MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /** 00002 * MOAB, a Mesh-Oriented datABase, is a software component for creating, 00003 * storing and accessing finite element mesh data. 00004 * 00005 * Copyright 2004 Sandia Corporation. Under the terms of Contract 00006 * DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government 00007 * retains certain rights in this software. 00008 * 00009 * This library is free software; you can redistribute it and/or 00010 * modify it under the terms of the GNU Lesser General Public 00011 * License as published by the Free Software Foundation; either 00012 * version 2.1 of the License, or (at your option) any later version. 00013 * 00014 */ 00015 00016 #ifdef WIN32 00017 #ifdef _DEBUG 00018 // turn off warnings that say they debugging identifier has been truncated 00019 // this warning comes up when using some STL containers 00020 #pragma warning( disable : 4786 ) 00021 #endif 00022 #endif 00023 00024 #include <iostream> 00025 #include "moab/Core.hpp" 00026 #include "moab/Remapping/TempestRemapper.hpp" 00027 00028 #ifdef MOAB_HAVE_MPI 00029 #include "moab/ParallelComm.hpp" 00030 #endif 00031 00032 #ifndef IS_BUILDING_MB 00033 #define IS_BUILDING_MB 00034 #endif 00035 00036 #include "Internals.hpp" 00037 #include "TestRunner.hpp" 00038 00039 using namespace moab; 00040 00041 const static double radius = 1.0; 00042 const double MOAB_PI = 3.1415926535897932384626433832795028841971693993751058209749445923; 00043 const static double surface_area = 4.0 * MOAB_PI * radius * radius; 00044 const static std::string outFilenames[5] = { "outTempestCS.g", "outTempestRLL.g", "outTempestICO.g", "outTempestICOD.g", 00045 "outTempestOV.g" }; 00046 00047 void test_tempest_cs_create(); 00048 void test_tempest_rll_create(); 00049 void test_tempest_ico_create(); 00050 void test_tempest_mpas_create(); 00051 void test_tempest_overlap_combinations(); 00052 void test_tempest_to_moab_convert(); 00053 00054 int main( int argc, char** argv ) 00055 { 00056 REGISTER_TEST( test_tempest_cs_create ); 00057 REGISTER_TEST( test_tempest_rll_create ); 00058 REGISTER_TEST( test_tempest_ico_create ); 00059 REGISTER_TEST( test_tempest_mpas_create ); 00060 REGISTER_TEST( test_tempest_overlap_combinations ); 00061 REGISTER_TEST( test_tempest_to_moab_convert ); 00062 00063 #ifdef MOAB_HAVE_MPI 00064 MPI_Init( &argc, &argv ); 00065 #endif 00066 int result = RUN_TESTS( argc, argv ); 00067 #ifdef MOAB_HAVE_MPI 00068 MPI_Finalize(); 00069 #endif 00070 return result; 00071 } 00072 00073 void test_tempest_cs_create() 00074 { 00075 NcError error( NcError::verbose_nonfatal ); 00076 const int blockSize = 30; 00077 const std::string outFilename = outFilenames[0]; 00078 00079 std::cout << "Creating TempestRemap Cubed-Sphere Mesh ...\n"; 00080 Mesh tempest_mesh; 00081 int ierr = GenerateCSMesh( tempest_mesh, blockSize, outFilename, "NetCDF4" ); 00082 CHECK_EQUAL( ierr, 0 ); 00083 00084 // Compute the surface area of CS mesh 00085 const double sphere_area = tempest_mesh.CalculateFaceAreas( false ); 00086 CHECK_REAL_EQUAL( sphere_area, surface_area, 1e-10 ); 00087 } 00088 00089 void test_tempest_rll_create() 00090 { 00091 NcError error( NcError::verbose_nonfatal ); 00092 const int blockSize = 30; 00093 const std::string outFilename = outFilenames[1]; 00094 00095 std::cout << "Creating TempestRemap Latitude-Longitude Mesh ...\n"; 00096 Mesh tempest_mesh; 00097 int ierr = 00098 GenerateRLLMesh( tempest_mesh, blockSize * 2, blockSize, 0.0, 360.0, -90.0, 90.0, false, false, true, "", "", 00099 "", // std::string strInputFile, std::string strInputFileLonName, std::string 00100 // strInputFileLatName, 00101 outFilename, "NetCDF4", // std::string strOutputFile, std::string strOutputFormat 00102 false ); 00103 CHECK_EQUAL( ierr, 0 ); 00104 00105 // Compute the surface area of RLL mesh 00106 const double sphere_area = tempest_mesh.CalculateFaceAreas( false ); 00107 CHECK_REAL_EQUAL( sphere_area, surface_area, 1e-10 ); 00108 } 00109 00110 void test_tempest_ico_create() 00111 { 00112 NcError error( NcError::verbose_nonfatal ); 00113 const int blockSize = 30; 00114 const bool computeDual = false; 00115 const std::string outFilename = outFilenames[2]; 00116 00117 std::cout << "Creating TempestRemap Icosahedral Mesh ...\n"; 00118 Mesh tempest_mesh; 00119 int ierr = GenerateICOMesh( tempest_mesh, blockSize, computeDual, outFilename, "NetCDF4" ); 00120 CHECK_EQUAL( ierr, 0 ); 00121 00122 // Compute the surface area of ICO mesh 00123 const double sphere_area = tempest_mesh.CalculateFaceAreas( false ); 00124 CHECK_REAL_EQUAL( sphere_area, surface_area, 1e-10 ); 00125 } 00126 00127 void test_tempest_mpas_create() 00128 { 00129 NcError error( NcError::verbose_nonfatal ); 00130 const int blockSize = 30; 00131 const bool computeDual = true; 00132 const std::string outFilename = outFilenames[3]; 00133 00134 std::cout << "Creating TempestRemap MPAS Mesh (dual of the Icosahedral) ...\n"; 00135 Mesh tempest_mesh; 00136 int ierr = GenerateICOMesh( tempest_mesh, blockSize, computeDual, outFilename, "NetCDF4" ); 00137 CHECK_EQUAL( ierr, 0 ); 00138 00139 // Compute the surface area of MPAS mesh 00140 const double sphere_area = tempest_mesh.CalculateFaceAreas( false ); 00141 CHECK_REAL_EQUAL( sphere_area, surface_area, 1e-10 ); 00142 } 00143 00144 void test_tempest_overlap_combinations() 00145 { 00146 NcError error( NcError::verbose_nonfatal ); 00147 const std::string outFilename = outFilenames[4]; 00148 00149 Mesh inpMesh( outFilenames[0] ); 00150 // verify input mesh area first 00151 const double inpArea = inpMesh.CalculateFaceAreas( false ); 00152 CHECK_REAL_EQUAL( inpArea, surface_area, 1e-10 ); 00153 00154 for( int isrc = 0; isrc < 4; ++isrc ) 00155 { 00156 for( int jsrc = 0; jsrc < 4; ++jsrc ) 00157 { 00158 std::cout << "Computing Overlap between " << outFilenames[isrc] << " and " << outFilenames[jsrc] 00159 << " ...\n"; 00160 Mesh tempest_mesh; 00161 int ierr = GenerateOverlapMesh( outFilenames[isrc], outFilenames[jsrc], tempest_mesh, outFilename, 00162 "NetCDF4", "exact", false, false, false, false, false ); 00163 CHECK_EQUAL( ierr, 0 ); 00164 // verify overlap mesh area 00165 const double ovArea = tempest_mesh.CalculateFaceAreas( false ); 00166 CHECK_REAL_EQUAL( ovArea, surface_area, 1e-10 ); 00167 } 00168 } 00169 } 00170 00171 void test_tempest_to_moab_convert() 00172 { 00173 NcError error( NcError::verbose_nonfatal ); 00174 00175 // Allocate and create MOAB Remapper object 00176 moab::ErrorCode rval; 00177 moab::Interface* mbCore = new( std::nothrow ) moab::Core; 00178 CHECK( NULL != mbCore ); 00179 00180 #ifdef MOAB_HAVE_MPI 00181 moab::ParallelComm* pcomm = new moab::ParallelComm( mbCore, MPI_COMM_WORLD, 0 ); 00182 moab::TempestRemapper* remapper = new moab::TempestRemapper( mbCore, pcomm ); 00183 #else 00184 moab::TempestRemapper* remapper = new moab::TempestRemapper( mbCore ); 00185 #endif 00186 remapper->meshValidate = true; 00187 remapper->constructEdgeMap = true; 00188 remapper->initialize(); 00189 00190 #ifdef MOAB_HAVE_MPI 00191 rval = pcomm->check_all_shared_handles();CHECK_ERR( rval ); 00192 #endif 00193 00194 rval = remapper->LoadMesh( moab::Remapper::SourceMesh, outFilenames[0], moab::TempestRemapper::CS );CHECK_ERR( rval ); 00195 00196 // Load the meshes and validate 00197 rval = remapper->ConvertTempestMesh( moab::Remapper::SourceMesh );CHECK_ERR( rval ); 00198 00199 Mesh* srcTempest = remapper->GetMesh( moab::Remapper::SourceMesh ); 00200 00201 moab::EntityHandle srcset = remapper->GetMeshSet( moab::Remapper::SourceMesh ); 00202 00203 moab::EntityHandle& tgtset = remapper->GetMeshSet( moab::Remapper::TargetMesh ); 00204 00205 tgtset = srcset; 00206 00207 // Load the meshes and validate 00208 rval = remapper->ConvertMeshToTempest( moab::Remapper::TargetMesh );CHECK_ERR( rval ); 00209 00210 Mesh* tgtTempest = remapper->GetMesh( moab::Remapper::TargetMesh ); 00211 00212 const size_t tempest_nodes_src = srcTempest->nodes.size(), tempest_elems_src = srcTempest->faces.size(); 00213 const size_t tempest_nodes_tgt = tgtTempest->nodes.size(), tempest_elems_tgt = tgtTempest->faces.size(); 00214 CHECK_EQUAL( tempest_nodes_src, tempest_nodes_tgt ); 00215 CHECK_EQUAL( tempest_elems_src, tempest_elems_tgt ); 00216 00217 delete remapper; 00218 #ifdef MOAB_HAVE_MPI 00219 delete pcomm; 00220 #endif 00221 delete mbCore; 00222 }
