MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /** @example ContinentsOnGlobe 00002 * Description: read a mesh on a sphere and boundaries of continents and major islands, 00003 * and write a boundaries mesh file (bound.vtk) and a file with sets for major continents 00004 * (map.h5m). Boundaries exist as 2 files, a list of boundary points and a list of loops, 00005 * representing each continent and major islands; there are 796 loops (islands). The first one has 00006 * 1239 edges/segments (Asia+Europe), while the last one has only 3. It must be a small island :) 00007 * ContinentsOnGlobe <input.h5m> 00008 * default values: poly2000.h5m : a mesh with 2000 polygons on a sphere of radius 1 00009 */ 00010 00011 #include "moab/Core.hpp" 00012 #include "moab/ReadUtilIface.hpp" 00013 #include <cmath> 00014 #include "moab/CartVect.hpp" 00015 00016 #include <iostream> 00017 #include <fstream> 00018 00019 using namespace moab; 00020 using namespace std; 00021 00022 string bd_name = string( MESH_DIR ) + string( "/../examples/earth/boundary_points.dat" ); 00023 string loops = string( MESH_DIR ) + string( "/../examples/earth/SaveLoopCounts" ); 00024 string input_file = string( MESH_DIR ) + string( "/../examples/earth/poly2000.h5m" ); 00025 00026 double getLat( CartVect p ) 00027 { 00028 p.normalize(); 00029 return asin( p[2] ); 00030 } 00031 double getLon( CartVect p ) 00032 { 00033 p.normalize(); 00034 double lon; 00035 00036 lon = atan2( p[1], p[0] ); 00037 00038 if( lon < -2.95 ) 00039 { // separate Asia/Europe from Americas 00040 return 2.0 * M_PI + lon; 00041 } 00042 else 00043 { 00044 return lon; 00045 } 00046 } 00047 00048 // we project sphere points on a 2d map. We decide if a point is in interior of a loop 00049 // with the span angle test; it will work for any island except Antarctica 00050 00051 bool interior_point( vector< double >& coords, int& startLoop, int& endLoop, double lat, double lon ) 00052 { 00053 // compute oriented angle between point and edges in the loop 00054 // if angle ~ +/-2Pi, it is in the interior 00055 double totalAngle = 0; 00056 for( int i = startLoop; i <= endLoop; i++ ) 00057 { 00058 double x1 = coords[2 * i], y1 = coords[2 * i + 1]; 00059 int i2 = i + 1; 00060 if( i == endLoop ) i2 = startLoop; 00061 double x2 = coords[2 * i2], y2 = coords[2 * i2 + 1]; 00062 CartVect P1( x1 - lat, y1 - lon, 0. ); 00063 CartVect P2( x2 - lat, y2 - lon, 0. ); 00064 CartVect cross = P1 * P2; 00065 double angle1 = angle( P1, P2 ); 00066 if( cross[2] < 0 ) angle1 = -angle1; 00067 totalAngle += angle1; 00068 } 00069 if( fabs( totalAngle + 2 * M_PI ) < 0.1 || fabs( totalAngle - 2 * M_PI ) < 0.1 ) return true; 00070 return false; 00071 } 00072 00073 int main( int argc, char** argv ) 00074 { 00075 // Get MOAB instance 00076 Interface* mb = new( std::nothrow ) Core; 00077 if( NULL == mb ) return 1; 00078 00079 if( argc > 1 ) 00080 { 00081 // User has input file for mesh file 00082 input_file = argv[1]; 00083 } 00084 00085 cout << "input file : " << input_file << "\n"; 00086 std::vector< double > coords; 00087 ifstream bdFile( bd_name.c_str() ); 00088 if( !bdFile ) 00089 { 00090 cout << endl << "Failed to open file " << bd_name << endl; 00091 ; 00092 return 1; 00093 } 00094 coords.resize( 0 ); 00095 while( !bdFile.eof() ) 00096 { 00097 double co; 00098 bdFile >> co; 00099 coords.push_back( co ); 00100 } 00101 cout << " number of boundary points:" << coords.size() / 3 << "\n"; 00102 /// get loops for boundaries 00103 vector< int > loopsindx; 00104 ifstream loopFile( loops.c_str() ); 00105 while( !loopFile.eof() ) 00106 { 00107 int indx; 00108 loopFile >> indx; 00109 loopsindx.push_back( indx ); 00110 } 00111 cout << "number of loops: " << loopsindx.size() / 2 << "\n"; 00112 // convert loops to lat-lon loops 00113 // it will be easier to determine in-out relations for points in 2d plane 00114 // careful with the international time zone; ( + - Pi longitude ) 00115 vector< double > coords2d; 00116 coords2d.resize( coords.size() / 3 * 2 ); 00117 for( int i = 0; i < (int)coords.size() / 3; i++ ) 00118 { 00119 CartVect p( coords[3 * i], coords[3 * i + 1], coords[3 * i + 2] ); 00120 coords2d[2 * i] = getLat( p ); 00121 coords2d[2 * i + 1] = getLon( p ); 00122 } 00123 00124 ErrorCode rval = mb->load_file( input_file.c_str() );MB_CHK_SET_ERR( rval, "Can't load file" ); 00125 // look at the center of element, and see if it is inside the loop 00126 00127 Range cells; 00128 rval = mb->get_entities_by_dimension( 0, 2, cells );MB_CHK_SET_ERR( rval, "Can't get cells" ); 00129 00130 cout << "number of cells: " << cells.size() << "\n"; 00131 00132 // tag for continents 00133 Tag tag1; 00134 int defa = -1; 00135 rval = mb->tag_get_handle( "continent", 1, MB_TYPE_INTEGER, tag1, MB_TAG_DENSE | MB_TAG_CREAT, &defa );MB_CHK_SET_ERR( rval, "Trouble creating continent tag" ); 00136 EntityHandle islandSets[6]; 00137 for( int loop_index = 0; loop_index < 6; loop_index++ ) 00138 { 00139 rval = mb->create_meshset( MESHSET_SET, islandSets[loop_index] );MB_CHK_SET_ERR( rval, "Can't create island set" ); 00140 int startLoop = loopsindx[2 * loop_index]; 00141 int endLoop = loopsindx[2 * loop_index + 1]; 00142 00143 vector< EntityHandle > interiorCells; 00144 for( Range::iterator cit = cells.begin(); cit != cells.end(); cit++ ) 00145 { 00146 EntityHandle cell = *cit; 00147 // see if it is in the interior of the loop 00148 CartVect center; 00149 rval = mb->get_coords( &cell, 1, &( center[0] ) );MB_CHK_SET_ERR( rval, "Can't get cell center coords" ); 00150 double lat = getLat( center ), lon = getLon( center ); 00151 // if NA, use some boxes too, for lat/lon 00152 // if (NorthAmerica && (lat < 0.15 || lon < M_PI || lon > 2*M_PI - 0.5) ) 00153 // continue; 00154 00155 if( interior_point( coords2d, startLoop, endLoop, lat, lon ) ) 00156 { 00157 interiorCells.push_back( cell ); 00158 rval = mb->tag_set_data( tag1, &cell, 1, &loop_index );MB_CHK_SET_ERR( rval, "Can't get tag on cell" ); 00159 } 00160 } 00161 00162 rval = mb->add_entities( islandSets[loop_index], &interiorCells[0], interiorCells.size() );MB_CHK_SET_ERR( rval, "Can't add entities to set" ); 00163 } 00164 00165 std::stringstream islandFile; 00166 00167 islandFile << "map.h5m"; 00168 00169 rval = mb->write_file( islandFile.str().c_str() );MB_CHK_SET_ERR( rval, "Can't write island file" ); 00170 return 0; 00171 }
