MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /** 00002 * @file Read and distribute mapping weights to multiple processes 00003 * @author Vijay Mahadevan ([email protected]) 00004 * @brief 00005 * @version 0.1 00006 * @date 2020-07-13 00007 * 00008 */ 00009 00010 #include <iostream> 00011 #include <vector> 00012 #include "moab/Core.hpp" 00013 00014 #ifndef MOAB_HAVE_TEMPESTREMAP 00015 #error Need TempestRemap dependency for this test 00016 #endif 00017 00018 #include "OfflineMap.h" 00019 #include "moab/Remapping/TempestRemapper.hpp" 00020 #include "moab/Remapping/TempestOnlineMap.hpp" 00021 #include "moab/ParallelComm.hpp" 00022 00023 #ifndef IS_BUILDING_MB 00024 #define IS_BUILDING_MB 00025 #endif 00026 00027 #include "Internals.hpp" 00028 #include "TestRunner.hpp" 00029 00030 #include <netcdf.h> 00031 #include <netcdf_par.h> 00032 00033 using namespace moab; 00034 00035 std::string inMapFilename = ""; 00036 00037 void test_tempest_map_bcast(); 00038 void read_buffered_map(); 00039 void read_map_from_disk(); 00040 00041 int main( int argc, char** argv ) 00042 { 00043 if( argc > 1 ) 00044 inMapFilename = std::string( argv[1] ); 00045 else 00046 inMapFilename = TestDir + "unittest/outCS5ICOD5_map.nc"; 00047 00048 REGISTER_TEST( test_tempest_map_bcast ); 00049 REGISTER_TEST( read_buffered_map ); 00050 REGISTER_TEST( read_map_from_disk ); 00051 00052 #ifdef MOAB_HAVE_MPI 00053 MPI_Init( &argc, &argv ); 00054 #endif 00055 int result = RUN_TESTS( argc, argv ); 00056 #ifdef MOAB_HAVE_MPI 00057 MPI_Finalize(); 00058 #endif 00059 return result; 00060 } 00061 00062 #define NCERROREXIT( err, MSG ) \ 00063 if( err ) \ 00064 { \ 00065 std::cout << "Error (" << ( err ) << "): " << ( MSG ); \ 00066 std::cout << "\nAborting with message: " << nc_strerror( err ) << "... \n"; \ 00067 return; \ 00068 } 00069 00070 void read_buffered_map() 00071 { 00072 NcError error( NcError::silent_nonfatal ); 00073 00074 // Define our total buffer size to use 00075 NcFile* ncMap = NULL; 00076 NcVar *varRow = NULL, *varCol = NULL, *varS = NULL; 00077 00078 #ifdef MOAB_HAVE_MPI 00079 int mpierr = 0; 00080 const int rootProc = 0; 00081 #endif 00082 // Main inputs; 00083 // 1. Map Filename 00084 // 2. Ownership info from the processes to be gathered on root 00085 const int nBufferSize = 64 * 1024; // 64 KB 00086 const int nNNZBytes = 2 * sizeof( int ) + sizeof( double ); 00087 const int nMaxEntries = nBufferSize / nNNZBytes; 00088 int nA = 0, nB = 0, nVA = 0, nVB = 0, nS = 0; 00089 double dTolerance = 1e-08; 00090 00091 int nprocs = 1, rank = 0; 00092 #ifdef MOAB_HAVE_MPI 00093 MPI_Comm commW = MPI_COMM_WORLD; 00094 MPI_Comm_size( commW, &nprocs ); 00095 MPI_Comm_rank( commW, &rank ); 00096 #endif 00097 00098 #ifdef MOAB_HAVE_MPI 00099 if( rank == rootProc ) 00100 #endif 00101 { 00102 ncMap = new NcFile( inMapFilename.c_str(), NcFile::ReadOnly ); 00103 if( !ncMap->is_valid() ) 00104 { 00105 _EXCEPTION1( "Unable to open input map file \"%s\"", inMapFilename.c_str() ); 00106 } 00107 00108 // Source and Target mesh resolutions 00109 NcDim* dimNA = ncMap->get_dim( "n_a" ); 00110 if( dimNA == NULL ) 00111 { 00112 _EXCEPTIONT( "Input map missing dimension \"n_a\"" ); 00113 } 00114 else 00115 nA = dimNA->size(); 00116 00117 NcDim* dimNB = ncMap->get_dim( "n_b" ); 00118 if( dimNB == NULL ) 00119 { 00120 _EXCEPTIONT( "Input map missing dimension \"n_b\"" ); 00121 } 00122 else 00123 nB = dimNB->size(); 00124 00125 NcDim* dimNVA = ncMap->get_dim( "nv_a" ); 00126 if( dimNVA == NULL ) 00127 { 00128 _EXCEPTIONT( "Input map missing dimension \"nv_a\"" ); 00129 } 00130 else 00131 nVA = dimNVA->size(); 00132 00133 NcDim* dimNVB = ncMap->get_dim( "nv_b" ); 00134 if( dimNVB == NULL ) 00135 { 00136 _EXCEPTIONT( "Input map missing dimension \"nv_b\"" ); 00137 } 00138 else 00139 nVB = dimNVB->size(); 00140 00141 // Read SparseMatrix entries 00142 NcDim* dimNS = ncMap->get_dim( "n_s" ); 00143 if( dimNS == NULL ) 00144 { 00145 _EXCEPTION1( "Map file \"%s\" does not contain dimension \"n_s\"", inMapFilename.c_str() ); 00146 } 00147 else 00148 nS = dimNS->size(); // store total number of nonzeros 00149 00150 varRow = ncMap->get_var( "row" ); 00151 if( varRow == NULL ) 00152 { 00153 _EXCEPTION1( "Map file \"%s\" does not contain variable \"row\"", inMapFilename.c_str() ); 00154 } 00155 00156 varCol = ncMap->get_var( "col" ); 00157 if( varCol == NULL ) 00158 { 00159 _EXCEPTION1( "Map file \"%s\" does not contain variable \"col\"", inMapFilename.c_str() ); 00160 } 00161 00162 varS = ncMap->get_var( "S" ); 00163 if( varS == NULL ) 00164 { 00165 _EXCEPTION1( "Map file \"%s\" does not contain variable \"S\"", inMapFilename.c_str() ); 00166 } 00167 } 00168 00169 // const int nTotalBytes = nS * nNNZBytes; 00170 int nEntriesRemaining = nS; 00171 int nBufferedReads = static_cast< int >( ceil( ( 1.0 * nS ) / ( 1.0 * nMaxEntries ) ) ); 00172 int runData[6] = { nA, nB, nVA, nVB, nS, nBufferedReads }; 00173 00174 mpierr = MPI_Bcast( runData, 6, MPI_INT, rootProc, commW ); 00175 CHECK_EQUAL( mpierr, 0 ); 00176 00177 #ifdef MOAB_HAVE_MPI 00178 if( rank != rootProc ) 00179 { 00180 nA = runData[0]; 00181 nB = runData[1]; 00182 nVA = runData[2]; 00183 nVB = runData[3]; 00184 nS = runData[4]; 00185 nBufferedReads = runData[5]; 00186 } 00187 else 00188 printf( "Global parameters: nA = %d, nB = %d, nS = %d\n", nA, nB, nS ); 00189 #else 00190 printf( "Global parameters: nA = %d, nB = %d, nS = %d\n", nA, nB, nS ); 00191 #endif 00192 00193 std::vector< int > rowOwnership( nprocs ); 00194 int nGRowPerPart = nB / nprocs; 00195 int nGRowRemainder = nB % nprocs; // Keep the remainder in root 00196 rowOwnership[0] = nGRowPerPart + nGRowRemainder; 00197 for( int ip = 1, roffset = rowOwnership[0]; ip < nprocs; ++ip ) 00198 { 00199 roffset += nGRowPerPart; 00200 rowOwnership[ip] = roffset; 00201 } 00202 00203 // Let us declare the map object for every process 00204 OfflineMap mapRemap; 00205 SparseMatrix< double >& sparseMatrix = mapRemap.GetSparseMatrix(); 00206 00207 #ifdef MOAB_HAVE_MPI 00208 if( rank == rootProc ) 00209 #endif 00210 printf( "Parameters: nA=%d, nB=%d, nVA=%d, nVB=%d, nS=%d, nNNZBytes = %d, nBufferedReads = %d\n", nA, nB, nVA, 00211 nVB, nS, nNNZBytes, nBufferedReads ); 00212 00213 std::map< int, int > rowMap, colMap; 00214 int rindexMax = 0, cindexMax = 0; 00215 long offset = 0; 00216 00217 /* Split the rows and send to processes in chunks 00218 Let us start the buffered read */ 00219 for( int iRead = 0; iRead < nBufferedReads; ++iRead ) 00220 { 00221 // pointers to the data 00222 DataArray1D< int > vecRow; 00223 DataArray1D< int > vecCol; 00224 DataArray1D< double > vecS; 00225 std::vector< std::vector< int > > dataPerProcess( nprocs ); 00226 std::vector< int > nDataPerProcess( nprocs, 0 ); 00227 for( int ip = 0; ip < nprocs; ++ip ) 00228 dataPerProcess[ip].reserve( std::max( 100, nMaxEntries / nprocs ) ); 00229 00230 #ifdef MOAB_HAVE_MPI 00231 if( rank == rootProc ) 00232 #endif 00233 { 00234 int nLocSize = std::min( nEntriesRemaining, static_cast< int >( ceil( nBufferSize * 1.0 / nNNZBytes ) ) ); 00235 00236 printf( "Reading file: elements %ld to %ld\n", offset, offset + nLocSize ); 00237 00238 // Allocate and resize based on local buffer size 00239 vecRow.Allocate( nLocSize ); 00240 vecCol.Allocate( nLocSize ); 00241 vecS.Allocate( nLocSize ); 00242 00243 varRow->set_cur( (long)( offset ) ); 00244 varRow->get( &( vecRow[0] ), nLocSize ); 00245 00246 varCol->set_cur( (long)( offset ) ); 00247 varCol->get( &( vecCol[0] ), nLocSize ); 00248 00249 varS->set_cur( (long)( offset ) ); 00250 varS->get( &( vecS[0] ), nLocSize ); 00251 00252 // Decrement vecRow and vecCol 00253 for( size_t i = 0; i < vecRow.GetRows(); i++ ) 00254 { 00255 vecRow[i]--; 00256 vecCol[i]--; 00257 00258 // TODO: Fix this linear search to compute process ownership 00259 int pOwner = -1; 00260 if( rowOwnership[0] > vecRow[i] ) 00261 pOwner = 0; 00262 else 00263 { 00264 for( int ip = 1; ip < nprocs; ++ip ) 00265 { 00266 if( rowOwnership[ip - 1] <= vecRow[i] && rowOwnership[ip] > vecRow[i] ) 00267 { 00268 pOwner = ip; 00269 break; 00270 } 00271 } 00272 } 00273 00274 assert( pOwner >= 0 && pOwner < nprocs ); 00275 dataPerProcess[pOwner].push_back( i ); 00276 } 00277 00278 offset += nLocSize; 00279 nEntriesRemaining -= nLocSize; 00280 00281 for( int ip = 0; ip < nprocs; ++ip ) 00282 nDataPerProcess[ip] = dataPerProcess[ip].size(); 00283 } 00284 00285 // Communicate the number of DoF data to expect from root 00286 int nEntriesComm = 0; 00287 mpierr = MPI_Scatter( nDataPerProcess.data(), 1, MPI_INT, &nEntriesComm, 1, MPI_INT, rootProc, commW ); 00288 CHECK_EQUAL( mpierr, 0 ); 00289 00290 #ifdef MOAB_HAVE_MPI 00291 if( rank == rootProc ) 00292 #endif 00293 { 00294 std::vector< MPI_Request > cRequests; 00295 std::vector< MPI_Status > cStats( 2 * nprocs - 2 ); 00296 cRequests.reserve( 2 * nprocs - 2 ); 00297 00298 // First send out all the relevant data buffers to other process 00299 std::vector< std::vector< int > > dataRowColsAll( nprocs ); 00300 std::vector< std::vector< double > > dataEntriesAll( nprocs ); 00301 for( int ip = 1; ip < nprocs; ++ip ) 00302 { 00303 const int nDPP = nDataPerProcess[ip]; 00304 if( nDPP > 0 ) 00305 { 00306 std::vector< int >& dataRowCols = dataRowColsAll[ip]; 00307 dataRowCols.resize( 2 * nDPP ); 00308 std::vector< double >& dataEntries = dataEntriesAll[ip]; 00309 dataEntries.resize( nDPP ); 00310 00311 for( int ij = 0; ij < nDPP; ++ij ) 00312 { 00313 dataRowCols[ij * 2] = vecRow[dataPerProcess[ip][ij]]; 00314 dataRowCols[ij * 2 + 1] = vecCol[dataPerProcess[ip][ij]]; 00315 dataEntries[ij] = vecS[dataPerProcess[ip][ij]]; 00316 } 00317 00318 MPI_Request rcsend, dsend; 00319 mpierr = MPI_Isend( dataRowCols.data(), 2 * nDPP, MPI_INT, ip, iRead * 1000, commW, &rcsend ); 00320 CHECK_EQUAL( mpierr, 0 ); 00321 mpierr = MPI_Isend( dataEntries.data(), nDPP, MPI_DOUBLE, ip, iRead * 1000 + 1, commW, &dsend ); 00322 CHECK_EQUAL( mpierr, 0 ); 00323 00324 cRequests.push_back( rcsend ); 00325 cRequests.push_back( dsend ); 00326 } 00327 } 00328 00329 // Next perform all necessary local work while we wait for the buffers to be sent out 00330 // Compute an offset for the rows and columns by creating a local to global mapping for rootProc 00331 int rindex = 0, cindex = 0; 00332 assert( dataPerProcess[0].size() - nEntriesComm == 0 ); // sanity check 00333 for( int i = 0; i < nEntriesComm; ++i ) 00334 { 00335 const int& vecRowValue = vecRow[dataPerProcess[0][i]]; 00336 const int& vecColValue = vecCol[dataPerProcess[0][i]]; 00337 00338 std::map< int, int >::iterator riter = rowMap.find( vecRowValue ); 00339 if( riter == rowMap.end() ) 00340 { 00341 rowMap[vecRowValue] = rindexMax; 00342 rindex = rindexMax; 00343 rindexMax++; 00344 } 00345 else 00346 rindex = riter->second; 00347 00348 std::map< int, int >::iterator citer = colMap.find( vecColValue ); 00349 if( citer == colMap.end() ) 00350 { 00351 colMap[vecColValue] = cindexMax; 00352 cindex = cindexMax; 00353 cindexMax++; 00354 } 00355 else 00356 cindex = citer->second; 00357 00358 sparseMatrix( rindex, cindex ) = vecS[i]; 00359 } 00360 00361 // Wait until all communication is pushed out 00362 mpierr = MPI_Waitall( cRequests.size(), cRequests.data(), cStats.data() ); 00363 CHECK_EQUAL( mpierr, 0 ); 00364 } // if( rank == rootProc ) 00365 #ifdef MOAB_HAVE_MPI 00366 else 00367 { 00368 if( nEntriesComm > 0 ) 00369 { 00370 MPI_Request cRequests[2]; 00371 MPI_Status cStats[2]; 00372 /* code */ 00373 // create buffers to receive the data from root process 00374 std::vector< int > dataRowCols( 2 * nEntriesComm ); 00375 vecRow.Allocate( nEntriesComm ); 00376 vecCol.Allocate( nEntriesComm ); 00377 vecS.Allocate( nEntriesComm ); 00378 00379 /* TODO: combine row and column scatters together. Save one communication by better packing */ 00380 // Scatter the rows, cols and entries to the processes according to the partition 00381 mpierr = MPI_Irecv( dataRowCols.data(), 2 * nEntriesComm, MPI_INT, rootProc, iRead * 1000, commW, 00382 &cRequests[0] ); 00383 CHECK_EQUAL( mpierr, 0 ); 00384 00385 mpierr = MPI_Irecv( vecS, nEntriesComm, MPI_DOUBLE, rootProc, iRead * 1000 + 1, commW, &cRequests[1] ); 00386 CHECK_EQUAL( mpierr, 0 ); 00387 00388 // Wait until all communication is pushed out 00389 mpierr = MPI_Waitall( 2, cRequests, cStats ); 00390 CHECK_EQUAL( mpierr, 0 ); 00391 00392 // Compute an offset for the rows and columns by creating a local to global mapping 00393 int rindex = 0, cindex = 0; 00394 for( int i = 0; i < nEntriesComm; ++i ) 00395 { 00396 const int& vecRowValue = dataRowCols[i * 2]; 00397 const int& vecColValue = dataRowCols[i * 2 + 1]; 00398 00399 std::map< int, int >::iterator riter = rowMap.find( vecRowValue ); 00400 if( riter == rowMap.end() ) 00401 { 00402 rowMap[vecRowValue] = rindexMax; 00403 rindex = rindexMax; 00404 rindexMax++; 00405 } 00406 else 00407 rindex = riter->second; 00408 vecRow[i] = rindex; 00409 00410 std::map< int, int >::iterator citer = colMap.find( vecColValue ); 00411 if( citer == colMap.end() ) 00412 { 00413 colMap[vecColValue] = cindexMax; 00414 cindex = cindexMax; 00415 cindexMax++; 00416 } 00417 else 00418 cindex = citer->second; 00419 vecCol[i] = cindex; 00420 00421 sparseMatrix( rindex, cindex ) = vecS[i]; 00422 } 00423 00424 // clear the local buffer 00425 dataRowCols.clear(); 00426 } // if( nEntriesComm > 0 ) 00427 } // if( rank != rootProc ) 00428 00429 MPI_Barrier( commW ); 00430 #endif 00431 } 00432 00433 #ifdef MOAB_HAVE_MPI 00434 if( rank == rootProc ) 00435 #endif 00436 { 00437 assert( nEntriesRemaining == 0 ); 00438 ncMap->close(); 00439 } 00440 00441 /** 00442 * Perform a series of checks to ensure that the local maps in each process still preserve map properties 00443 * Let us run our usual tests to verify that the map data has been distributed correctly 00444 * 1) Consistency check -- row sum = 1.0 00445 * 2) Disable conservation checks that require global column sums (and hence more communication/reduction) 00446 * 3) Perform monotonicity check and ensure failures globally are same as serial case 00447 */ 00448 printf( "Rank %d: sparsematrix size = %d x %d\n", rank, sparseMatrix.GetRows(), sparseMatrix.GetColumns() ); 00449 00450 // consistency: row sums 00451 { 00452 int isConsistentP = mapRemap.IsConsistent( dTolerance ); 00453 if( 0 != isConsistentP ) 00454 { 00455 printf( "Rank %d failed consistency checks...\n", rank ); 00456 } 00457 CHECK_EQUAL( 0, isConsistentP ); 00458 } 00459 00460 // conservation: we will disable this conservation check for now. 00461 // int isConservativeP = mapRemap.IsConservative( dTolerance ); 00462 // CHECK_EQUAL( 0, isConservativeP ); 00463 00464 // monotonicity: local failures 00465 { 00466 int isMonotoneP = mapRemap.IsMonotone( dTolerance ); 00467 // Accumulate sum of failures to ensure that it is exactly same as serial case 00468 int isMonotoneG; 00469 mpierr = MPI_Allreduce( &isMonotoneP, &isMonotoneG, 1, MPI_INT, MPI_SUM, commW ); 00470 CHECK_EQUAL( mpierr, 0 ); 00471 00472 // 4600 monotonicity fails in serial and parallel for the test map file 00473 CHECK_EQUAL( 4600, isMonotoneG ); 00474 } 00475 00476 delete ncMap; 00477 00478 return; 00479 } 00480 00481 void read_map_from_disk() 00482 { 00483 moab::ErrorCode rval; 00484 NcError error( NcError::verbose_nonfatal ); 00485 MPI_Comm commW = MPI_COMM_WORLD; 00486 std::vector< int > tmp_owned_ids; 00487 double dTolerance = 1e-08; 00488 00489 std::string remap_weights_filename = TestDir + "unittest/outCS5ICOD5_map.nc"; 00490 00491 moab::Interface* mb = new moab::Core(); 00492 moab::ParallelComm pcomm( mb, commW ); 00493 00494 moab::TempestRemapper remapper( mb, &pcomm ); 00495 remapper.meshValidate = true; 00496 remapper.constructEdgeMap = true; 00497 00498 // Do not create new filesets; Use the sets from our respective applications 00499 remapper.initialize( false ); 00500 00501 moab::TempestOnlineMap onlinemap( &remapper ); 00502 00503 rval = onlinemap.ReadParallelMap( remap_weights_filename.c_str(), tmp_owned_ids, true ); 00504 CHECK_EQUAL( rval, moab::MB_SUCCESS ); 00505 00506 // consistency: row sums 00507 int isConsistentP = onlinemap.IsConsistent( dTolerance ); 00508 CHECK_EQUAL( 0, isConsistentP ); 00509 00510 // conservation: we will disable this conservation check for now 00511 // since we do not have information about source and target areas 00512 // to accurately decipher conservation data satisfaction 00513 // int isConservativeP = onlinemap.IsConservative( dTolerance ); 00514 // CHECK_EQUAL( 0, isConservativeP ); 00515 00516 // monotonicity: global failures 00517 int isMonotoneP = onlinemap.IsMonotone( dTolerance ); 00518 // Accumulate sum of failures to ensure that it is exactly same as serial case 00519 // 4600 fails in serial. What about parallel ? Check and confirm. 00520 CHECK_EQUAL( 4600, isMonotoneP ); 00521 } 00522 00523 void test_tempest_map_bcast() 00524 { 00525 /* 00526 * 00527 * Load mapping file generated with CS5 and ICOD5 meshes with FV-FV 00528 * projection for field data. It has following attributes: 00529 * 00530 * Analyzing map 00531 * ..Per-dof consistency (tol 1.00000e-08).. PASS 00532 * ..Per-dof conservation (tol 1.00000e-08).. PASS 00533 * ..Weights within range [-10,+10].. Done 00534 * .. 00535 * .. Total nonzero entries: 8976 00536 * .. Column index min/max: 1 / 150 (150 source dofs) 00537 * .. Row index min/max: 1 / 252 (252 target dofs) 00538 * .. Source area / 4pi: 9.999999999991666e-01 00539 * .. Source area min/max: 7.758193626656797e-02 / 9.789674024202324e-02 00540 * .. Target area / 4pi: 9.999999999999928e-01 00541 * .. Target area min/max: 3.418848585325412e-02 / 5.362041648788460e-02 00542 * .. Source frac min/max: 9.999999999997851e-01 / 1.000000000003865e+00 00543 * .. Target frac min/max: 9.999999999993099e-01 / 1.000000000000784e+00 00544 * .. Map weights min/max: -2.062659472710135e-01 / 1.143815352351317e+00 00545 * .. Row sums min/max: 9.999999999993099e-01 / 1.000000000000784e+00 00546 * .. Consist. err min/max: -6.901146321069973e-13 / 7.838174553853605e-13 00547 * .. Col wt.sums min/max: 9.999999999997854e-01 / 1.000000000003865e+00 00548 * .. Conserv. err min/max: -2.146061106600428e-13 / 3.865352482534945e-12 00549 * .. 00550 * ..Histogram of nonzero entries in sparse matrix 00551 * ....Column 1: Number of nonzero entries (bin minimum) 00552 * ....Column 2: Number of columns with that many nonzero values 00553 * ....Column 3: Number of rows with that many nonzero values 00554 * ..[[25, 0, 2],[29, 0, 8],[30, 0, 10],[31, 150, 232]] 00555 * .. 00556 * ..Histogram of weights 00557 * ....Column 1: Lower bound on weights 00558 * ....Column 2: Upper bound on weights 00559 * ....Column 3: # of weights in that bin 00560 * ..[[-1, 0, 4577],[0, 1, 4365],[1, 2, 34]] 00561 * 00562 */ 00563 NcError error( NcError::silent_nonfatal ); 00564 MPI_Comm commW = MPI_COMM_WORLD; 00565 const int rootProc = 0; 00566 const std::string outFilename = inMapFilename; 00567 double dTolerance = 1e-08; 00568 int mpierr = 0; 00569 00570 int nprocs, rank; 00571 MPI_Comm_size( MPI_COMM_WORLD, &nprocs ); 00572 MPI_Comm_rank( MPI_COMM_WORLD, &rank ); 00573 00574 const double dFillValueOverride = 0.0; 00575 OfflineMap mapRemap; 00576 if( rank == 0 ) 00577 { 00578 std::cout << "Reading file: " << outFilename << std::endl; 00579 mapRemap.Read( outFilename ); 00580 mapRemap.SetFillValueOverrideDbl( dFillValueOverride ); 00581 mapRemap.SetFillValueOverride( static_cast< float >( dFillValueOverride ) ); 00582 00583 int isConsistent = mapRemap.IsConsistent( dTolerance ); 00584 CHECK_EQUAL( 0, isConsistent ); 00585 int isConservative = mapRemap.IsConservative( dTolerance ); 00586 CHECK_EQUAL( 0, isConservative ); 00587 int isMonotone = mapRemap.IsMonotone( dTolerance ); 00588 CHECK_EQUAL( 4600, isMonotone ); 00589 00590 // verify that the source and target mesh areas are equal 00591 DataArray1D< double >& srcAreas = mapRemap.GetSourceAreas(); 00592 DataArray1D< double >& tgtAreas = mapRemap.GetTargetAreas(); 00593 00594 double totSrcArea = 0.0; 00595 for( size_t i = 0; i < srcAreas.GetRows(); ++i ) 00596 totSrcArea += srcAreas[i]; 00597 00598 double totTgtArea = 0.0; 00599 for( size_t i = 0; i < tgtAreas.GetRows(); ++i ) 00600 totTgtArea += tgtAreas[i]; 00601 00602 CHECK_REAL_EQUAL( totSrcArea, totTgtArea, 1e-10 ); 00603 } 00604 00605 MPI_Barrier( commW ); 00606 00607 SparseMatrix< double >& sparseMatrix = mapRemap.GetSparseMatrix(); 00608 00609 // Get the row, col and entry data tupl 00610 // Retrieve all data from the map operator on root process 00611 DataArray1D< int > dataRowsGlobal, dataColsGlobal; 00612 DataArray1D< double > dataEntriesGlobal; 00613 if( rank == 0 ) 00614 { 00615 sparseMatrix.GetEntries( dataRowsGlobal, dataColsGlobal, dataEntriesGlobal ); 00616 std::cout << "Total NNZ in remap matrix = " << dataRowsGlobal.GetRows() << std::endl; 00617 } 00618 00619 int *rg = nullptr, *cg = nullptr; 00620 double* de = nullptr; 00621 int nMapGlobalRowCols[3] = { sparseMatrix.GetRows(), sparseMatrix.GetColumns(), 00622 static_cast< int >( dataEntriesGlobal.GetRows() ) }; 00623 00624 /* split the rows and send to processes in chunks */ 00625 std::vector< int > rowAllocation; 00626 std::vector< int > sendCounts; 00627 std::vector< int > displs; 00628 const int NDATA = 3; 00629 if( rank == 0 ) 00630 { 00631 rg = dataRowsGlobal; 00632 cg = dataColsGlobal; 00633 de = dataEntriesGlobal; 00634 00635 // Let us do a trivial partitioning of the row data 00636 rowAllocation.resize( nprocs * NDATA ); 00637 displs.resize( nprocs ); 00638 sendCounts.resize( nprocs ); 00639 00640 int nRowPerPart = nMapGlobalRowCols[0] / nprocs; 00641 int remainder = nMapGlobalRowCols[0] % nprocs; // Keep the remainder in root 00642 // printf( "nRowPerPart = %d, remainder = %d\n", nRowPerPart, remainder ); 00643 int sum = 0; 00644 for( int i = 0; i < nprocs; ++i ) 00645 { 00646 rowAllocation[i * NDATA] = nRowPerPart + ( i == 0 ? remainder : 0 ); 00647 rowAllocation[i * NDATA + 1] = std::find( rg, rg + dataRowsGlobal.GetRows(), sum ) - rg; 00648 sum += rowAllocation[i * NDATA]; 00649 displs[i] = rowAllocation[i * NDATA + 1]; 00650 } 00651 for( int i = 0; i < nprocs - 1; ++i ) 00652 { 00653 rowAllocation[i * NDATA + 2] = rowAllocation[( i + 1 ) * NDATA + 1] - rowAllocation[i * NDATA + 1]; 00654 sendCounts[i] = rowAllocation[i * NDATA + 2]; 00655 } 00656 rowAllocation[( nprocs - 1 ) * NDATA + 2] = nMapGlobalRowCols[2] - displs[nprocs - 1]; 00657 sendCounts[nprocs - 1] = rowAllocation[( nprocs - 1 ) * NDATA + 2]; 00658 00659 // for( int i = 0; i < nprocs; i++ ) 00660 // printf( "sendcounts[%d] = %d, %d, %d\tdispls[%d] = %d, %d\n", i, rowAllocation[i * NDATA], 00661 // rowAllocation[i * NDATA + 1], rowAllocation[i * NDATA + 2], i, displs[i], sendCounts[i] ); 00662 } 00663 00664 mpierr = MPI_Bcast( nMapGlobalRowCols, 3, MPI_INT, rootProc, commW ); 00665 CHECK_EQUAL( mpierr, 0 ); 00666 00667 int allocationSize[NDATA] = { 0, 0, 0 }; 00668 mpierr = MPI_Scatter( rowAllocation.data(), NDATA, MPI_INT, &allocationSize, NDATA, MPI_INT, rootProc, commW ); 00669 CHECK_EQUAL( mpierr, 0 ); 00670 00671 // create buffers to receive the data from root process 00672 DataArray1D< int > dataRows, dataCols; 00673 DataArray1D< double > dataEntries; 00674 dataRows.Allocate( allocationSize[2] ); 00675 dataCols.Allocate( allocationSize[2] ); 00676 dataEntries.Allocate( allocationSize[2] ); 00677 00678 /* TODO: combine row and column scatters together. Save one communication by better packing */ 00679 // Scatter the rows, cols and entries to the processes according to the partition 00680 mpierr = MPI_Scatterv( rg, sendCounts.data(), displs.data(), MPI_INT, (int*)( dataRows ), dataRows.GetByteSize(), 00681 MPI_INT, rootProc, commW ); 00682 CHECK_EQUAL( mpierr, 0 ); 00683 00684 mpierr = MPI_Scatterv( cg, sendCounts.data(), displs.data(), MPI_INT, (int*)( dataCols ), dataCols.GetByteSize(), 00685 MPI_INT, rootProc, commW ); 00686 CHECK_EQUAL( mpierr, 0 ); 00687 00688 mpierr = MPI_Scatterv( de, sendCounts.data(), displs.data(), MPI_DOUBLE, (double*)( dataEntries ), 00689 dataEntries.GetByteSize(), MPI_DOUBLE, rootProc, commW ); 00690 CHECK_EQUAL( mpierr, 0 ); 00691 00692 // Compute an offset for the rows and columns by creating a local to global mapping 00693 std::vector< int > rowMap, colMap; 00694 for( int i = 0; i < allocationSize[2]; ++i ) 00695 { 00696 int rindex, cindex; 00697 std::vector< int >::iterator riter = std::find( rowMap.begin(), rowMap.end(), dataRows[i] ); 00698 if( riter == rowMap.end() ) 00699 { 00700 rowMap.push_back( dataRows[i] ); 00701 rindex = rowMap.size() - 1; 00702 } 00703 else 00704 rindex = riter - rowMap.begin(); 00705 dataRows[i] = rindex; 00706 00707 std::vector< int >::iterator citer = std::find( colMap.begin(), colMap.end(), dataCols[i] ); 00708 if( citer == colMap.end() ) 00709 { 00710 colMap.push_back( dataCols[i] ); 00711 cindex = colMap.size() - 1; 00712 } 00713 else 00714 cindex = citer - colMap.begin(); 00715 dataCols[i] = cindex; 00716 } 00717 00718 // Now set the data received from root onto the sparse matrix 00719 sparseMatrix.SetEntries( dataRows, dataCols, dataEntries ); 00720 00721 /** 00722 * Perform a series of checks to ensure that the local maps in each process still preserve map properties 00723 * Let us run our usual tests to verify that the map data has been distributed correctly 00724 * 1) Consistency check -- row sum = 1.0 00725 * 2) Disable conservation checks that require global column sums (and hence more communication/reduction) 00726 * 3) Perform monotonicity check and ensure failures globally are same as serial case 00727 */ 00728 00729 // consistency: row sums 00730 int isConsistentP = mapRemap.IsConsistent( dTolerance ); 00731 CHECK_EQUAL( 0, isConsistentP ); 00732 00733 // conservation: we will disable this conservation check for now. 00734 // int isConservativeP = mapRemap.IsConservative( dTolerance ); 00735 // CHECK_EQUAL( 0, isConservativeP ); 00736 00737 // monotonicity: local failures 00738 int isMonotoneP = mapRemap.IsMonotone( dTolerance ); 00739 // Accumulate sum of failures to ensure that it is exactly same as serial case 00740 int isMonotoneG; 00741 mpierr = MPI_Allreduce( &isMonotoneP, &isMonotoneG, 1, MPI_INT, MPI_SUM, commW ); 00742 CHECK_EQUAL( mpierr, 0 ); 00743 // 4600 fails in serial. What about parallel ? Check and confirm. 00744 CHECK_EQUAL( 4600, isMonotoneG ); 00745 00746 return; 00747 }
