MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /* 00002 * This imoab_read_map test will simulate coupling between 2 components 00003 * 2 meshes will be loaded from 2 files (src, tgt), and one map file 00004 * after the map is read, in parallel, on coupler pes, with distributed rows, the 00005 * coupler meshes for source and target will be generated, in a migration step, 00006 * in which we will migrate from target pes according to row ids, to coupler target mesh, 00007 * and from source to coverage mesh mesh on coupler. During this migration, par comm graphs 00008 * will be established between source and coupler and target and coupler, which will assist 00009 * in field transfer from source to target, through coupler 00010 * 00011 */ 00012 00013 #include "moab/Core.hpp" 00014 #ifndef MOAB_HAVE_MPI 00015 #error mbtempest tool requires MPI configuration 00016 #endif 00017 00018 // MPI includes 00019 #include "moab_mpi.h" 00020 #include "moab/ParallelComm.hpp" 00021 #include "MBParallelConventions.h" 00022 00023 #include "moab/iMOAB.h" 00024 #include "TestUtil.hpp" 00025 #include "moab/CpuTimer.hpp" 00026 #include "moab/ProgOptions.hpp" 00027 #include <iostream> 00028 #include <sstream> 00029 00030 #include "imoab_coupler_utils.hpp" 00031 00032 #ifndef MOAB_HAVE_TEMPESTREMAP 00033 #error The climate coupler test example requires MOAB configuration with TempestRemap 00034 #endif 00035 00036 int main( int argc, char* argv[] ) 00037 { 00038 int ierr; 00039 int rankInGlobalComm, numProcesses; 00040 MPI_Group jgroup; 00041 std::string readopts( "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION;PARALLEL_RESOLVE_SHARED_ENTS" ); 00042 00043 // Timer data 00044 moab::CpuTimer timer; 00045 double timer_ops; 00046 std::string opName; 00047 00048 MPI_Init( &argc, &argv ); 00049 MPI_Comm_rank( MPI_COMM_WORLD, &rankInGlobalComm ); 00050 MPI_Comm_size( MPI_COMM_WORLD, &numProcesses ); 00051 00052 MPI_Comm_group( MPI_COMM_WORLD, &jgroup ); // all processes in jgroup 00053 00054 std::string atmFilename = TestDir + "unittest/wholeATM_T.h5m"; 00055 // on a regular case, 5 ATM, 6 CPLATM (ATMX), 17 OCN , 18 CPLOCN (OCNX) ; 00056 // intx atm/ocn is not in e3sm yet, give a number 00057 // 6 * 100+ 18 = 618 : atmocnid 00058 // 9 LND, 10 CPLLND 00059 // 6 * 100 + 10 = 610 atmlndid: 00060 // cmpatm is for atm on atm pes 00061 // cmpocn is for ocean, on ocean pe 00062 // cplatm is for atm on coupler pes 00063 // cplocn is for ocean on coupelr pes 00064 // atmocnid is for intx atm / ocn on coupler pes 00065 // 00066 int rankInAtmComm = -1; 00067 int cmpatm = 5, 00068 cplatm = 6; // component ids are unique over all pes, and established in advance; 00069 00070 std::string ocnFilename = TestDir + "unittest/recMeshOcn.h5m"; 00071 std::string mapFilename = TestDir + "unittest/atm_ocn_map.nc"; // this is a netcdf file! 00072 00073 std::string baseline = TestDir + "unittest/baseline1.txt"; 00074 int rankInOcnComm = -1; 00075 int cmpocn = 17, cplocn = 18, 00076 atmocnid = 618; // component ids are unique over all pes, and established in advance; 00077 00078 int rankInCouComm = -1; 00079 00080 int nghlay = 0; // number of ghost layers for loading the file 00081 std::vector< int > groupTasks; 00082 int startG1 = 0, startG2 = 0, endG1 = numProcesses - 1, endG2 = numProcesses - 1; 00083 00084 int startG4 = startG1, endG4 = endG1; // these are for coupler layout 00085 int context_id = -1; // used now for freeing buffers 00086 00087 // default: load atm on 2 proc, ocean on 2, 00088 // load map on 2 also, in parallel, distributed by rows (which is very bad actually for ocean mesh, because 00089 // probably all source cells will be involved in coverage mesh on both tasks 00090 00091 ProgOptions opts; 00092 opts.addOpt< std::string >( "atmosphere,t", "atm mesh filename (source)", &atmFilename ); 00093 opts.addOpt< std::string >( "ocean,m", "ocean mesh filename (target)", &ocnFilename ); 00094 opts.addOpt< std::string >( "map_file,w", "map file from source to target", &mapFilename ); 00095 00096 opts.addOpt< int >( "startAtm,a", "start task for atmosphere layout", &startG1 ); 00097 opts.addOpt< int >( "endAtm,b", "end task for atmosphere layout", &endG1 ); 00098 00099 opts.addOpt< int >( "startOcn,c", "start task for ocean layout", &startG2 ); 00100 opts.addOpt< int >( "endOcn,d", "end task for ocean layout", &endG2 ); 00101 00102 opts.addOpt< int >( "startCoupler,g", "start task for coupler layout", &startG4 ); 00103 opts.addOpt< int >( "endCoupler,j", "end task for coupler layout", &endG4 ); 00104 00105 int n = 1; // number of send/receive / project / send back cycles 00106 opts.addOpt< int >( "iterations,n", "number of iterations for coupler", &n ); 00107 00108 bool no_regression_test = false; 00109 opts.addOpt< void >( "no_regression,r", "do not do regression test against baseline 1", &no_regression_test ); 00110 opts.parseCommandLine( argc, argv ); 00111 00112 char fileWriteOptions[] = "PARALLEL=WRITE_PART"; 00113 00114 if( !rankInGlobalComm ) 00115 { 00116 std::cout << " atm file: " << atmFilename << "\n on tasks : " << startG1 << ":" << endG1 00117 << "\n ocn file: " << ocnFilename << "\n on tasks : " << startG2 << ":" << endG2 00118 << "\n map file:" << mapFilename << "\n on tasks : " << startG4 << ":" << endG4 << "\n"; 00119 if( !no_regression_test ) 00120 { 00121 std::cout << " check projection against baseline: " << baseline << "\n"; 00122 } 00123 } 00124 00125 // load files on 3 different communicators, groups 00126 // first groups has task 0, second group tasks 0 and 1 00127 // coupler will be on joint tasks, will be on a third group (0 and 1, again) 00128 // first groups has task 0, second group tasks 0 and 1 00129 // coupler will be on joint tasks, will be on a third group (0 and 1, again) 00130 MPI_Group atmPEGroup; 00131 MPI_Comm atmComm; 00132 ierr = create_group_and_comm( startG1, endG1, jgroup, &atmPEGroup, &atmComm ); 00133 CHECKIERR( ierr, "Cannot create atm MPI group and communicator " ) 00134 00135 MPI_Group ocnPEGroup; 00136 MPI_Comm ocnComm; 00137 ierr = create_group_and_comm( startG2, endG2, jgroup, &ocnPEGroup, &ocnComm ); 00138 CHECKIERR( ierr, "Cannot create ocn MPI group and communicator " ) 00139 00140 // we will always have a coupler 00141 MPI_Group couPEGroup; 00142 MPI_Comm couComm; 00143 ierr = create_group_and_comm( startG4, endG4, jgroup, &couPEGroup, &couComm ); 00144 CHECKIERR( ierr, "Cannot create cpl MPI group and communicator " ) 00145 00146 // atm_coupler 00147 MPI_Group joinAtmCouGroup; 00148 MPI_Comm atmCouComm; 00149 ierr = create_joint_comm_group( atmPEGroup, couPEGroup, &joinAtmCouGroup, &atmCouComm ); 00150 CHECKIERR( ierr, "Cannot create joint atm cou communicator" ) 00151 00152 // ocn_coupler 00153 MPI_Group joinOcnCouGroup; 00154 MPI_Comm ocnCouComm; 00155 ierr = create_joint_comm_group( ocnPEGroup, couPEGroup, &joinOcnCouGroup, &ocnCouComm ); 00156 CHECKIERR( ierr, "Cannot create joint ocn cou communicator" ) 00157 00158 ierr = iMOAB_Initialize( argc, argv ); // not really needed anything from argc, argv, yet; maybe we should 00159 CHECKIERR( ierr, "Cannot initialize iMOAB" ) 00160 00161 int cmpAtmAppID = -1; 00162 iMOAB_AppID cmpAtmPID = &cmpAtmAppID; // atm 00163 int cplAtmAppID = -1; // -1 means it is not initialized 00164 iMOAB_AppID cplAtmPID = &cplAtmAppID; // atm on coupler PEs 00165 00166 int cmpOcnAppID = -1; 00167 iMOAB_AppID cmpOcnPID = &cmpOcnAppID; // ocn 00168 int cplOcnAppID = -1, cplAtmOcnAppID = -1; // -1 means it is not initialized 00169 iMOAB_AppID cplOcnPID = &cplOcnAppID; // ocn on coupler PEs 00170 iMOAB_AppID cplAtmOcnPID = &cplAtmOcnAppID; // intx atm -ocn on coupler PEs 00171 00172 if( couComm != MPI_COMM_NULL ) 00173 { 00174 MPI_Comm_rank( couComm, &rankInCouComm ); 00175 // Register all the applications on the coupler PEs 00176 ierr = iMOAB_RegisterApplication( "ATMX", &couComm, &cplatm, 00177 cplAtmPID ); // atm on coupler pes 00178 CHECKIERR( ierr, "Cannot register ATM over coupler PEs" ) 00179 00180 ierr = iMOAB_RegisterApplication( "OCNX", &couComm, &cplocn, 00181 cplOcnPID ); // ocn on coupler pes 00182 CHECKIERR( ierr, "Cannot register OCN over coupler PEs" ) 00183 } 00184 00185 if( atmComm != MPI_COMM_NULL ) 00186 { 00187 MPI_Comm_rank( atmComm, &rankInAtmComm ); 00188 ierr = iMOAB_RegisterApplication( "ATM1", &atmComm, &cmpatm, cmpAtmPID ); 00189 CHECKIERR( ierr, "Cannot register ATM App" ) 00190 ierr = iMOAB_LoadMesh( cmpAtmPID, atmFilename.c_str(), readopts.c_str(), &nghlay ); 00191 CHECKIERR( ierr, "Cannot load atm mesh" ) 00192 } 00193 00194 MPI_Barrier( MPI_COMM_WORLD ); 00195 if( ocnComm != MPI_COMM_NULL ) 00196 { 00197 MPI_Comm_rank( ocnComm, &rankInOcnComm ); 00198 ierr = iMOAB_RegisterApplication( "OCN1", &ocnComm, &cmpocn, cmpOcnPID ); 00199 CHECKIERR( ierr, "Cannot register OCN App" ) 00200 ierr = iMOAB_LoadMesh( cmpOcnPID, ocnFilename.c_str(), readopts.c_str(), &nghlay ); 00201 CHECKIERR( ierr, "Cannot load ocn mesh" ) 00202 } 00203 00204 MPI_Barrier( MPI_COMM_WORLD ); 00205 00206 if( couComm != MPI_COMM_NULL ) 00207 { 00208 // now load map between OCNx and ATMx on coupler PEs 00209 ierr = iMOAB_RegisterApplication( "ATMOCN", &couComm, &atmocnid, cplAtmOcnPID ); 00210 CHECKIERR( ierr, "Cannot register ocn_atm map instance over coupler pes " ) 00211 } 00212 00213 int disc_orders[3] = { 4, 1, 1 }; 00214 00215 const std::string intx_from_file_identifier = "map-from-file"; 00216 00217 if( couComm != MPI_COMM_NULL ) 00218 { 00219 int dummyCpl = -1; 00220 int dummy_rowcol = -1; 00221 int dummyType = 0; 00222 ierr = iMOAB_LoadMappingWeightsFromFile( cplAtmOcnPID, &dummyCpl, &dummy_rowcol, &dummyType, 00223 intx_from_file_identifier.c_str(), mapFilename.c_str() ); 00224 CHECKIERR( ierr, "failed to load map file from disk" ); 00225 } 00226 00227 if( atmCouComm != MPI_COMM_NULL ) 00228 { 00229 int type = 1; // quads in source set 00230 int direction = 1; // from source to coupler; will create a mesh on cplAtmPID 00231 // because it is like "coverage", context will be cplocn 00232 ierr = iMOAB_MigrateMapMesh( cmpAtmPID, cplAtmOcnPID, cplAtmPID, &atmCouComm, &atmPEGroup, &couPEGroup, &type, 00233 &cmpatm, &cplocn, &direction ); 00234 CHECKIERR( ierr, "failed to migrate mesh for atm on coupler" ); 00235 #ifdef VERBOSE 00236 if( *cplAtmPID >= 0 ) 00237 { 00238 char prefix[] = "atmcov"; 00239 ierr = iMOAB_WriteLocalMesh( cplAtmPID, prefix ); 00240 CHECKIERR( ierr, "failed to write local mesh" ); 00241 } 00242 #endif 00243 } 00244 MPI_Barrier( MPI_COMM_WORLD ); 00245 00246 if( ocnCouComm != MPI_COMM_NULL ) 00247 { 00248 int type = 3; // cells with GLOBAL_ID in ocean / target set 00249 int direction = 2; // from coupler to target; will create a mesh on cplOcnPID 00250 // it will be like initial migrate cmpocn <-> cplocn 00251 ierr = iMOAB_MigrateMapMesh( cmpOcnPID, cplAtmOcnPID, cplOcnPID, &ocnCouComm, &ocnPEGroup, &couPEGroup, &type, 00252 &cmpocn, &cplocn, &direction ); 00253 CHECKIERR( ierr, "failed to migrate mesh for ocn on coupler" ); 00254 #ifdef VERBOSE 00255 if( *cplOcnPID >= 0 ) 00256 { 00257 char prefix[] = "ocntgt"; 00258 ierr = iMOAB_WriteLocalMesh( cplOcnPID, prefix ); 00259 CHECKIERR( ierr, "failed to write local ocean mesh" ); 00260 char outputFileRec[] = "CoupOcn.h5m"; 00261 ierr = iMOAB_WriteMesh( cplOcnPID, outputFileRec, fileWriteOptions ); 00262 CHECKIERR( ierr, "failed to write ocean global mesh file" ); 00263 } 00264 #endif 00265 } 00266 MPI_Barrier( MPI_COMM_WORLD ); 00267 00268 int tagIndex[2]; 00269 int tagTypes[2] = { DENSE_DOUBLE, DENSE_DOUBLE }; 00270 int atmCompNDoFs = disc_orders[0] * disc_orders[0], ocnCompNDoFs = 1 /*FV*/; 00271 00272 const char* bottomFields = "a2oTbot:a2oUbot:a2oVbot"; 00273 const char* bottomProjectedFields = "a2oTbot_proj:a2oUbot_proj:a2oVbot_proj"; 00274 00275 if( couComm != MPI_COMM_NULL ) 00276 { 00277 ierr = iMOAB_DefineTagStorage( cplAtmPID, bottomFields, &tagTypes[0], &atmCompNDoFs, &tagIndex[0] ); 00278 CHECKIERR( ierr, "failed to define the field tags a2oTbot:a2oUbot:a2oVbot" ); 00279 00280 ierr = iMOAB_DefineTagStorage( cplOcnPID, bottomProjectedFields, &tagTypes[1], &ocnCompNDoFs, &tagIndex[1] ); 00281 CHECKIERR( ierr, "failed to define the field tags a2oTbot_proj:a2oUbot_proj:a2oVbot_proj " ); 00282 } 00283 00284 // need to make sure that the coverage mesh (created during intx method) received the tag that 00285 // need to be projected to target so far, the coverage mesh has only the ids and global dofs; 00286 // need to change the migrate method to accommodate any GLL tag 00287 // now send a tag from original atmosphere (cmpAtmPID) towards migrated coverage mesh 00288 // (cplAtmPID), using the new coverage graph communicator 00289 00290 // make the tag 0, to check we are actually sending needed data 00291 { 00292 if( cplAtmAppID >= 0 ) 00293 { 00294 int nverts[3], nelem[3], nblocks[3], nsbc[3], ndbc[3]; 00295 /* 00296 * Each process in the communicator will have access to a local mesh instance, which 00297 * will contain the original cells in the local partition and ghost entities. Number of 00298 * vertices, primary cells, visible blocks, number of sidesets and nodesets boundary 00299 * conditions will be returned in numProcesses 3 arrays, for local, ghost and total 00300 * numbers. 00301 */ 00302 ierr = iMOAB_GetMeshInfo( cplAtmPID, nverts, nelem, nblocks, nsbc, ndbc ); 00303 CHECKIERR( ierr, "failed to get num primary elems" ); 00304 int numAllElem = nelem[2]; 00305 std::vector< double > vals; 00306 int storLeng = atmCompNDoFs * numAllElem * 3; // 3 tags 00307 int eetype = 1; 00308 00309 vals.resize( storLeng ); 00310 for( int k = 0; k < storLeng; k++ ) 00311 vals[k] = 0.; 00312 00313 ierr = iMOAB_SetDoubleTagStorage( cplAtmPID, bottomFields, &storLeng, &eetype, &vals[0] ); 00314 CHECKIERR( ierr, "cannot make tag nul" ) 00315 } 00316 } 00317 00318 const char* concat_fieldname = "a2oTbot:a2oUbot:a2oVbot"; 00319 const char* concat_fieldnameT = "a2oTbot_proj:a2oUbot_proj:a2oVbot_proj"; 00320 00321 // start a virtual loop for number of iterations 00322 for( int iters = 0; iters < n; iters++ ) 00323 { 00324 00325 PUSH_TIMER( "Send/receive data from atm component to coupler in ocn context" ) 00326 if( atmComm != MPI_COMM_NULL ) 00327 { 00328 // as always, use nonblocking sends 00329 // this is for projection to ocean: 00330 ierr = iMOAB_SendElementTag( cmpAtmPID, "a2oTbot:a2oUbot:a2oVbot", &atmCouComm, &cplocn ); 00331 CHECKIERR( ierr, "cannot send tag values" ) 00332 #ifdef GRAPH_INFO 00333 int is_sender = 1; 00334 int context = cplocn; 00335 iMOAB_DumpCommGraph( cmpAtmPID, &context, &is_sender, "AtmCovOcnS" ); 00336 #endif 00337 } 00338 if( couComm != MPI_COMM_NULL ) 00339 { 00340 // receive on atm on coupler pes, that was redistributed according to coverage 00341 ierr = iMOAB_ReceiveElementTag( cplAtmPID, "a2oTbot:a2oUbot:a2oVbot", &atmCouComm, &cmpatm ); 00342 CHECKIERR( ierr, "cannot receive tag values" ) 00343 #ifdef GRAPH_INFO 00344 int is_sender = 0; 00345 int context = atmocnid; // the same context 00346 iMOAB_DumpCommGraph( cmpAtmPID, &context, &is_sender, "AtmCovOcnR" ); 00347 #endif 00348 } 00349 00350 // we can now free the sender buffers 00351 if( atmComm != MPI_COMM_NULL ) 00352 { 00353 ierr = iMOAB_FreeSenderBuffers( cmpAtmPID, &cplocn ); // context is for ocean 00354 CHECKIERR( ierr, "cannot free buffers used to resend atm tag towards the coverage mesh" ) 00355 } 00356 POP_TIMER( MPI_COMM_WORLD, rankInGlobalComm ) 00357 #ifdef VERBOSE 00358 if( *cplAtmPID >= 0 && n == 1 ) 00359 { 00360 char prefix[] = "atmcov_withdata"; 00361 ierr = iMOAB_WriteLocalMesh( cplAtmPID, prefix ); 00362 CHECKIERR( ierr, "failed to write local atm cov mesh with data" ); 00363 } 00364 00365 if( couComm != MPI_COMM_NULL && 1 == n ) 00366 { 00367 // write only for n==1 case 00368 char outputFileRecvd[] = "recvAtmCoupOcn.h5m"; 00369 ierr = iMOAB_WriteMesh( cplAtmPID, outputFileRecvd, fileWriteOptions ); 00370 CHECKIERR( ierr, "could not write recvAtmCoupOcn.h5m to disk" ) 00371 } 00372 #endif 00373 00374 if( couComm != MPI_COMM_NULL ) 00375 { 00376 /* We have the remapping weights now. Let us apply the weights onto the tag we defined 00377 on the source mesh and get the projection on the target mesh */ 00378 PUSH_TIMER( "Apply Scalar projection weights" ) 00379 ierr = iMOAB_ApplyScalarProjectionWeights( cplAtmOcnPID, intx_from_file_identifier.c_str(), 00380 concat_fieldname, concat_fieldnameT ); 00381 CHECKIERR( ierr, "failed to compute projection weight application" ); 00382 POP_TIMER( couComm, rankInCouComm ) 00383 if( 1 == n ) // write only for n==1 case 00384 { 00385 char outputFileTgt[] = "fOcnOnCpl8.h5m"; 00386 ierr = iMOAB_WriteMesh( cplOcnPID, outputFileTgt, fileWriteOptions ); 00387 CHECKIERR( ierr, "could not write fOcnOnCpl8.h5m to disk" ) 00388 } 00389 } 00390 00391 // send the projected tag back to ocean pes, with send/receive tag 00392 if( ocnComm != MPI_COMM_NULL ) 00393 { 00394 int tagIndexIn2; 00395 ierr = 00396 iMOAB_DefineTagStorage( cmpOcnPID, bottomProjectedFields, &tagTypes[1], &ocnCompNDoFs, &tagIndexIn2 ); 00397 CHECKIERR( ierr, "failed to define the field tag for receiving back the tags " 00398 "a2oTbot_proj:a2oUbot_proj:a2oVbot_proj on ocn pes" ); 00399 } 00400 // send the tag to ocean pes, from ocean mesh on coupler pes 00401 // from couComm, using common joint comm ocn_coupler 00402 // as always, use nonblocking sends 00403 // original graph (context is -1_ 00404 if( couComm != MPI_COMM_NULL ) 00405 { 00406 // need to use ocean comp id for context 00407 context_id = cmpocn; // id for ocean on comp 00408 ierr = 00409 iMOAB_SendElementTag( cplOcnPID, "a2oTbot_proj:a2oUbot_proj:a2oVbot_proj", &ocnCouComm, &context_id ); 00410 CHECKIERR( ierr, "cannot send tag values back to ocean pes" ) 00411 } 00412 00413 // receive on component 2, ocean 00414 if( ocnComm != MPI_COMM_NULL ) 00415 { 00416 context_id = cplocn; // id for ocean on coupler 00417 ierr = iMOAB_ReceiveElementTag( cmpOcnPID, "a2oTbot_proj:a2oUbot_proj:a2oVbot_proj", &ocnCouComm, 00418 &context_id ); 00419 CHECKIERR( ierr, "cannot receive tag values from ocean mesh on coupler pes" ) 00420 } 00421 00422 if( couComm != MPI_COMM_NULL ) 00423 { 00424 context_id = cmpocn; 00425 ierr = iMOAB_FreeSenderBuffers( cplOcnPID, &context_id ); 00426 } 00427 MPI_Barrier( MPI_COMM_WORLD ); 00428 00429 if( ocnComm != MPI_COMM_NULL && 1 == n ) // write only for n==1 case 00430 { 00431 #ifdef VERBOSE 00432 char outputFileOcn[] = "OcnWithProj.h5m"; 00433 ierr = iMOAB_WriteMesh( cmpOcnPID, outputFileOcn, fileWriteOptions ); 00434 CHECKIERR( ierr, "could not write OcnWithProj.h5m to disk" ) 00435 #endif 00436 // test results only for n == 1, for bottomTempProjectedField = "a2oTbot_proj" 00437 if( !no_regression_test ) 00438 { 00439 // the same as remap test 00440 // get temp field on ocean, from conservative, the global ids, and dump to the baseline file 00441 // first get GlobalIds from ocn, and fields: 00442 int nverts[3], nelem[3]; 00443 ierr = iMOAB_GetMeshInfo( cmpOcnPID, nverts, nelem, 0, 0, 0 ); 00444 CHECKIERR( ierr, "failed to get ocn mesh info" ); 00445 std::vector< int > gidElems; 00446 gidElems.resize( nelem[2] ); 00447 std::vector< double > tempElems; 00448 tempElems.resize( nelem[2] ); 00449 // get global id storage 00450 const std::string GidStr = "GLOBAL_ID"; // hard coded too 00451 int tag_type = DENSE_INTEGER, ncomp = 1, tagInd = 0; 00452 ierr = iMOAB_DefineTagStorage( cmpOcnPID, GidStr.c_str(), &tag_type, &ncomp, &tagInd ); 00453 CHECKIERR( ierr, "failed to define global id tag" ); 00454 00455 int ent_type = 1; 00456 ierr = iMOAB_GetIntTagStorage( cmpOcnPID, GidStr.c_str(), &nelem[2], &ent_type, &gidElems[0] ); 00457 CHECKIERR( ierr, "failed to get global ids" ); 00458 ierr = iMOAB_GetDoubleTagStorage( cmpOcnPID, "a2oTbot_proj", &nelem[2], &ent_type, &tempElems[0] ); 00459 CHECKIERR( ierr, "failed to get temperature field" ); 00460 int err_code = 1; 00461 check_baseline_file( baseline, gidElems, tempElems, 1.e-9, err_code ); 00462 if( 0 == err_code ) 00463 std::cout << " passed baseline test atm2ocn on ocean task " << rankInOcnComm << "\n"; 00464 } 00465 } 00466 00467 } // end loop iterations n 00468 00469 if( couComm != MPI_COMM_NULL ) 00470 { 00471 ierr = iMOAB_DeregisterApplication( cplAtmOcnPID ); 00472 CHECKIERR( ierr, "cannot deregister app intx AO" ) 00473 } 00474 if( ocnComm != MPI_COMM_NULL ) 00475 { 00476 ierr = iMOAB_DeregisterApplication( cmpOcnPID ); 00477 CHECKIERR( ierr, "cannot deregister app OCN1" ) 00478 } 00479 00480 if( atmComm != MPI_COMM_NULL ) 00481 { 00482 ierr = iMOAB_DeregisterApplication( cmpAtmPID ); 00483 CHECKIERR( ierr, "cannot deregister app ATM1" ) 00484 } 00485 00486 if( couComm != MPI_COMM_NULL ) 00487 { 00488 ierr = iMOAB_DeregisterApplication( cplOcnPID ); 00489 CHECKIERR( ierr, "cannot deregister app OCNX" ) 00490 } 00491 00492 if( couComm != MPI_COMM_NULL ) 00493 { 00494 ierr = iMOAB_DeregisterApplication( cplAtmPID ); 00495 CHECKIERR( ierr, "cannot deregister app ATMX" ) 00496 } 00497 00498 //#endif 00499 ierr = iMOAB_Finalize(); 00500 CHECKIERR( ierr, "did not finalize iMOAB" ) 00501 00502 // free atm coupler group and comm 00503 if( MPI_COMM_NULL != atmCouComm ) MPI_Comm_free( &atmCouComm ); 00504 MPI_Group_free( &joinAtmCouGroup ); 00505 if( MPI_COMM_NULL != atmComm ) MPI_Comm_free( &atmComm ); 00506 00507 if( MPI_COMM_NULL != ocnComm ) MPI_Comm_free( &ocnComm ); 00508 // free ocn - coupler group and comm 00509 if( MPI_COMM_NULL != ocnCouComm ) MPI_Comm_free( &ocnCouComm ); 00510 MPI_Group_free( &joinOcnCouGroup ); 00511 00512 if( MPI_COMM_NULL != couComm ) MPI_Comm_free( &couComm ); 00513 00514 MPI_Group_free( &atmPEGroup ); 00515 00516 MPI_Group_free( &ocnPEGroup ); 00517 00518 MPI_Group_free( &couPEGroup ); 00519 MPI_Group_free( &jgroup ); 00520 00521 MPI_Finalize(); 00522 00523 return 0; 00524 }
