MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 #include "TestUtil.hpp" 00002 #include "moab/Core.hpp" 00003 #define IS_BUILDING_MB 00004 #include "moab/Range.hpp" 00005 00006 using namespace moab; 00007 00008 #ifdef MESHDIR 00009 static const char example[] = STRINGIFY( MESHDIR ) "/io/three.smf"; 00010 #else 00011 static const char example[] = "three.smf"; 00012 #endif 00013 00014 void read_file( Interface& moab, const char* input_file ); 00015 void test_read_nodes(); 00016 void test_read_triangles(); 00017 00018 int main() 00019 { 00020 int result = 0; 00021 00022 result += RUN_TEST( test_read_nodes ); 00023 result += RUN_TEST( test_read_triangles ); 00024 00025 return result; 00026 } 00027 00028 void read_file( Interface& moab, const char* input_file ) 00029 { 00030 ErrorCode rval = moab.load_file( input_file );CHECK_ERR( rval ); 00031 } 00032 00033 void test_read_nodes() 00034 { 00035 const double eps = 1e-10; 00036 ErrorCode rval; 00037 Core moab; 00038 Interface& mb = moab; 00039 read_file( moab, example ); 00040 00041 std::vector< EntityHandle > nodes; 00042 rval = mb.get_entities_by_type( 0, MBVERTEX, nodes );CHECK_ERR( rval ); 00043 CHECK_EQUAL( (size_t)24, nodes.size() ); 00044 00045 std::vector< double > coords( 3 * nodes.size() ); 00046 rval = mb.get_coords( &nodes[0], nodes.size(), &coords[0] );CHECK_ERR( rval ); 00047 00048 int idx = 0; 00049 CHECK_REAL_EQUAL( coords[3 * idx + 0], 0.0, eps ); 00050 CHECK_REAL_EQUAL( coords[3 * idx + 1], 0.0, eps ); 00051 CHECK_REAL_EQUAL( coords[3 * idx + 2], 0.0, eps ); 00052 00053 ++idx; 00054 CHECK_REAL_EQUAL( coords[3 * idx + 0], 1.0, eps ); 00055 CHECK_REAL_EQUAL( coords[3 * idx + 1], 0.0, eps ); 00056 CHECK_REAL_EQUAL( coords[3 * idx + 2], 0.0, eps ); 00057 00058 idx = 8; // second cube 00059 CHECK_REAL_EQUAL( coords[3 * idx + 0], 1.2, eps ); 00060 CHECK_REAL_EQUAL( coords[3 * idx + 1], 0.0, eps ); 00061 CHECK_REAL_EQUAL( coords[3 * idx + 2], 0.0, eps ); 00062 00063 idx = 15; // last node of second cube 00064 CHECK_REAL_EQUAL( coords[3 * idx + 0], 2.2, eps ); 00065 CHECK_REAL_EQUAL( coords[3 * idx + 1], 1.0, eps ); 00066 CHECK_REAL_EQUAL( coords[3 * idx + 2], 1.0, eps ); 00067 00068 idx = 16; // first node of third cube 00069 CHECK_REAL_EQUAL( coords[3 * idx + 0], -1.2, eps ); 00070 CHECK_REAL_EQUAL( coords[3 * idx + 1], 0.5, eps ); 00071 CHECK_REAL_EQUAL( coords[3 * idx + 2], -0.2071067812, eps ); 00072 } 00073 00074 void test_read_triangles() 00075 { 00076 ErrorCode rval; 00077 Core moab; 00078 Interface& mb = moab; 00079 read_file( moab, example ); 00080 00081 std::vector< EntityHandle > triangles; 00082 rval = mb.get_entities_by_type( 0, MBTRI, triangles );CHECK_ERR( rval ); 00083 CHECK_EQUAL( (size_t)36, triangles.size() ); 00084 00085 int vtx_ids[3]; 00086 const EntityHandle* conn; 00087 int len; 00088 00089 const int conn1[] = { 1, 4, 2 }; 00090 int pos = 0; 00091 rval = mb.get_connectivity( triangles[pos], conn, len );CHECK_ERR( rval ); 00092 CHECK_EQUAL( 3, len ); 00093 int i = 0; 00094 for( i = 0; i < 3; i++ ) 00095 vtx_ids[i] = mb.id_from_handle( conn[i] ); 00096 CHECK_ARRAYS_EQUAL( conn1, 3, vtx_ids, len ); 00097 00098 // last triangle 00099 const int conn2[] = { 19, 21, 23 }; 00100 rval = mb.get_connectivity( triangles[35], conn, len );CHECK_ERR( rval ); 00101 CHECK_EQUAL( 3, len ); 00102 for( i = 0; i < 3; i++ ) 00103 vtx_ids[i] = mb.id_from_handle( conn[i] ); 00104 CHECK_ARRAYS_EQUAL( conn2, 3, vtx_ids, len ); 00105 }
