MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /** 00002 * MOAB, a Mesh-Oriented datABase, is a software component for creating, 00003 * storing and accessing finite element mesh data. 00004 * 00005 * Copyright 2004 Sandia Corporation. Under the terms of Contract 00006 * DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government 00007 * retains certain rights in this software. 00008 * 00009 * This library is free software; you can redistribute it and/or 00010 * modify it under the terms of the GNU Lesser General Public 00011 * License as published by the Free Software Foundation; either 00012 * version 2.1 of the License, or (at your option) any later version. 00013 * 00014 */ 00015 00016 #include "ScdVertexSeq.hpp" 00017 #include "ScdElementSeq.hpp" 00018 #include "EntitySequenceManager.hpp" 00019 #include "EntitySequence.hpp" 00020 #include "moab/Core.hpp" 00021 #include "moab/ReadUtilIface.hpp" 00022 00023 #include <iostream> 00024 #include <ctime> 00025 00026 using namespace moab; 00027 00028 /* 00029 // some timing/memory measurement includes; memory measurement 00030 // doesn't work on linux, so they're commented out for now to avoid 00031 // platform problems 00032 #include <unistd.h> 00033 #include <termios.h> 00034 #include <sys/ioctl.h> 00035 #include <ctype.h> 00036 #include <sys/resource.h> 00037 #include <sys/types.h> 00038 #include <sys/stat.h> 00039 #include <fcntl.h> 00040 */ 00041 00042 int create_3dtri_3_sequences( Core* gMB, const int intervals, EntityHandle* vstart, EntityHandle* estart ); 00043 int create_3dtri_ucd_sequences( Core* gMB, const int intervals, EntityHandle* vstart, EntityHandle* estart ); 00044 void print_time(); 00045 00046 int main( int argc, char** argv ) 00047 { 00048 int errors = 0; 00049 00050 // first we need to make a new Core 00051 Core* gMB = new Core(); 00052 00053 // get the intervals 00054 if( argc < 2 ) 00055 { 00056 std::cout << "Usage: <scdseq_timing> <#intervals> " << std::endl 00057 << " where #intervals is the number of intervals on each side of each cube." << std::endl; 00058 return 0; 00059 } 00060 00061 int intervals; 00062 sscanf( argv[1], "%d", &intervals ); 00063 00064 char do_option[8]; 00065 00066 bool do_scd = true, do_ucd = true; 00067 00068 if( argc > 2 ) 00069 { 00070 sscanf( argv[2], "%s", do_option ); 00071 if( do_option[0] == 'u' ) 00072 do_scd = false; 00073 else if( do_option[0] == 's' ) 00074 do_ucd = false; 00075 else 00076 { 00077 std::cout << "Didn't understand input; doing both scd and ucd." << std::endl; 00078 } 00079 } 00080 00081 EntityHandle estart[3], vstart[3]; 00082 int total_elements = intervals * intervals * intervals; 00083 std::vector< EntityHandle > connect; 00084 ErrorCode result; 00085 clock_t start, stop; 00086 float time; 00087 char inp[1]; 00088 00089 // wait for input to get memory reading 00090 std::cout << "Hit any key and return to continue..."; 00091 std::cin >> inp; 00092 std::cout << std::endl; 00093 00094 if( do_scd ) 00095 { 00096 00097 // create structured mesh 00098 errors = create_3dtri_3_sequences( gMB, intervals, vstart, estart ); 00099 if( errors != 0 ) 00100 { 00101 std::cout << "Problem creating structured sequences." << std::endl; 00102 return errors; 00103 } 00104 00105 // get connectivity 00106 00107 start = clock(); 00108 for( int j = 0; j < 3; j++ ) 00109 { 00110 for( int i = 0; i < total_elements; i++ ) 00111 { 00112 result = gMB->get_connectivity( estart[j] + i, connect ); 00113 if( MB_SUCCESS != result ) break; 00114 connect.clear(); 00115 } 00116 } 00117 stop = clock(); 00118 time = static_cast< float >( stop - start ) / CLOCKS_PER_SEC; 00119 00120 std::cout << "Time to get connectivity for scd mesh of " << 3 * total_elements << " elements: " << time 00121 << " seconds." << std::endl; 00122 00123 print_time(); 00124 // wait for input to get memory reading 00125 std::cout << "Hit any key and return to continue..."; 00126 std::cin >> inp; 00127 std::cout << std::endl; 00128 00129 // destroy this mesh 00130 delete gMB; 00131 } 00132 00133 if( do_ucd ) 00134 { 00135 00136 // now do the same thing, only unstructured 00137 gMB = new Core(); 00138 00139 // create the elements 00140 errors = create_3dtri_ucd_sequences( gMB, intervals, vstart, estart ); 00141 if( errors != 0 ) 00142 { 00143 std::cout << "Problem creating unstructured sequences." << std::endl; 00144 return errors; 00145 } 00146 00147 // get connectivity 00148 std::vector< EntityHandle > connect; 00149 start = clock(); 00150 for( int j = 0; j < 3; j++ ) 00151 { 00152 for( int i = 0; i < total_elements; i++ ) 00153 { 00154 result = gMB->get_connectivity( estart[j] + i, connect ); 00155 if( MB_SUCCESS != result ) break; 00156 connect.clear(); 00157 } 00158 } 00159 stop = clock(); 00160 time = static_cast< float >( stop - start ) / CLOCKS_PER_SEC; 00161 00162 std::cout << "Time to get connectivity for ucd mesh of " << 3 * total_elements << " elements: " << time 00163 << " seconds." << std::endl; 00164 00165 print_time(); 00166 // wait for input to get memory reading 00167 std::cout << "Hit any key and return to continue..."; 00168 std::cin >> inp; 00169 std::cout << std::endl; 00170 00171 // destroy this mesh 00172 delete gMB; 00173 } 00174 } 00175 00176 int create_3dtri_3_sequences( Core* gMB, const int intervals, EntityHandle* vstart, EntityHandle* estart ) 00177 { 00178 // create 3 brick esequences arranged such that the all share a common (tri-valent) edge; 00179 // orient each region similarly to the 2dtri_3_esequences test problem, swept into 3d in the 00180 // positive k direction. This direction is divided into intervals intervals 00181 // 00182 // intervals and intervals controls the i and j intervals in region 0, intervals follows from 00183 // that; intervals divides the k axis 00184 00185 // input is 4 interval settings controlling the 4 degrees of freedom on the interfacesp 00186 int errors = 0; 00187 00188 ScdVertexSeq* vseq[3]; 00189 ScdElementSeq* eseq[3]; 00190 00191 // set vseq parametric spaces directly from intervals-4 00192 // use 0-based parameterization on vseq's just for fun, which means we'll have to transform into 00193 // eseq system 00194 HomCoord vseq0_minmax[2] = { HomCoord( 0, 0, 0 ), HomCoord( intervals, intervals, intervals ) }; 00195 HomCoord vseq1_minmax[2] = { HomCoord( 0, 0, 0 ), HomCoord( intervals - 1, intervals, intervals ) }; 00196 HomCoord vseq2_minmax[2] = { HomCoord( 0, 0, 0 ), HomCoord( intervals - 1, intervals - 1, intervals ) }; 00197 00198 // get the seq manager from gMB 00199 EntitySequenceManager* seq_mgr = gMB->sequence_manager(); 00200 00201 // create three vertex sequences 00202 EntitySequence* dum_seq; 00203 vseq[0] = vseq[1] = vseq[2] = NULL; 00204 00205 // first vertex sequence 00206 ErrorCode result = 00207 seq_mgr->create_scd_sequence( vseq0_minmax[0], vseq0_minmax[1], MBVERTEX, 1, vstart[0], dum_seq ); 00208 if( NULL != dum_seq ) vseq[0] = dynamic_cast< ScdVertexSeq* >( dum_seq ); 00209 assert( MB_FAILURE != result && vstart[0] != 0 && dum_seq != NULL && vseq[0] != NULL ); 00210 00211 // second vertex sequence 00212 result = seq_mgr->create_scd_sequence( vseq1_minmax[0], vseq1_minmax[1], MBVERTEX, 1, vstart[1], dum_seq ); 00213 if( NULL != dum_seq ) vseq[1] = dynamic_cast< ScdVertexSeq* >( dum_seq ); 00214 assert( MB_FAILURE != result && vstart[1] != 0 && dum_seq != NULL && vseq[1] != NULL ); 00215 00216 // third vertex sequence 00217 result = seq_mgr->create_scd_sequence( vseq2_minmax[0], vseq2_minmax[1], MBVERTEX, 1, vstart[2], dum_seq ); 00218 if( NULL != dum_seq ) vseq[2] = dynamic_cast< ScdVertexSeq* >( dum_seq ); 00219 assert( MB_FAILURE != result && vstart[2] != 0 && dum_seq != NULL && vseq[2] != NULL ); 00220 00221 // now create the three element sequences 00222 00223 // set eseq parametric spaces directly from intervals-4 00224 // use 0-based parameterization on eseq's just for fun, which means we'll have to transform into 00225 // eseq system 00226 HomCoord eseq0_minmax[2] = { HomCoord( 0, 0, 0 ), HomCoord( intervals, intervals, intervals ) }; 00227 HomCoord eseq1_minmax[2] = { HomCoord( 0, 0, 0 ), HomCoord( intervals, intervals, intervals ) }; 00228 HomCoord eseq2_minmax[2] = { HomCoord( 0, 0, 0 ), HomCoord( intervals, intervals, intervals ) }; 00229 00230 eseq[0] = eseq[1] = eseq[2] = NULL; 00231 00232 // create the first element sequence 00233 result = seq_mgr->create_scd_sequence( eseq0_minmax[0], eseq0_minmax[1], MBHEX, 1, estart[0], dum_seq ); 00234 if( NULL != dum_seq ) eseq[0] = dynamic_cast< ScdElementSeq* >( dum_seq ); 00235 assert( MB_FAILURE != result && estart[0] != 0 && dum_seq != NULL && eseq[0] != NULL ); 00236 00237 // only need to add one vseq to this, unity transform 00238 result = eseq[0]->add_vsequence( vseq[0], 00239 // trick: if I know it's going to be unity, just input 00240 // 3 sets of equivalent points 00241 vseq0_minmax[0], vseq0_minmax[0], vseq0_minmax[0], vseq0_minmax[0], 00242 vseq0_minmax[0], vseq0_minmax[0] ); 00243 00244 if( MB_SUCCESS != result ) 00245 { 00246 std::cout << "Couldn't add first vsequence to first element sequence in tri-composite 3d eseq." << std::endl; 00247 errors++; 00248 } 00249 00250 // create the second element sequence 00251 result = seq_mgr->create_scd_sequence( eseq1_minmax[0], eseq1_minmax[1], MBHEX, 1, estart[1], dum_seq ); 00252 if( NULL != dum_seq ) eseq[1] = dynamic_cast< ScdElementSeq* >( dum_seq ); 00253 assert( MB_FAILURE != result && estart[1] != 0 && dum_seq != NULL && eseq[1] != NULL ); 00254 00255 // add shared side from first vseq to this eseq, with bb to get just the face 00256 result = eseq[1]->add_vsequence( vseq[0], 00257 // p1: origin in both systems 00258 vseq0_minmax[0], eseq0_minmax[0], 00259 // p2: one unit along the shared line (i in one, j in other) 00260 vseq0_minmax[0] + HomCoord::unitv[0], eseq0_minmax[0] + HomCoord::unitv[1], 00261 // p3: arbitrary 00262 vseq0_minmax[0], eseq0_minmax[0], 00263 // set bb such that it's the jmin side of vseq 00264 true, eseq[1]->min_params(), 00265 HomCoord( eseq[1]->min_params().i(), eseq[1]->max_params().j(), 00266 eseq[1]->max_params().k() ) ); 00267 if( MB_SUCCESS != result ) 00268 { 00269 std::cout << "Couldn't add shared vsequence to second element sequence in tri-composite 3d eseq." << std::endl; 00270 errors++; 00271 } 00272 00273 // add second vseq to this eseq, with different orientation but all of it (no bb input) 00274 result = 00275 eseq[1]->add_vsequence( vseq[1], 00276 // p1: origin/i+1 (vseq/eseq) 00277 vseq1_minmax[0], eseq1_minmax[0] + HomCoord::unitv[0], 00278 // p2: j+1 from p1 00279 vseq1_minmax[0] + HomCoord::unitv[1], 00280 eseq1_minmax[0] + HomCoord::unitv[0] + HomCoord::unitv[1], 00281 // p3: i+1 from p1 00282 vseq1_minmax[0] + HomCoord::unitv[0], eseq[1]->min_params() + HomCoord::unitv[0] * 2 ); 00283 if( MB_SUCCESS != result ) 00284 { 00285 std::cout << "Couldn't add second vseq to second element sequence in tri-composite 3d eseq." << std::endl; 00286 errors++; 00287 } 00288 00289 // create the third element sequence 00290 result = seq_mgr->create_scd_sequence( eseq2_minmax[0], eseq2_minmax[1], MBHEX, 1, estart[2], dum_seq ); 00291 if( NULL != dum_seq ) eseq[2] = dynamic_cast< ScdElementSeq* >( dum_seq ); 00292 assert( MB_FAILURE != result && estart[2] != 0 && dum_seq != NULL && eseq[2] != NULL ); 00293 00294 // add shared side from second vseq to this eseq 00295 result = eseq[2]->add_vsequence( 00296 vseq[1], 00297 // p1: origin/j+1 (vseq/eseq) 00298 vseq1_minmax[0], eseq[2]->min_params() + HomCoord::unitv[1], 00299 // p2: i+1/j+2 (vseq/eseq) 00300 vseq1_minmax[0] + HomCoord::unitv[0], eseq[2]->min_params() + HomCoord::unitv[1] * 2, 00301 // p3: arbitrary 00302 vseq1_minmax[0], eseq[2]->min_params() + HomCoord::unitv[1], 00303 // bb input such that we only get one side of eseq parameter space 00304 true, eseq[2]->min_params() + HomCoord::unitv[1], 00305 HomCoord( eseq[2]->min_params().i(), eseq[2]->max_params().j(), eseq[2]->max_params().k() ) ); 00306 if( MB_SUCCESS != result ) 00307 { 00308 std::cout << "Couldn't add shared vsequence to third element sequence in tri-composite 3d eseq." << std::endl; 00309 errors++; 00310 } 00311 00312 // add shared side from first vseq to this eseq 00313 result = eseq[2]->add_vsequence( vseq[0], 00314 // p1: origin/origin 00315 vseq1_minmax[0], eseq2_minmax[0], 00316 // p2: j+1/i+1 00317 vseq1_minmax[0] + HomCoord::unitv[1], eseq2_minmax[0] + HomCoord::unitv[0], 00318 // p3: arbitrary 00319 vseq1_minmax[0], eseq2_minmax[0], 00320 // bb input such that we only get one side of eseq parameter space 00321 true, eseq2_minmax[0], 00322 HomCoord( eseq2_minmax[1].i(), eseq2_minmax[0].j(), eseq2_minmax[1].k() ) ); 00323 if( MB_SUCCESS != result ) 00324 { 00325 std::cout << "Couldn't add left shared vsequence to third element sequence in " 00326 "tri-composite 3d eseq." 00327 << std::endl; 00328 errors++; 00329 } 00330 00331 // add third vseq to this eseq 00332 result = eseq[2]->add_vsequence( vseq[2], 00333 // p1: origin/i+1,j+1 00334 vseq2_minmax[0], eseq[2]->min_params() + HomCoord::unitv[0] + HomCoord::unitv[1], 00335 // p2: i+1 from p1 00336 vseq2_minmax[0] + HomCoord::unitv[0], 00337 eseq[2]->min_params() + HomCoord::unitv[0] * 2 + HomCoord::unitv[1], 00338 // p3: j+1 from p1 00339 vseq2_minmax[0] + HomCoord::unitv[1], 00340 eseq[2]->min_params() + HomCoord::unitv[0] + HomCoord::unitv[1] * 2 ); 00341 if( MB_SUCCESS != result ) 00342 { 00343 std::cout << "Couldn't add third vseq to third element sequence in tri-composite 3d eseq." << std::endl; 00344 errors++; 00345 } 00346 00347 return errors; 00348 } 00349 00350 int create_3dtri_ucd_sequences( Core* gMB, const int intervals, EntityHandle* vstart, EntityHandle* estart ) 00351 { 00352 00353 ReadUtilIface* readMeshIface; 00354 gMB->query_interface( readMeshIface ); 00355 00356 int num_elements = intervals * intervals * intervals; 00357 int num_verts = ( intervals + 1 ) * ( intervals + 1 ) * ( intervals + 1 ); 00358 00359 std::vector< double* > arrays; 00360 for( int i = 0; i < 3; i++ ) 00361 { 00362 readMeshIface->get_node_coords( 3, num_verts, MB_START_ID, vstart[i], arrays ); 00363 arrays.clear(); 00364 } 00365 00366 EntityHandle* conn[3]; 00367 00368 // allocate 3 arrays to initialize connectivity data 00369 for( int i = 0; i < 3; i++ ) 00370 { 00371 readMeshIface->get_element_connect( num_elements, 8, MBHEX, 1, estart[i], conn[i] ); 00372 00373 // now, initialize connectivity data to what it should be; just fudge for now 00374 for( int j = 0; j < num_elements * 8; j++ ) 00375 conn[i][j] = vstart[i]; 00376 } 00377 00378 return 0; 00379 } 00380 00381 void print_time() 00382 { 00383 /* 00384 struct rusage r_usage; 00385 float utime, stime; 00386 getrusage(RUSAGE_SELF, &r_usage); 00387 00388 if (r_usage.ru_maxrss == 0) { 00389 // this machine doesn't return rss - try going to /proc 00390 // print the file name to open 00391 char file_str[4096], dum_str[4096]; 00392 int file_ptr = -1, file_len; 00393 file_ptr = open("/proc/self/stat", O_RDONLY); 00394 file_len = read(file_ptr, file_str, sizeof(file_str)-1); 00395 if (file_len == 0) return; 00396 close(file_ptr); 00397 file_str[file_len] = '\0'; 00398 // read the preceeding fields and the ones we really want... 00399 int dum_int; 00400 unsigned int dum_uint, vm_size, rss; 00401 static int page_size = getpagesize(); 00402 int num_fields = sscanf(file_str, 00403 "%d " // pid 00404 "%s " // comm 00405 "%c " // state 00406 "%d %d %d %d %d " // ppid, pgrp, session, tty, tpgid 00407 "%u %u %u %u %u " // flags, minflt, cminflt, majflt, cmajflt 00408 "%d %d %d %d %d %d " // utime, stime, cutime, cstime, counter, 00409 priority 00410 "%u %u " // timeout, itrealvalue 00411 "%d " // starttime 00412 "%u %u", // vsize, rss 00413 &dum_int, 00414 dum_str, 00415 dum_str, 00416 &dum_int, &dum_int, &dum_int, &dum_int, &dum_int, 00417 &dum_uint, &dum_uint, &dum_uint, &dum_uint, &dum_uint, 00418 &dum_int, &dum_int, &dum_int, &dum_int, &dum_int, &dum_int, 00419 &dum_uint, &dum_uint, 00420 &dum_int, 00421 &vm_size, &rss); 00422 if (num_fields == 24) { 00423 r_usage.ru_maxrss = rss/page_size; 00424 r_usage.ru_idrss = vm_size/page_size; 00425 } 00426 } 00427 utime = (float)r_usage.ru_utime.tv_sec + 00428 ((float)r_usage.ru_utime.tv_usec/1.e6); 00429 stime = (float)r_usage.ru_stime.tv_sec + 00430 ((float)r_usage.ru_stime.tv_usec/1.e6); 00431 static int pagesize = getpagesize(); 00432 00433 std::cout << "Execution time = " << utime+stime << ", max RSS = " 00434 << r_usage.ru_maxrss*pagesize << " bytes." << std::endl; 00435 00436 */ 00437 }
