ) 00707 { 00708 ierr = iMOAB_DeregisterApplication( cmpOcnPID ); 00709 CHECKIERR( ierr, "cannot deregister app OCN1" ) 00710 } 00711 #endif // ENABLE_ATMOCN_COUPLING 00712 00713 if( atmComm != MPI_COMM_NULL ) 00714 { 00715 ierr = iMOAB_DeregisterApplication( cmpAtmPID ); 00716 CHECKIERR( ierr, "cannot deregister app ATM1" ) 00717 } 00718 00719 #ifdef ENABLE_ATMLND_COUPLING 00720 if( couComm != MPI_COMM_NULL ) 00721 { 00722 ierr = iMOAB_DeregisterApplication( cplLndPID ); 00723 CHECKIERR( ierr, "cannot deregister app LNDX" ) 00724 } 00725 #endif // ENABLE_ATMLND_COUPLING 00726 00727 #ifdef ENABLE_ATMOCN_COUPLING 00728 if( couComm != MPI_COMM_NULL ) 00729 { 00730 ierr = iMOAB_DeregisterApplication( cplOcnPID ); 00731 CHECKIERR( ierr, "cannot deregister app OCNX" ) 00732 } 00733 #endif // ENABLE_ATMOCN_COUPLING 00734 00735 if( couComm != MPI_COMM_NULL ) 00736 { 00737 ierr = iMOAB_DeregisterApplication( cplAtmPID ); 00738 CHECKIERR( ierr, "cannot deregister app ATMX" ) 00739 } 00740 00741 //#endif 00742 ierr = iMOAB_Finalize(); 00743 CHECKIERR( ierr, "did not finalize iMOAB" ) 00744 00745 // free atm coupler group and comm 00746 if( MPI_COMM_NULL != atmCouComm ) MPI_Comm_free( &atmCouComm ); 00747 MPI_Group_free( &joinAtmCouGroup ); 00748 if( MPI_COMM_NULL != atmComm ) MPI_Comm_free( &atmComm ); 00749 00750 #ifdef ENABLE_ATMOCN_COUPLING 00751 if( MPI_COMM_NULL != ocnComm ) MPI_Comm_free( &ocnComm ); 00752 // free ocn - coupler group and comm 00753 if( MPI_COMM_NULL != ocnCouComm ) MPI_Comm_free( &ocnCouComm ); 00754 MPI_Group_free( &joinOcnCouGroup ); 00755 #endif 00756 00757 #ifdef ENABLE_ATMLND_COUPLING 00758 if( MPI_COMM_NULL != lndComm ) MPI_Comm_free( &lndComm ); 00759 // free land - coupler group and comm 00760 if( MPI_COMM_NULL != lndCouComm ) MPI_Comm_free( &lndCouComm ); 00761 MPI_Group_free( &joinLndCouGroup ); 00762 #endif 00763 00764 if( MPI_COMM_NULL != couComm ) MPI_Comm_free( &couComm ); 00765 00766 MPI_Group_free( &atmPEGroup ); 00767 #ifdef ENABLE_ATMOCN_COUPLING 00768 MPI_Group_free( &ocnPEGroup ); 00769 #endif 00770 #ifdef ENABLE_ATMLND_COUPLING 00771 MPI_Group_free( &lndPEGroup ); 00772 #endif 00773 MPI_Group_free( &couPEGroup ); 00774 MPI_Group_free( &jgroup ); 00775 00776 MPI_Finalize(); 00777 // endif #if 0 00778 00779 return 0; 00780 }
