MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 C push parallel mesh into moab, using iMoab API, F77 version 00002 C 00003 C This program shows how to push a mesh into MOAB in parallel using iMoab, with sufficient 00004 C information to resolve boundary sharing and exchange a layer of ghost information. 00005 C 00006 C After resolving the sharing, mesh is saved to a file, then read back again, in parallel 00007 C the mesh is a quad mesh, 2x2 on each task, 00008 C by default, this test is run on 2 processors 00009 00010 C Test is similar to itaps/iMeshP_unit_tests.cpp 00011 C 00012 C 00013 C Create a mesh: 00014 C Groups of four quads will be arranged into parts as follows: 00015 C +------+------+------+------+------+----- 00016 C | | | 00017 C | | | 00018 C + Part 0 + Part 2 + Part 4 00019 C | | | 00020 C | | | 00021 C +------+------+------+------+------+----- 00022 C | | | 00023 C | | | 00024 C + Part 1 + Part 3 + Part 5 00025 C | | | 00026 C | | | 00027 C +------+------+------+------+------+----- 00028 C 00029 C Vertices will be enumerated as follows: 00030 C 1------6-----11-----16-----21-----26----- > x x from 0, 1, 2 00031 C | | | 00032 C | | | 00033 C 2 7 12 17 22 27 00034 C | | | 00035 C | | | 00036 C 3------8-----13-----18-----23-----28----- 00037 C | | | 00038 C | | | 00039 C 4 9 14 19 24 29 00040 C | | | 00041 C | | | 00042 C 5-----10-----15-----20-----25-----30----- 00043 C | 00044 C y varies from 0 to 4 00045 C 00046 C Processor 0 will have vertices 1, 2, 3, 6, 7, 8, 11, 12, 13 00047 C and 4 quads, with ids from 1 to 4, and connectivity 00048 C 1, 2, 7, 6; 2, 3, 8, 7; 6 ,7, 12, 11; 7, 8, 13, 12 00049 C Processor 1 will have vertices 3, 4, 5, 8, 9, 10, 13, 14, 15 00050 C and 4 quads, with ids from 5 to 8, and connectivity 00051 C 3, 4, 8, 9; 4, 5, 10, 9; 8, 9, 14, 13; 9, 10, 15, 14, 00052 C and so on 00053 C 00054 C Vertex Global IDs will be used to resolve sharing 00055 C 00056 C Element IDs will be [4*rank+1,4*rank+5] 00057 C #define ERROR(rval) if (0 .ne. rval) call exit(1) 00058 00059 00060 SUBROUTINE errorout(ierr, message) 00061 integer ierr 00062 character*(*) message 00063 if (ierr.ne.0) then 00064 print *, message 00065 call exit (1) 00066 end if 00067 return 00068 end 00069 00070 #include "moab/MOABConfig.h" 00071 program imoabpar_test 00072 C implicit none 00073 00074 use iMOAB 00075 #include "mpif.h" 00076 00077 integer ierr, my_id, num_procs, pid, i, ix, iy, numv, nume 00078 integer dime, lco, mbtype, blockid, npe 00079 integer compid 00080 character :: appname*10 00081 character :: outfile*100, wopts*100 00082 C coordinates for 9 vertices 00083 double precision coordinates(27) , coords_core(27), deltax, deltay 00084 integer ids(9) 00085 integer connec(16) 00086 C used for ghosting 00087 integer dimgh, bridge, num_layers 00088 00089 data coords_core/ 0., 0., 0., 00090 & 0., 1., 0., 00091 & 0., 2., 0., 00092 & 1., 0., 0., 00093 & 1., 1., 0., 00094 & 1., 2., 0., 00095 & 2., 0., 0., 00096 & 2., 1., 0., 00097 & 2., 2., 0./ 00098 data ids/1, 2, 3, 6, 7, 8, 11, 12, 13/ 00099 data connec/ 1, 2, 5, 4, 00100 & 2, 3, 6, 5, 00101 & 4, 5, 8, 7, 00102 & 5, 6, 9, 8/ 00103 00104 call MPI_Init ( ierr ) 00105 call errorout(ierr, 'fail to initialize MPI') 00106 00107 ierr = iMOAB_Initialize() 00108 call errorout(ierr, 'fail to initialize iMOAB') 00109 00110 call MPI_COMM_RANK (MPI_COMM_WORLD, my_id, ierr) 00111 call errorout(ierr, 'fail to get MPI rank') 00112 00113 call MPI_COMM_SIZE (MPI_COMM_WORLD, num_procs, ierr) 00114 call errorout(ierr, 'fail to get MPI size') 00115 00116 ! find out MY process ID, and how many processes were started. 00117 if (my_id .eq. 0) then 00118 print *, " I'm process ", my_id, " out of ", 00119 & num_procs, " processes." 00120 end if 00121 00122 ! give a component id 00123 compid = 7 00124 appname = 'IMTEST'//CHAR(0) 00125 ierr = iMOAB_RegisterApplication(appname, MPI_COMM_WORLD, 00126 & compid, pid) 00127 call errorout(ierr, 'fail to initialize fortran app') 00128 00129 ! create first 9 vertices, in a square 3x3; 00130 deltax=(my_id/2) * 2. 00131 deltay = mod(my_id, 2) * 2. 00132 ix = (my_id/2) * 10 00133 iy = mod(my_id,2) * 2 00134 do i=1,9 00135 coordinates( 3*(i-1) + 1 ) = coords_core (3*(i-1)+1) + deltax 00136 coordinates( 3*(i-1) + 2 ) = coords_core (3*(i-1)+2) + deltay 00137 coordinates( 3*(i-1) + 3 ) = coords_core (3*(i-1)+3) 00138 00139 ! translate the ids too, by multiples of 10 or add 2 00140 ids(i) = ids(i) + ix+iy 00141 enddo 00142 numv = 9 00143 nume = 4 00144 lco = numv*3 00145 dime = 3 00146 ierr = iMOAB_CreateVertices(pid, lco, dime, coordinates); 00147 call errorout(ierr, 'fail to create vertices') 00148 00149 ! create now 4 quads with those 9 vertices 00150 mbtype = 3 00151 blockid = 100 00152 npe = 4 00153 ierr = iMOAB_CreateElements(pid, nume, mbtype, npe, 00154 & connec, blockid) 00155 call errorout(ierr, 'fail to create quads') 00156 00157 ierr = iMOAB_ResolveSharedEntities( pid, numv, ids ); 00158 call errorout(ierr, 'fail to resolve shared entities') 00159 00160 ! see ghost elements 00161 dimgh = 2 ! will ghost quads, topological dim 2 00162 bridge = 0 ! use vertex as bridge 00163 num_layers = 1 ! so far, one layer only 00164 ierr = iMOAB_DetermineGhostEntities( pid, dimgh, num_layers, 00165 & bridge) 00166 call errorout(ierr, 'fail to determine ghosts') 00167 00168 ! write out the mesh file to disk, in parallel, if h5m 00169 #ifdef MOAB_HAVE_HDF5 00170 outfile = 'wholeF.h5m'//CHAR(0) 00171 wopts = 'PARALLEL=WRITE_PART'//CHAR(0) 00172 ierr = iMOAB_WriteMesh(pid, outfile, wopts) 00173 call errorout(ierr, 'fail to write the mesh file') 00174 #endif 00175 00176 ! all done. de-register and finalize 00177 ierr = iMOAB_DeregisterApplication(pid) 00178 call errorout(ierr, 'fail to deregister application') 00179 00180 ierr = iMOAB_Finalize() 00181 call errorout(ierr, 'fail to finalize iMOAB') 00182 00183 00184 call MPI_FINALIZE ( ierr ) 00185 call errorout(ierr, 'fail to finalize MPI') 00186 00187 end 00188
