MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /** @example TestExodusII.cpp 00002 * This example demonstrates how to retrieve material, dirichlet and neumann sets 00003 * from an ExodusII file. \n 00004 * Sets in MOAB contain entities and have a tag on them to give meaning to the entities. 00005 * Tag names: MATERIAL_SET", "DIRICHLET_SET" and "NEUMANN_SET" are reserved and 00006 * are associated with their corresponding entity sets. 00007 * Sets are traversed to find out the type number of entities contained in each set. \n 00008 * 00009 * <b>Steps in this example </b>: 00010 * -# Instantiate MOAB 00011 * -# Get input mesh file name and load it. 00012 * -# Loop over the three sets: material, dirichlet and neumann 00013 * -# Get TagHandle and EntitySet(corresponding to the TagHandle) 00014 * -# Loop thru all the EntitySet's 00015 * -# Get the set id and entities in this set 00016 * -# Destroy the MOAB instance 00017 * 00018 * 00019 * <b> To compile: </b> 00020 * make TestExodusII MOAB_DIR=<installdir> \n 00021 * 00022 * <b> To run: </b> 00023 * -# TestExodusII <mesh-file> \n 00024 * -# TestExodusII (This uses the default <mesh-file>: 00025 * <MOAB_SRC_DIR>/MeshFiles/unittest/mbtest2.g) 00026 */ 00027 #include <iostream> 00028 00029 // Include header for MOAB instance and range 00030 #include "moab/Core.hpp" 00031 00032 using namespace moab; 00033 using namespace std; 00034 00035 string test_file_name = string( MESH_DIR ) + string( "/mbtest2.g" ); 00036 int main( int argc, char** argv ) 00037 { 00038 #ifdef MOAB_HAVE_NETCDF 00039 // Get MOAB instance 00040 Interface* mb = new( std::nothrow ) Core; 00041 if( NULL == mb ) return 1; 00042 00043 // Get the material set tag handle 00044 Tag mtag; 00045 ErrorCode rval; 00046 const char* tag_nms[] = { "MATERIAL_SET", "DIRICHLET_SET", "NEUMANN_SET" }; 00047 Range sets, set_ents; 00048 00049 // Load a file 00050 if( argc == 1 ) 00051 { 00052 cout << "Running default case, loading " << test_file_name << endl; 00053 cout << "Usage: " << argv[0] << " <filename>\n" << endl; 00054 rval = mb->load_file( test_file_name.c_str() );MB_CHK_ERR( rval ); 00055 } 00056 else 00057 { 00058 rval = mb->load_file( argv[argc - 1] );MB_CHK_ERR( rval ); 00059 cout << "Loaded mesh file: " << argv[argc - 1] << endl; 00060 } 00061 00062 // Loop over set types 00063 for( int i = 0; i < 3; i++ ) 00064 { 00065 rval = mb->tag_get_handle( tag_nms[i], 1, MB_TYPE_INTEGER, mtag );MB_CHK_ERR( rval ); 00066 00067 // Get all the sets of that type in the mesh 00068 sets.clear(); 00069 rval = mb->get_entities_by_type_and_tag( 0, MBENTITYSET, &mtag, NULL, 1, sets );MB_CHK_ERR( rval ); 00070 00071 // Iterate over each set, getting entities 00072 Range::iterator set_it; 00073 for( set_it = sets.begin(); set_it != sets.end(); ++set_it ) 00074 { 00075 EntityHandle this_set = *set_it; 00076 00077 // Get the id for this set 00078 int set_id; 00079 rval = mb->tag_get_data( mtag, &this_set, 1, &set_id );MB_CHK_ERR( rval ); 00080 00081 // Get the entities in the set, recursively 00082 rval = mb->get_entities_by_handle( this_set, set_ents, true );MB_CHK_ERR( rval ); 00083 00084 cout << tag_nms[i] << " " << set_id << " has " << set_ents.size() << " entities:" << endl; 00085 00086 // Print the entities contained in this set 00087 set_ents.print( " " ); 00088 set_ents.clear(); 00089 } 00090 } 00091 00092 delete mb; 00093 #else 00094 cout << " This test needs moab configured with netcdf \n"; 00095 #endif 00096 00097 return 0; 00098 }
