MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /** 00002 * MOAB, a Mesh-Oriented datABase, is a software component for creating, 00003 * storing and accessing finite element mesh data. 00004 * 00005 * Copyright 2004 Sandia Corporation. Under the terms of Contract 00006 * DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government 00007 * retains certain rights in this software. 00008 * 00009 * This library is free software; you can redistribute it and/or 00010 * modify it under the terms of the GNU Lesser General Public 00011 * License as published by the Free Software Foundation; either 00012 * version 2.1 of the License, or (at your option) any later version. 00013 * 00014 */ 00015 00016 /** TSTT Mesh Interface brick mesh performance test 00017 * 00018 * This program tests TSTT mesh interface functions used to create a square structured 00019 * mesh. Boilerplate taken from tstt mesh interface test in MOAB and performance test in MOAB 00020 * 00021 */ 00022 00023 // Different platforms follow different conventions for usage 00024 #if !defined( _NT ) && !defined( _MSC_VER ) && !defined( __MINGW32__ ) 00025 #include <sys/resource.h> 00026 #endif 00027 #ifdef SOLARIS 00028 extern "C" int getrusage( int, struct rusage* ); 00029 #ifndef RUSAGE_SELF 00030 #include </usr/ucbinclude/sys/rusage.h> 00031 #endif 00032 #endif 00033 00034 #include <cstdlib> 00035 #include <cstdio> 00036 #include <iostream> 00037 00038 //------------------------------------------------------- 00039 // CHANGE THESE DEFINITIONS TO SUIT YOUR IMPLEMENTATION 00040 00041 // #include here any files with declarations needed to instantiate your 00042 // implementation instance 00043 #include "TSTT_MOAB.hh" 00044 00045 // define IMPLEMENTATION_CLASS to be the namespace::class of your implementation 00046 #define IMPLEMENTATION_CLASS TSTT_MOAB::MoabMesh 00047 //------------------------------------------------------- 00048 00049 #define CAST_INTERFACE( var_in, var_out, iface ) \ 00050 TSTT::iface var_out; \ 00051 try \ 00052 { \ 00053 ( var_out ) = var_in; \ 00054 } \ 00055 catch( TSTT::Error ) \ 00056 { \ 00057 cerr << "Error: current interface doesn't support iface." << endl; \ 00058 return; \ 00059 } 00060 00061 #define CAST_MINTERFACE( var_in, var_out, iface ) \ 00062 TSTTM::iface var_out; \ 00063 try \ 00064 { \ 00065 ( var_out ) = var_in; \ 00066 } \ 00067 catch( TSTT::Error ) \ 00068 { \ 00069 cerr << "Error: current interface doesn't support iface." << endl; \ 00070 return; \ 00071 } 00072 00073 #include <iostream> 00074 #include "TSTT.hh" 00075 #include "TSTTM.hh" 00076 00077 // needed to get the proper size for handles 00078 typedef void* Entity_Handle; 00079 00080 using namespace std; 00081 00082 #define ARRAY_PTR( array, type ) ( reinterpret_cast< ( type )* >( ( array )._get_ior()->d_firstElement ) ) 00083 #define HANDLE_ARRAY_PTR( array ) ( reinterpret_cast< Entity_Handle* >( ( array )._get_ior()->d_firstElement ) ) 00084 #define ARRAY_SIZE( array ) ( ( array )._is_nil() ? 0 : ( array ).upper( 0 ) - ( array ).lower( 0 ) + 1 ) 00085 #define CHECK_SIZE( array, size ) \ 00086 if( ( array )._is_nil() || ARRAY_SIZE( array ) == 0 ) \ 00087 ( array ) = ( array ).create1d( size ); \ 00088 else if( ARRAY_SIZE( array ) < ( size ) ) \ 00089 { \ 00090 cerr << "Array passed in is non-zero but too short." << endl; \ 00091 assert( false ); \ 00092 } 00093 00094 double LENGTH = 1.0; 00095 00096 // forward declare some functions 00097 void query_vert_to_elem( TSTTM::Mesh& mesh ); 00098 void query_elem_to_vert( TSTTM::Mesh& mesh ); 00099 void print_time( const bool print_em, double& tot_time, double& utime, double& stime ); 00100 void build_connect( const int nelem, const int vstart, int*& connect ); 00101 void testB( TSTTM::Mesh& mesh, const int nelem, sidl::array< double >& coords, const int* connect ); 00102 void testC( TSTTM::Mesh& mesh, const int nelem, sidl::array< double >& coords ); 00103 void compute_edge( double* start, const int nelem, const double xint, const int stride ); 00104 void compute_face( double* a, const int nelem, const double xint, const int stride1, const int stride2 ); 00105 void build_coords( const int nelem, sidl::array< double >& coords ); 00106 void build_connect( const int nelem, const int vstart, int*& connect ); 00107 00108 int main( int argc, char* argv[] ) 00109 { 00110 int nelem = 20; 00111 if( argc < 3 ) 00112 { 00113 std::cout << "Usage: " << argv[0] << " <ints_per_side> <A|B|C>" << std::endl; 00114 return 1; 00115 } 00116 00117 char which_test = '\0'; 00118 00119 sscanf( argv[1], "%d", &nelem ); 00120 sscanf( argv[2], "%c", &which_test ); 00121 00122 if( which_test != 'B' && which_test != 'C' ) 00123 { 00124 std::cout << "Must indicate B or C for test." << std::endl; 00125 return 1; 00126 } 00127 00128 std::cout << "number of elements: " << nelem << "; test " << which_test << std::endl; 00129 00130 // pre-build the coords array 00131 sidl::array< double > coords; 00132 build_coords( nelem, coords ); 00133 assert( NULL != coords ); 00134 00135 int* connect = NULL; 00136 build_connect( nelem, 1, connect ); 00137 00138 // create an implementation 00139 TSTTM::Mesh mesh = IMPLEMENTATION_CLASS::_create(); 00140 00141 switch( which_test ) 00142 { 00143 case 'B': 00144 // test B: create mesh using bulk interface 00145 testB( mesh, nelem, coords, connect ); 00146 break; 00147 00148 case 'C': 00149 // test C: create mesh using individual interface 00150 testC( mesh, nelem, coords ); 00151 break; 00152 } 00153 00154 return 0; 00155 } 00156 00157 void testB( TSTTM::Mesh& mesh, const int nelem, sidl::array< double >& coords, const int* connect ) 00158 { 00159 double utime, stime, ttime0, ttime1, ttime2, ttime3; 00160 00161 print_time( false, ttime0, utime, stime ); 00162 int num_verts = ( nelem + 1 ) * ( nelem + 1 ) * ( nelem + 1 ); 00163 int num_elems = nelem * nelem * nelem; 00164 00165 // create vertices as a block 00166 CAST_MINTERFACE( mesh, mesh_arrmod, ArrMod ); 00167 sidl::array< Entity_Handle > sidl_vertices, dum_handles; 00168 CHECK_SIZE( dum_handles, num_verts ); 00169 int sidl_vertices_size; 00170 00171 try 00172 { 00173 mesh_arrmod.createVtxArr( num_verts, TSTTM::StorageOrder_BLOCKED, coords, 3 * num_verts, sidl_vertices, 00174 sidl_vertices_size ); 00175 } 00176 catch( TSTT::Error& /* err */ ) 00177 { 00178 cerr << "Couldn't create vertices in bulk call" << endl; 00179 return; 00180 } 00181 00182 // need to explicitly fill connectivity array, since we don't know 00183 // the format of entity handles 00184 sidl::array< Entity_Handle > sidl_connect; 00185 int sidl_connect_size = 8 * num_elems; 00186 CHECK_SIZE( sidl_connect, 8 * num_elems ); 00187 Entity_Handle* sidl_connect_ptr = HANDLE_ARRAY_PTR( sidl_connect ); 00188 00189 Entity_Handle* sidl_vertices_ptr = HANDLE_ARRAY_PTR( sidl_vertices ); 00190 for( int i = 0; i < sidl_connect_size; i++ ) 00191 { 00192 // use connect[i]-1 because we used starting vertex index (vstart) of 1 00193 assert( connect[i] - 1 < num_verts ); 00194 sidl_connect_ptr[i] = sidl_vertices_ptr[connect[i] - 1]; 00195 } 00196 00197 // create the entities 00198 sidl::array< Entity_Handle > new_hexes; 00199 int new_hexes_size; 00200 sidl::array< TSTTM::CreationStatus > status; 00201 int status_size; 00202 00203 try 00204 { 00205 mesh_arrmod.createEntArr( TSTTM::EntityTopology_HEXAHEDRON, sidl_connect, sidl_connect_size, new_hexes, 00206 new_hexes_size, status, status_size ); 00207 } 00208 catch( TSTT::Error& /* err */ ) 00209 { 00210 cerr << "Couldn't create hex elements in bulk call" << endl; 00211 return; 00212 } 00213 00214 print_time( false, ttime1, utime, stime ); 00215 00216 // query the mesh 2 ways 00217 query_elem_to_vert( mesh ); 00218 00219 print_time( false, ttime2, utime, stime ); 00220 00221 query_vert_to_elem( mesh ); 00222 00223 print_time( false, ttime3, utime, stime ); 00224 00225 std::cout << "TSTT/MOAB ucd blocked: nelem, construct, e_to_v query, v_to_e query = " << nelem << ", " 00226 << ttime1 - ttime0 << ", " << ttime2 - ttime1 << ", " << ttime3 - ttime2 << " seconds" << std::endl; 00227 } 00228 00229 void testC( TSTTM::Mesh& mesh, const int nelem, sidl::array< double >& coords ) 00230 { 00231 double utime, stime, ttime0, ttime1, ttime2, ttime3; 00232 print_time( false, ttime0, utime, stime ); 00233 00234 CAST_MINTERFACE( mesh, mesh_arrmod, ArrMod ); 00235 00236 // need some dimensions 00237 int numv = nelem + 1; 00238 int numv_sq = numv * numv; 00239 int num_verts = numv * numv * numv; 00240 #define VINDEX( i, j, k ) ( ( i ) + ( (j)*numv ) + ( (k)*numv_sq ) ) 00241 00242 // array to hold vertices created individually 00243 sidl::array< Entity_Handle > sidl_vertices; 00244 // int sidl_vertices_size = num_verts; 00245 CHECK_SIZE( sidl_vertices, num_verts ); 00246 00247 // temporary array to hold vertex positions for single vertex 00248 sidl::array< double > tmp_coords; 00249 int tmp_coords_size = 3; 00250 CHECK_SIZE( tmp_coords, 3 ); 00251 double* dum_coords = ARRAY_PTR( tmp_coords, double ); 00252 00253 // get direct pointer to coordinate array 00254 double* coords_ptr = ARRAY_PTR( coords, double ); 00255 00256 for( int i = 0; i < num_verts; i++ ) 00257 { 00258 00259 // temporary array to hold (single) vertices 00260 sidl::array< Entity_Handle > tmp_vertices; 00261 int tmp_vertices_size = 0; 00262 00263 // create the vertex 00264 dum_coords[0] = coords_ptr[i]; 00265 dum_coords[1] = coords_ptr[num_verts + i]; 00266 dum_coords[2] = coords_ptr[2 * num_verts + i]; 00267 try 00268 { 00269 mesh_arrmod.createVtxArr( 1, TSTTM::StorageOrder_BLOCKED, tmp_coords, tmp_coords_size, tmp_vertices, 00270 tmp_vertices_size ); 00271 } 00272 catch( TSTT::Error& /* err */ ) 00273 { 00274 cerr << "Couldn't create vertex in individual call" << endl; 00275 return; 00276 } 00277 00278 // assign into permanent vertex array 00279 sidl_vertices.set( i, tmp_vertices.get( 0 ) ); 00280 } 00281 00282 // get vertex array pointer for reading into tmp_conn 00283 Entity_Handle* tmp_sidl_vertices = HANDLE_ARRAY_PTR( sidl_vertices ); 00284 00285 for( int i = 0; i < nelem; i++ ) 00286 { 00287 for( int j = 0; j < nelem; j++ ) 00288 { 00289 for( int k = 0; k < nelem; k++ ) 00290 { 00291 00292 sidl::array< Entity_Handle > tmp_conn; 00293 int tmp_conn_size = 8; 00294 CHECK_SIZE( tmp_conn, 8 ); 00295 00296 int vijk = VINDEX( i, j, k ); 00297 tmp_conn.set( 0, tmp_sidl_vertices[vijk] ); 00298 tmp_conn.set( 1, tmp_sidl_vertices[vijk + 1] ); 00299 tmp_conn.set( 2, tmp_sidl_vertices[vijk + 1 + numv] ); 00300 tmp_conn.set( 3, tmp_sidl_vertices[vijk + numv] ); 00301 tmp_conn.set( 4, tmp_sidl_vertices[vijk + numv * numv] ); 00302 tmp_conn.set( 5, tmp_sidl_vertices[vijk + 1 + numv * numv] ); 00303 tmp_conn.set( 6, tmp_sidl_vertices[vijk + 1 + numv + numv * numv] ); 00304 tmp_conn.set( 7, tmp_sidl_vertices[vijk + numv + numv * numv] ); 00305 00306 // create the entity 00307 00308 sidl::array< Entity_Handle > new_hex; 00309 int new_hex_size = 0; 00310 sidl::array< TSTTM::CreationStatus > status; 00311 int status_size = 0; 00312 00313 try 00314 { 00315 mesh_arrmod.createEntArr( TSTTM::EntityTopology_HEXAHEDRON, tmp_conn, tmp_conn_size, new_hex, 00316 new_hex_size, status, status_size ); 00317 } 00318 catch( TSTT::Error& /* err */ ) 00319 { 00320 cerr << "Couldn't create hex element in individual call" << endl; 00321 return; 00322 } 00323 } 00324 } 00325 } 00326 00327 print_time( false, ttime1, utime, stime ); 00328 00329 // query the mesh 2 ways 00330 query_elem_to_vert( mesh ); 00331 00332 print_time( false, ttime2, utime, stime ); 00333 00334 query_vert_to_elem( mesh ); 00335 00336 print_time( false, ttime3, utime, stime ); 00337 00338 std::cout << "TSTT/MOAB ucd indiv: nelem, construct, e_to_v query, v_to_e query = " << nelem << ", " 00339 << ttime1 - ttime0 << ", " << ttime2 - ttime1 << ", " << ttime3 - ttime2 << " seconds" << std::endl; 00340 } 00341 00342 void query_elem_to_vert( TSTTM::Mesh& mesh ) 00343 { 00344 sidl::array< Entity_Handle > all_hexes; 00345 int all_hexes_size; 00346 CAST_MINTERFACE( mesh, mesh_ent, Entity ); 00347 00348 // get all the hex elements 00349 try 00350 { 00351 mesh.getEntities( 0, TSTTM::EntityType_REGION, TSTTM::EntityTopology_HEXAHEDRON, all_hexes, all_hexes_size ); 00352 } 00353 catch( TSTT::Error& /* err */ ) 00354 { 00355 cerr << "Couldn't get all hex elements in query_mesh" << endl; 00356 return; 00357 } 00358 00359 try 00360 { 00361 // set up some tmp arrays and array ptrs 00362 Entity_Handle* all_hexes_ptr = HANDLE_ARRAY_PTR( all_hexes ); 00363 00364 // now loop over elements 00365 for( int i = 0; i < all_hexes_size; i++ ) 00366 { 00367 sidl::array< int > dum_offsets; 00368 sidl::array< Entity_Handle > dum_connect; 00369 int dum_connect_size = 0; 00370 // get the connectivity of this element; will allocate space on 1st iteration, 00371 // but will have correct size on subsequent ones 00372 mesh_ent.getEntAdj( all_hexes_ptr[i], TSTTM::EntityType_VERTEX, dum_connect, dum_connect_size ); 00373 00374 // get vertex coordinates; ; will allocate space on 1st iteration, 00375 // but will have correct size on subsequent ones 00376 sidl::array< double > dum_coords; 00377 int dum_coords_size = 0; 00378 TSTTM::StorageOrder order = TSTTM::StorageOrder_UNDETERMINED; 00379 mesh.getVtxArrCoords( dum_connect, dum_connect_size, order, dum_coords, dum_coords_size ); 00380 00381 assert( 24 == dum_coords_size && ARRAY_SIZE( dum_coords ) == 24 ); 00382 double* dum_coords_ptr = ARRAY_PTR( dum_coords, double ); 00383 double centroid[3] = { 0.0, 0.0, 0.0 }; 00384 if( order == TSTTM::StorageOrder_BLOCKED ) 00385 { 00386 for( int j = 0; j < 8; j++ ) 00387 { 00388 centroid[0] += dum_coords_ptr[j]; 00389 centroid[1] += dum_coords_ptr[8 + j]; 00390 centroid[2] += dum_coords_ptr[16 + j]; 00391 centroid[0] += dum_coords.get( j ); 00392 centroid[1] += dum_coords.get( 8 + j ); 00393 centroid[2] += dum_coords.get( 16 + j ); 00394 } 00395 } 00396 else 00397 { 00398 for( int j = 0; j < 8; j++ ) 00399 { 00400 centroid[0] += dum_coords_ptr[3 * j]; 00401 centroid[1] += dum_coords_ptr[3 * j + 1]; 00402 centroid[2] += dum_coords_ptr[3 * j + 2]; 00403 } 00404 } 00405 } 00406 } 00407 catch( TSTT::Error& /* err */ ) 00408 { 00409 cerr << "Problem getting connectivity or vertex coords." << endl; 00410 return; 00411 } 00412 } 00413 00414 void query_vert_to_elem( TSTTM::Mesh& mesh ) 00415 { 00416 sidl::array< Entity_Handle > all_verts; 00417 int all_verts_size; 00418 CAST_MINTERFACE( mesh, mesh_ent, Entity ); 00419 00420 // get all the vertices elements 00421 try 00422 { 00423 mesh.getEntities( 0, TSTTM::EntityType_VERTEX, TSTTM::EntityTopology_POINT, all_verts, all_verts_size ); 00424 } 00425 catch( TSTT::Error& /* err */ ) 00426 { 00427 cerr << "Couldn't get all vertices in query_vert_to_elem" << endl; 00428 return; 00429 } 00430 00431 try 00432 { 00433 // set up some tmp arrays and array ptrs 00434 Entity_Handle* all_verts_ptr = HANDLE_ARRAY_PTR( all_verts ); 00435 00436 // now loop over vertices 00437 for( int i = 0; i < all_verts_size; i++ ) 00438 { 00439 sidl::array< Entity_Handle > dum_hexes; 00440 int dum_hexes_size; 00441 00442 // get the connectivity of this element; will have to allocate space on every 00443 // iteration, since size can vary 00444 mesh_ent.getEntAdj( all_verts_ptr[i], TSTTM::EntityType_REGION, dum_hexes, dum_hexes_size ); 00445 } 00446 } 00447 catch( TSTT::Error& /* err */ ) 00448 { 00449 cerr << "Problem getting connectivity or vertex coords." << endl; 00450 return; 00451 } 00452 } 00453 00454 void print_time( const bool print_em, double& tot_time, double& utime, double& stime ) 00455 { 00456 struct rusage r_usage; 00457 getrusage( RUSAGE_SELF, &r_usage ); 00458 utime = (double)r_usage.ru_utime.tv_sec + ( (double)r_usage.ru_utime.tv_usec / 1.e6 ); 00459 stime = (double)r_usage.ru_stime.tv_sec + ( (double)r_usage.ru_stime.tv_usec / 1.e6 ); 00460 tot_time = utime + stime; 00461 if( print_em ) 00462 std::cout << "User, system, total time = " << utime << ", " << stime << ", " << tot_time << std::endl; 00463 #ifndef LINUX 00464 std::cout << "Max resident set size = " << r_usage.ru_maxrss * 4096 << " bytes" << std::endl; 00465 std::cout << "Int resident set size = " << r_usage.ru_idrss << std::endl; 00466 #else 00467 system( "ps o args,drs,rss | grep perf | grep -v grep" ); // RedHat 9.0 doesnt fill in actual 00468 // memory data 00469 #endif 00470 } 00471 00472 void compute_edge( double* start, const int nelem, const double xint, const int stride ) 00473 { 00474 for( int i = 1; i < nelem; i++ ) 00475 { 00476 start[i * stride] = start[0] + i * xint; 00477 start[nelem + 1 + i * stride] = start[nelem + 1] + i * xint; 00478 start[2 * ( nelem + 1 ) + i * stride] = start[2 * ( nelem + 1 )] + i * xint; 00479 } 00480 } 00481 00482 void compute_face( double* a, const int nelem, const double xint, const int stride1, const int stride2 ) 00483 { 00484 // 2D TFI on a face starting at a, with strides stride1 in ada and stride2 in tse 00485 for( int j = 1; j < nelem; j++ ) 00486 { 00487 double tse = j * xint; 00488 for( int i = 1; i < nelem; i++ ) 00489 { 00490 double ada = i * xint; 00491 00492 a[i * stride1 + j * stride2] = 00493 ( 1.0 - ada ) * a[i * stride1] + ada * a[i * stride1 + nelem * stride2] + 00494 ( 1.0 - tse ) * a[j * stride2] + tse * a[j * stride2 + nelem * stride1] - 00495 ( 1.0 - tse ) * ( 1.0 - ada ) * a[0] - ( 1.0 - tse ) * ada * a[nelem * stride1] - 00496 tse * ( 1.0 - ada ) * a[nelem * stride2] - tse * ada * a[nelem * ( stride1 + stride2 )]; 00497 a[nelem + 1 + i * stride1 + j * stride2] = 00498 ( 1.0 - ada ) * a[nelem + 1 + i * stride1] + ada * a[nelem + 1 + i * stride1 + nelem * stride2] + 00499 ( 1.0 - tse ) * a[nelem + 1 + j * stride2] + tse * a[nelem + 1 + j * stride2 + nelem * stride1] - 00500 ( 1.0 - tse ) * ( 1.0 - ada ) * a[nelem + 1 + 0] - 00501 ( 1.0 - tse ) * ada * a[nelem + 1 + nelem * stride1] - 00502 tse * ( 1.0 - ada ) * a[nelem + 1 + nelem * stride2] - 00503 tse * ada * a[nelem + 1 + nelem * ( stride1 + stride2 )]; 00504 a[2 * ( nelem + 1 ) + i * stride1 + j * stride2] = 00505 ( 1.0 - ada ) * a[2 * ( nelem + 1 ) + i * stride1] + 00506 ada * a[2 * ( nelem + 1 ) + i * stride1 + nelem * stride2] + 00507 ( 1.0 - tse ) * a[2 * ( nelem + 1 ) + j * stride2] + 00508 tse * a[2 * ( nelem + 1 ) + j * stride2 + nelem * stride1] - 00509 ( 1.0 - tse ) * ( 1.0 - ada ) * a[2 * ( nelem + 1 ) + 0] - 00510 ( 1.0 - tse ) * ada * a[2 * ( nelem + 1 ) + nelem * stride1] - 00511 tse * ( 1.0 - ada ) * a[2 * ( nelem + 1 ) + nelem * stride2] - 00512 tse * ada * a[2 * ( nelem + 1 ) + nelem * ( stride1 + stride2 )]; 00513 } 00514 } 00515 } 00516 00517 void build_coords( const int nelem, sidl::array< double >& coords ) 00518 { 00519 double ttime0, ttime1, utime1, stime1; 00520 print_time( false, ttime0, utime1, stime1 ); 00521 00522 // allocate the memory 00523 int numv = nelem + 1; 00524 int numv_sq = numv * numv; 00525 int tot_numv = numv * numv * numv; 00526 CHECK_SIZE( coords, 3 * tot_numv ); 00527 double* coords_ptr = ARRAY_PTR( coords, double ); 00528 00529 // use FORTRAN-like indexing 00530 #define VINDEX( i, j, k ) ( ( i ) + ( (j)*numv ) + ( (k)*numv_sq ) ) 00531 int idx; 00532 double scale1, scale2, scale3; 00533 // use these to prevent optimization on 1-scale, etc (real map wouldn't have 00534 // all these equal) 00535 scale1 = LENGTH / nelem; 00536 scale2 = LENGTH / nelem; 00537 scale3 = LENGTH / nelem; 00538 00539 #ifdef REALTFI 00540 // use a real TFI xform to compute coordinates 00541 // initialize positions of 8 corners 00542 coords_ptr[VINDEX( 0, 0, 0 )] = coords_ptr[VINDEX( 0, 0, 0 ) + nelem + 1] = 00543 coords_ptr[VINDEX( 0, 0, 0 ) + 2 * ( nelem + 1 )] = 0.0; 00544 coords_ptr[VINDEX( 0, nelem, 0 )] = coords_ptr[VINDEX( 0, nelem, 0 ) + 2 * ( nelem + 1 )] = 0.0; 00545 coords_ptr[VINDEX( 0, nelem, 0 ) + nelem + 1] = LENGTH; 00546 coords_ptr[VINDEX( 0, 0, nelem )] = coords_ptr[VINDEX( 0, 0, nelem ) + nelem + 1] = 0.0; 00547 coords_ptr[VINDEX( 0, 0, nelem ) + 2 * ( nelem + 1 )] = LENGTH; 00548 coords_ptr[VINDEX( 0, nelem, nelem )] = 0.0; 00549 coords_ptr[VINDEX( 0, nelem, nelem ) + nelem + 1] = coords_ptr[VINDEX( 0, nelem, nelem ) + 2 * ( nelem + 1 )] = 00550 LENGTH; 00551 coords_ptr[VINDEX( nelem, 0, 0 )] = LENGTH; 00552 coords_ptr[VINDEX( nelem, 0, 0 ) + nelem + 1] = coords_ptr[VINDEX( nelem, 0, 0 ) + 2 * ( nelem + 1 )] = 0.0; 00553 coords_ptr[VINDEX( nelem, 0, nelem )] = coords_ptr[VINDEX( nelem, 0, nelem ) + 2 * ( nelem + 1 )] = LENGTH; 00554 coords_ptr[VINDEX( nelem, 0, nelem ) + nelem + 1] = 0.0; 00555 coords_ptr[VINDEX( nelem, nelem, 0 )] = coords_ptr[VINDEX( nelem, nelem, 0 ) + nelem + 1] = LENGTH; 00556 coords_ptr[VINDEX( nelem, nelem, 0 ) + 2 * ( nelem + 1 )] = 0.0; 00557 coords_ptr[VINDEX( nelem, nelem, nelem )] = coords_ptr[VINDEX( nelem, nelem, nelem ) + nelem + 1] = 00558 coords_ptr[VINDEX( nelem, nelem, nelem ) + 2 * ( nelem + 1 )] = LENGTH; 00559 00560 // compute edges 00561 // i (stride=1) 00562 compute_edge( &coords_ptr[VINDEX( 0, 0, 0 )], nelem, scale1, 1 ); 00563 compute_edge( &coords_ptr[VINDEX( 0, nelem, 0 )], nelem, scale1, 1 ); 00564 compute_edge( &coords_ptr[VINDEX( 0, 0, nelem )], nelem, scale1, 1 ); 00565 compute_edge( &coords_ptr[VINDEX( 0, nelem, nelem )], nelem, scale1, 1 ); 00566 // j (stride=numv) 00567 compute_edge( &coords_ptr[VINDEX( 0, 0, 0 )], nelem, scale1, numv ); 00568 compute_edge( &coords_ptr[VINDEX( nelem, 0, 0 )], nelem, scale1, numv ); 00569 compute_edge( &coords_ptr[VINDEX( 0, 0, nelem )], nelem, scale1, numv ); 00570 compute_edge( &coords_ptr[VINDEX( nelem, 0, nelem )], nelem, scale1, numv ); 00571 // k (stride=numv^2) 00572 compute_edge( &coords_ptr[VINDEX( 0, 0, 0 )], nelem, scale1, numv_sq ); 00573 compute_edge( &coords_ptr[VINDEX( nelem, 0, 0 )], nelem, scale1, numv_sq ); 00574 compute_edge( &coords_ptr[VINDEX( 0, nelem, 0 )], nelem, scale1, numv_sq ); 00575 compute_edge( &coords_ptr[VINDEX( nelem, nelem, 0 )], nelem, scale1, numv_sq ); 00576 00577 // compute faces 00578 // i=0, nelem 00579 compute_face( &coords_ptr[VINDEX( 0, 0, 0 )], nelem, scale1, numv, numv_sq ); 00580 compute_face( &coords_ptr[VINDEX( nelem, 0, 0 )], nelem, scale1, numv, numv_sq ); 00581 // j=0, nelem 00582 compute_face( &coords_ptr[VINDEX( 0, 0, 0 )], nelem, scale1, 1, numv_sq ); 00583 compute_face( &coords_ptr[VINDEX( 0, nelem, 0 )], nelem, scale1, 1, numv_sq ); 00584 // k=0, nelem 00585 compute_face( &coords_ptr[VINDEX( 0, 0, 0 )], nelem, scale1, 1, numv ); 00586 compute_face( &coords_ptr[VINDEX( 0, 0, nelem )], nelem, scale1, 1, numv ); 00587 00588 // initialize corner indices 00589 int i000 = VINDEX( 0, 0, 0 ); 00590 int ia00 = VINDEX( nelem, 0, 0 ); 00591 int i0t0 = VINDEX( 0, nelem, 0 ); 00592 int iat0 = VINDEX( nelem, nelem, 0 ); 00593 int i00g = VINDEX( 0, 0, nelem ); 00594 int ia0g = VINDEX( nelem, 0, nelem ); 00595 int i0tg = VINDEX( 0, nelem, nelem ); 00596 int iatg = VINDEX( nelem, nelem, nelem ); 00597 double cX, cY, cZ; 00598 int adaInts = nelem; 00599 int tseInts = nelem; 00600 int gammaInts = nelem; 00601 00602 for( int i = 1; i < nelem; i++ ) 00603 { 00604 for( int j = 1; j < nelem; j++ ) 00605 { 00606 for( int k = 1; k < nelem; k++ ) 00607 { 00608 // idx = VINDEX(i,j,k); 00609 double tse = i * scale1; 00610 double ada = j * scale2; 00611 double gamma = k * scale3; 00612 double tm1 = 1.0 - tse; 00613 double am1 = 1.0 - ada; 00614 double gm1 = 1.0 - gamma; 00615 00616 cX = gm1 * ( am1 * ( tm1 * coords_ptr[i000] + tse * coords_ptr[i0t0] ) + 00617 ada * ( tm1 * coords_ptr[ia00] + tse * coords_ptr[iat0] ) ) + 00618 gamma * ( am1 * ( tm1 * coords_ptr[i00g] + tse * coords_ptr[i0tg] ) + 00619 ada * ( tm1 * coords_ptr[ia0g] + tse * coords_ptr[iatg] ) ); 00620 00621 cY = gm1 * ( am1 * ( tm1 * coords_ptr[i000] + tse * coords_ptr[i0t0] ) + 00622 ada * ( tm1 * coords_ptr[ia00] + tse * coords_ptr[iat0] ) ) + 00623 gamma * ( am1 * ( tm1 * coords_ptr[i00g] + tse * coords_ptr[i0tg] ) + 00624 ada * ( tm1 * coords_ptr[ia0g] + tse * coords_ptr[iatg] ) ); 00625 00626 cZ = gm1 * ( am1 * ( tm1 * coords_ptr[i000] + tse * coords_ptr[i0t0] ) + 00627 ada * ( tm1 * coords_ptr[ia00] + tse * coords_ptr[iat0] ) ) + 00628 gamma * ( am1 * ( tm1 * coords_ptr[i00g] + tse * coords_ptr[i0tg] ) + 00629 ada * ( tm1 * coords_ptr[ia0g] + tse * coords_ptr[iatg] ) ); 00630 00631 double* ai0k = &coords_ptr[VINDEX( k, 0, i )]; 00632 double* aiak = &coords_ptr[VINDEX( k, adaInts, i )]; 00633 double* a0jk = &coords_ptr[VINDEX( k, j, 0 )]; 00634 double* atjk = &coords_ptr[VINDEX( k, j, tseInts )]; 00635 double* aij0 = &coords_ptr[VINDEX( 0, j, i )]; 00636 double* aijg = &coords_ptr[VINDEX( gammaInts, j, i )]; 00637 00638 coords_ptr[VINDEX( i, j, k )] = ( am1 * ai0k[0] + ada * aiak[0] + tm1 * a0jk[0] + tse * atjk[0] + 00639 gm1 * aij0[0] + gamma * aijg[0] ) / 00640 2.0 - 00641 cX / 2.0; 00642 00643 coords_ptr[nelem + 1 + VINDEX( i, j, k )] = 00644 ( am1 * ai0k[nelem + 1] + ada * aiak[nelem + 1] + tm1 * a0jk[nelem + 1] + tse * atjk[nelem + 1] + 00645 gm1 * aij0[nelem + 1] + gamma * aijg[nelem + 1] ) / 00646 2.0 - 00647 cY / 2.0; 00648 00649 coords_ptr[2 * ( nelem + 1 ) + VINDEX( i, j, k )] = 00650 ( am1 * ai0k[2 * ( nelem + 1 )] + ada * aiak[2 * ( nelem + 1 )] + tm1 * a0jk[2 * ( nelem + 1 )] + 00651 tse * atjk[2 * ( nelem + 1 )] + gm1 * aij0[2 * ( nelem + 1 )] + 00652 gamma * aijg[2 * ( nelem + 1 )] ) / 00653 2.0 - 00654 cZ / 2.0; 00655 } 00656 } 00657 } 00658 00659 #else 00660 for( int i = 0; i < numv; i++ ) 00661 { 00662 for( int j = 0; j < numv; j++ ) 00663 { 00664 for( int k = 0; k < numv; k++ ) 00665 { 00666 idx = VINDEX( i, j, k ); 00667 // blocked coordinate ordering 00668 coords_ptr[idx] = i * scale1; 00669 coords_ptr[tot_numv + idx] = j * scale2; 00670 coords_ptr[2 * tot_numv + idx] = k * scale3; 00671 } 00672 } 00673 } 00674 #endif 00675 print_time( false, ttime1, utime1, stime1 ); 00676 std::cout << "TSTT/MOAB: TFI time = " << ttime1 - ttime0 << " sec" << std::endl; 00677 } 00678 00679 void build_connect( const int nelem, const int vstart, int*& connect ) 00680 { 00681 // allocate the memory 00682 int nume_tot = nelem * nelem * nelem; 00683 connect = new int[8 * nume_tot]; 00684 00685 int vijk; 00686 int numv = nelem + 1; 00687 int numv_sq = numv * numv; 00688 int idx = 0; 00689 for( int i = 0; i < nelem; i++ ) 00690 { 00691 for( int j = 0; j < nelem; j++ ) 00692 { 00693 for( int k = 0; k < nelem; k++ ) 00694 { 00695 vijk = vstart + VINDEX( i, j, k ); 00696 connect[idx++] = vijk; 00697 connect[idx++] = vijk + 1; 00698 connect[idx++] = vijk + 1 + numv; 00699 connect[idx++] = vijk + numv; 00700 connect[idx++] = vijk + numv * numv; 00701 connect[idx++] = vijk + 1 + numv * numv; 00702 connect[idx++] = vijk + 1 + numv + numv * numv; 00703 connect[idx++] = vijk + numv + numv * numv; 00704 assert( i <= numv * numv * numv ); 00705 } 00706 } 00707 } 00708 }
