MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 #include <iostream> 00002 #include "moab/Interface.hpp" 00003 #ifndef IS_BUILDING_MB 00004 #define IS_BUILDING_MB 00005 #endif 00006 #include "TestUtil.hpp" 00007 #include "Internals.hpp" 00008 #include "moab/Core.hpp" 00009 00010 using namespace moab; 00011 00012 #define CHKERR( A ) \ 00013 do \ 00014 { \ 00015 if( MB_SUCCESS != ( A ) ) \ 00016 { \ 00017 std::cerr << "Failure (error code " << ( A ) << ") at " __FILE__ ":" << __LINE__ << std::endl; \ 00018 return A; \ 00019 } \ 00020 } while( false ) 00021 00022 #ifdef HAVE_OCC_STEP 00023 std::string input_file = TestDir + "unittest/io/dum.stp"; 00024 #else 00025 std::string input_file = TestDir + "unittest/io/dum.sat"; 00026 #endif 00027 00028 // Checks that a file can be loaded twice without errors 00029 void read_multiple_test() 00030 { 00031 Core mb; 00032 00033 ErrorCode rval = mb.load_file( input_file.c_str() );CHECK_ERR( rval ); 00034 // second load 00035 rval = mb.load_file( input_file.c_str() );CHECK_ERR( rval ); 00036 } 00037 00038 int main( int /* argc */, char** /* argv */ ) 00039 { 00040 int result = RUN_TEST( read_multiple_test ); 00041 00042 return result; 00043 }
