MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 #include "Internals.hpp" 00002 #include <iostream> 00003 using namespace std; 00004 00005 using namespace moab; 00006 00007 HandleUtils handleUtils( 0, 1 ); 00008 00009 bool internal_assert( bool c ) 00010 { 00011 return !c; 00012 } 00013 00014 #define handle_test_assert( C ) \ 00015 if( internal_assert( C ) ) \ 00016 { \ 00017 cout << "Test: " #C " failed ." << endl; \ 00018 return false; \ 00019 } 00020 00021 bool handle_test( EntityType type, EntityID id, int proc, bool should_fail ) 00022 { 00023 int err = 0; 00024 EntityHandle handle = CREATE_HANDLE( type, handleUtils.create_id( id, proc ), err ); 00025 if( should_fail ) 00026 { 00027 handle_test_assert( err ) return true; 00028 } 00029 handle_test_assert( !err ) 00030 00031 EntityType type_from_handle = TYPE_FROM_HANDLE( handle ); 00032 handle_test_assert( type_from_handle == type ) 00033 00034 EntityID id_from_handle = handleUtils.id_from_handle( handle ); 00035 handle_test_assert( id_from_handle == id ) 00036 00037 int proc_from_handle = handleUtils.rank_from_handle( handle ); 00038 handle_test_assert( proc_from_handle == proc ) 00039 00040 return true; 00041 } 00042 00043 #define tag_test_assert( C ) \ 00044 if( internal_assert( C ) ) \ 00045 { \ 00046 cout << "Test: " #C " failed." << endl; \ 00047 return false; \ 00048 } 00049 00050 bool tag_test( TagId id, TagType prop ) 00051 { 00052 Tag tag = TAG_HANDLE_FROM_ID( id, prop ); 00053 00054 unsigned long id_from_handle = ID_FROM_TAG_HANDLE( tag ); 00055 tag_test_assert( id_from_handle == id ) 00056 00057 TagType prop_from_handle = PROP_FROM_TAG_HANDLE( tag ); 00058 tag_test_assert( prop_from_handle == prop ) 00059 00060 return true; 00061 } 00062 00063 //! Sample code on a 32-bit system. 00064 int main() 00065 { 00066 const unsigned cpus[] = { 1, 4, 16, 5, 20 }; 00067 const int num_cpus = sizeof( cpus ) / sizeof( cpus[0] ); 00068 unsigned errors = 0, tests = 0; 00069 const int num_prop = MB_TAG_LAST + 1; 00070 00071 ++tests; 00072 if( MB_TAG_LAST > num_prop ) 00073 { 00074 cout << "MB_TAG_PROP_WIDTH insufficient for size of TagType" << endl; 00075 ++errors; 00076 } 00077 00078 ++tests; 00079 if( MBMAXTYPE > 1 << MB_TYPE_WIDTH ) 00080 { 00081 cout << "MB_TYPE_WIDTH insufficient for size of EntityType" << endl; 00082 ++errors; 00083 } 00084 00085 // if any errors so far, abort because everything else will 00086 // probably fail. 00087 if( errors ) return errors; 00088 00089 for( int num_cpu = 0; num_cpu < num_cpus; ++num_cpu ) 00090 { 00091 00092 handleUtils = HandleUtils( 0, cpus[num_cpu] ); 00093 00094 // init these after setting num_cpu, because max id depends on num cpu. 00095 const EntityID ids[] = { 0, 1, handleUtils.max_id() / 2, handleUtils.max_id() - 1, handleUtils.max_id() }; 00096 const TagId tids[] = { 0, 1, MB_TAG_PROP_MASK / 2, MB_TAG_PROP_MASK - 1, MB_TAG_PROP_MASK }; 00097 const int num_ids = sizeof( ids ) / sizeof( ids[0] ); 00098 const int num_tids = sizeof( tids ) / sizeof( tids[0] ); 00099 00100 for( unsigned cpu = 0; cpu < cpus[num_cpu]; ++cpu ) 00101 { 00102 for( EntityType type = MBVERTEX; type < MBMAXTYPE; ++type ) 00103 for( int id = 0; id < num_ids; ++id ) 00104 { 00105 ++tests; 00106 if( !handle_test( type, ids[id], cpu, false ) ) 00107 { 00108 cout << "Test of handle with type=" << type << ", id=" << ids[id] << ", proc=" << cpu 00109 << ", and numproc=" << cpus[num_cpu] << endl; 00110 ++errors; 00111 } 00112 } 00113 00114 for( int prop = 0; prop < num_prop; ++prop ) 00115 for( int id = 0; id < num_tids; ++id ) 00116 { 00117 ++tests; 00118 if( !tag_test( tids[id], (TagType)prop ) ) 00119 { 00120 cout << "Test of tag handle with prop=" << prop << ", id=" << tids[id] << ", proc=" << cpu 00121 << ", and numproc=" << cpus[num_cpu] << endl; 00122 ++errors; 00123 } 00124 } 00125 } 00126 } 00127 00128 // test some stuff that should fail 00129 handleUtils = HandleUtils( 0, 16 ); 00130 ++tests; 00131 if( !handle_test( MBVERTEX, MB_END_ID + 1, 0, true ) ) 00132 { 00133 cout << "Failed to catch ID overflow" << endl; 00134 ++errors; 00135 } 00136 ++tests; 00137 if( !handle_test( (EntityType)( MBMAXTYPE + 1 ), 1, 0, true ) ) 00138 { 00139 cout << "Failed to catch type overflow" << endl; 00140 ++errors; 00141 } 00142 // ++tests; 00143 // if (!handle_test( MBHEX, 1, 17, true)) { 00144 // cout << "Failed to catch Proc# overflow" << endl; 00145 // ++errors; 00146 // } 00147 00148 if( errors ) 00149 cout << endl << errors << " of " << tests << " tests failed." << endl << endl; 00150 else 00151 cout << endl << tests << " tests passed." << endl << endl; 00152 return errors; 00153 }
