MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /** 00002 * MOAB, a Mesh-Oriented datABase, is a software component for creating, 00003 * storing and accessing finite element mesh data. 00004 * 00005 * Copyright 2004 Sandia Corporation. Under the terms of Contract 00006 * DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government 00007 * retains certain rights in this software. 00008 * 00009 * This library is free software; you can redistribute it and/or 00010 * modify it under the terms of the GNU Lesser General Public 00011 * License as published by the Free Software Foundation; either 00012 * version 2.1 of the License, or (at your option) any later version. 00013 * 00014 */ 00015 00016 //----------------------------------------------------------------------------- 00017 // Filename : ReadOBJ.hpp 00018 // 00019 // Purpose : Wavefront obj file reader 00020 // 00021 // Creators : Chelsea D'Angelo, Paul Wilson, Andrew Davis 00022 // 00023 // Date : 02/16 00024 // 00025 // Owner : Chelsea D'Angelo 00026 //----------------------------------------------------------------------------- 00027 00028 /** 00029 * This class will read in an obj file and populate a MOAB instance with the 00030 * vertex and connectivity information in the file. A specification for obj files 00031 * can be found here: https://en.wikipedia.org/wiki/Wavefront_.obj_file 00032 * This reader only supports a subset of the full file structure, namely, 00033 * object names, group names, vertices, and faces. 00034 * 00035 * Overview of the supported structure: 00036 * 00037 * Heading 00038 * Object line: o object_name 00039 * Group line: g group_name1 00040 * Vertex lines: v x y z 00041 * Face lines (tri): f v1 v2 v3 00042 * Face lines (quad): f v1 v2 v3 v4 00043 * 00044 * Lines that begin w/ anything other than 'o ', 'g ', 'v ', and 'f ' are not 00045 * supported. If a valid, but unsupported line is found, it will be ignored. 00046 * If an invalid line is found, an error will be produced. 00047 * Face lines that contain 'vertex\texture\normal' are handled by ignoring the 00048 * texture and normal 00049 * 00050 * 00051 * A new meshset will be created for each object or group in the file. 00052 * Each object and group must have a name, or the line will be ignored. 00053 * Groups are thought to be collections of elements with no dimension or category and 00054 * will therefore only be assigned name and id tags. 00055 * Objects are thought to be closed surfaces. A surface meshset will be 00056 * created for each object. A volume meshset that directly corresponds 00057 * to the surface meshset will also be created. These will have name, id, 00058 * categorty, and dimension tags. A parent-child relationship exists 00059 * between the volume and surface meshsets. 00060 * Vertices will be created and added to a global vertex meshset. 00061 * Triangular faces will be created and added as members of the surface meshets. 00062 */ 00063 00064 #ifndef READ_OBJ_HPP 00065 #define READ_OBJ_HPP 00066 00067 #ifndef IS_BUILDING_MB 00068 #error "ReadOBJ.hpp isn't supposed to be included into an application" 00069 #endif 00070 00071 #include <iostream> 00072 #include <fstream> 00073 #include <sstream> 00074 #include <vector> 00075 #include <map> 00076 00077 #include "moab/Interface.hpp" 00078 #include "moab/ReaderIface.hpp" 00079 #include "FileTokenizer.hpp" 00080 #include "moab/RangeMap.hpp" 00081 #include "MBTagConventions.hpp" 00082 00083 /* struct vertex is a structure that stores coordinates 00084 of vertices. This is a convenience structure making 00085 i/o easier. 00086 */ 00087 struct vertex 00088 { 00089 int vertex_id; 00090 double coord[3]; 00091 }; 00092 00093 /* struct face is a structure that stores connectivity. 00094 This is a convenience structure makin i/o easier. 00095 */ 00096 struct face 00097 { 00098 int face_id; 00099 moab::EntityHandle conn[3]; 00100 }; 00101 namespace moab 00102 { 00103 00104 /* Supported obj file keywords 00105 */ 00106 enum keyword_type 00107 { 00108 obj_undefined = 0, 00109 object_start, 00110 group_start, 00111 face_start, 00112 vertex_start, 00113 valid_unsupported 00114 }; 00115 00116 class ReadUtilIface; 00117 class GeomTopoTool; 00118 00119 class ReadOBJ : public ReaderIface 00120 { 00121 00122 public: 00123 //! factory method 00124 static ReaderIface* factory( Interface* ); 00125 00126 ErrorCode load_file( const char* file_name, 00127 const EntityHandle* file_set, 00128 const FileOptions& opts, 00129 const SubsetList* subset_list = 0, 00130 const Tag* file_id_tag = 0 ); 00131 00132 ErrorCode read_tag_values( const char* file_name, 00133 const char* tag_name, 00134 const FileOptions& opts, 00135 std::vector< int >& tag_values_out, 00136 const SubsetList* subset_list = 0 ); 00137 00138 //! Constructor 00139 ReadOBJ( Interface* impl = NULL ); 00140 00141 //! Destructor 00142 virtual ~ReadOBJ(); 00143 00144 private: 00145 ReadUtilIface* readMeshIface; 00146 00147 //! interface instance 00148 Interface* MBI; 00149 00150 GeomTopoTool* myGeomTool; 00151 00152 Tag geom_tag, id_tag, name_tag, category_tag, faceting_tol_tag, geometry_resabs_tag, obj_name_tag; 00153 00154 /* The keyword type function matches the first character extracted from each line to a type of 00155 * line 00156 */ 00157 keyword_type get_keyword( std::vector< std::string > tokens ); 00158 00159 /* The match function searches a list of map keys for a match with the token 00160 */ 00161 template < typename T > 00162 std::string match( const std::string& token, std::map< std::string, T >& tokenList ); 00163 00164 /* The tokenize function takes a string as input and splits it into 00165 * a vector of strings based on the delimiter 00166 */ 00167 static const char* delimiters; 00168 00169 void tokenize( const std::string& str, std::vector< std::string >& tokens, const char* delimiters ); 00170 00171 /* 00172 * The create_object funtion will create a new meshset for 00173 * each object that contains all vertices and faces 00174 */ 00175 ErrorCode create_new_object( std::string object_name, int object_id, EntityHandle& curr_obj_meshset ); 00176 00177 ErrorCode create_new_group( std::string object_name, int curr_object, EntityHandle& object_meshset ); 00178 00179 /* create_new_vertex converts tokenized string input to 00180 vertex structure 00181 */ 00182 ErrorCode create_new_vertex( std::vector< std::string > v_tokens, EntityHandle& vertex_eh ); 00183 00184 /* create_new_face converts tokenized string input to 00185 * face structure 00186 */ 00187 ErrorCode create_new_face( std::vector< std::string > f_tokens, 00188 const std::vector< EntityHandle >& vertex_list, 00189 EntityHandle& face_eh ); 00190 00191 /* 00192 * The split_quad function creates 1 new vertex and 4 new tri faces 00193 * from a quad face. 00194 */ 00195 00196 ErrorCode split_quad( std::vector< std::string > f_tokens, 00197 std::vector< EntityHandle >& vertex_list, 00198 Range& face_eh ); 00199 00200 ErrorCode create_tri_faces( std::vector< EntityHandle > quad_vert_eh, 00201 // EntityHandle center_vertex_eh, 00202 Range& face_eh ); 00203 }; 00204 00205 } // namespace moab 00206 00207 #endif
