MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /* 00002 * IntxRllCssphere_test.cpp 00003 */ 00004 00005 #include "moab/IntxMesh/IntxRllCssphere.hpp" 00006 #include "moab/IntxMesh/IntxUtils.hpp" 00007 #include "TestUtil.hpp" 00008 00009 using namespace moab; 00010 00011 int main( int argc, char* argv[] ) 00012 { 00013 // check command line arg// Euler grid is red, arrival, Lagrangian is blue, departure 00014 // will will keep the 00015 const char* filename_mesh1 = STRINGIFY( MESHDIR ) "/mbcslam/outRLLMesh.g"; 00016 const char* filename_mesh2 = STRINGIFY( MESHDIR ) "/mbcslam/outCSMesh.g"; 00017 double R = 1.; // input 00018 double epsrel = 1.e-8; 00019 const char* newFile = "intx.vtk"; 00020 if( argc == 6 ) 00021 { 00022 filename_mesh1 = argv[1]; 00023 filename_mesh2 = argv[2]; 00024 R = atof( argv[3] ); 00025 epsrel = atof( argv[4] ); 00026 newFile = argv[5]; 00027 } 00028 else 00029 { 00030 printf( "Usage: %s <mesh_filename1> <mesh_filename2> <radius> <epsrel> <newFile>\n", argv[0] ); 00031 if( argc != 1 ) return 1; 00032 printf( "No files specified. Defaulting to: %s %s %f %g %s\n", filename_mesh1, filename_mesh2, R, epsrel, 00033 newFile ); 00034 } 00035 00036 // read meshes in 2 file sets 00037 Core moab; 00038 Interface* mb = &moab; // global 00039 EntityHandle sf1, sf2; 00040 ErrorCode rval = mb->create_meshset( MESHSET_SET, sf1 ); 00041 if( MB_SUCCESS != rval ) return 1; 00042 rval = mb->create_meshset( MESHSET_SET, sf2 ); 00043 if( MB_SUCCESS != rval ) return 1; 00044 rval = mb->load_file( filename_mesh1, &sf1 ); 00045 if( MB_SUCCESS != rval ) return 1; 00046 rval = mb->load_file( filename_mesh2, &sf2 ); 00047 if( MB_SUCCESS != rval ) return 1; 00048 00049 EntityHandle outputSet; 00050 rval = mb->create_meshset( MESHSET_SET, outputSet ); 00051 if( MB_SUCCESS != rval ) return 1; 00052 00053 // IntxUtils 00054 rval = IntxUtils::fix_degenerate_quads( mb, sf1 ); 00055 if( MB_SUCCESS != rval ) return 1; 00056 00057 IntxAreaUtils areaAdaptor; 00058 rval = areaAdaptor.positive_orientation( mb, sf1, R ); 00059 if( MB_SUCCESS != rval ) return 1; 00060 00061 rval = areaAdaptor.positive_orientation( mb, sf2, R ); 00062 if( MB_SUCCESS != rval ) return 1; 00063 00064 /*// set the edge tags on all elements sf1 00065 rval = set_edge_type_flag(mb, sf1); // form all edges, and set on them type 1 if constant 00066 latitude 00067 // add them to the set after this, just so we have them 00068 if (MB_SUCCESS != rval) 00069 return 1;*/ 00070 00071 IntxRllCssphere worker( mb ); 00072 00073 worker.set_error_tolerance( R * epsrel ); 00074 // worker.SetEntityType(moab::MBQUAD); 00075 worker.set_radius( R ); 00076 // worker.enable_debug(); 00077 rval = worker.FindMaxEdges( sf1, sf2 ); 00078 if( MB_SUCCESS != rval ) return 1; 00079 00080 rval = worker.intersect_meshes( sf1, sf2, outputSet ); 00081 // compute total area with 2 methods 00082 00083 if( MB_SUCCESS != rval ) std::cout << " failed to intersect meshes\n"; 00084 rval = mb->write_mesh( newFile, &outputSet, 1 ); 00085 if( MB_SUCCESS != rval ) return 1; 00086 return 0; 00087 }
