MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /** 00002 * MOAB, a Mesh-Oriented datABase, is a software component for creating, 00003 * storing and accessing finite element mesh data. 00004 * 00005 * Copyright 2004 Sandia Corporation. Under the terms of Contract 00006 * DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government 00007 * retains certain rights in this software. 00008 * 00009 * This library is free software; you can redistribute it and/or 00010 * modify it under the terms of the GNU Lesser General Public 00011 * License as published by the Free Software Foundation; either 00012 * version 2.1 of the License, or (at your option) any later version. 00013 * 00014 */ 00015 00016 //------------------------------------------------------------------------- 00017 // Filename : WriteSLAC.hpp 00018 // 00019 // Purpose : ExodusII writer 00020 // 00021 // Special Notes : Lots of code taken from verde implementation 00022 // 00023 // Creator : Corey Ernst 00024 // 00025 // Date : 8/02 00026 // 00027 // Owner : Corey Ernst 00028 //------------------------------------------------------------------------- 00029 00030 #ifndef WRITESLAC_HPP 00031 #define WRITESLAC_HPP 00032 00033 #ifndef IS_BUILDING_MB 00034 #error "WriteSLAC.hpp isn't supposed to be included into an application" 00035 #endif 00036 00037 #include <vector> 00038 #include <string> 00039 00040 #include "moab/Forward.hpp" 00041 #include "moab/Range.hpp" 00042 #include "moab/ExoIIInterface.hpp" 00043 #include "moab/WriterIface.hpp" 00044 00045 namespace moab 00046 { 00047 00048 class WriteUtilIface; 00049 00050 class WriteSLAC : public WriterIface 00051 { 00052 00053 public: 00054 //! Constructor 00055 WriteSLAC( Interface* impl ); 00056 00057 //! Destructor 00058 virtual ~WriteSLAC(); 00059 00060 static WriterIface* factory( Interface* ); 00061 00062 //! writes out a file 00063 ErrorCode write_file( const char* file_name, 00064 const bool overwrite, 00065 const FileOptions& opts, 00066 const EntityHandle* output_list, 00067 const int num_sets, 00068 const std::vector< std::string >& qa_list, 00069 const Tag* tag_list = NULL, 00070 int num_tags = 0, 00071 int export_dimension = 3 ); 00072 00073 //! struct used to hold data for each block to be output; used by 00074 //! initialize_file to initialize the file header for increased speed 00075 struct MaterialSetData 00076 { 00077 int id; 00078 int number_elements; 00079 int number_nodes_per_element; 00080 int number_attributes; 00081 ExoIIElementType element_type; 00082 EntityType moab_type; 00083 Range* elements; 00084 }; 00085 00086 //! struct used to hold data for each nodeset to be output; used by 00087 //! initialize_file to initialize the file header for increased speed 00088 struct DirichletSetData 00089 { 00090 int id; 00091 int number_nodes; 00092 std::vector< EntityHandle > nodes; 00093 std::vector< double > node_dist_factors; 00094 }; 00095 00096 //! struct used to hold data for each sideset to be output; used by 00097 //! initialize_file to initialize the file header for increased speed 00098 struct NeumannSetData 00099 { 00100 int id; 00101 int number_elements; 00102 std::vector< EntityHandle > elements; 00103 std::vector< int > side_numbers; 00104 EntityHandle mesh_set_handle; 00105 }; 00106 00107 protected: 00108 //! number of dimensions in this file 00109 // int number_dimensions(); 00110 00111 //! open a file for writing 00112 ErrorCode open_file( const char* filename ); 00113 00114 //! contains the general information about a mesh 00115 class MeshInfo 00116 { 00117 public: 00118 unsigned int num_dim; 00119 unsigned int num_nodes; 00120 unsigned int num_elements; 00121 unsigned int num_matsets; 00122 unsigned int num_int_hexes; 00123 unsigned int num_int_tets; 00124 Range bdy_hexes, bdy_tets; 00125 Range nodes; 00126 00127 MeshInfo() 00128 : num_dim( 0 ), num_nodes( 0 ), num_elements( 0 ), num_matsets( 0 ), num_int_hexes( 0 ), num_int_tets( 0 ) 00129 { 00130 } 00131 }; 00132 00133 private: 00134 //! interface instance 00135 Interface* mbImpl; 00136 WriteUtilIface* mWriteIface; 00137 00138 //! file name 00139 std::string fileName; 00140 int ncFile; 00141 00142 //! Cached tags for reading. Note that all these tags are defined when the 00143 //! core is initialized. 00144 Tag mMaterialSetTag; 00145 Tag mDirichletSetTag; 00146 Tag mNeumannSetTag; 00147 Tag mGlobalIdTag; 00148 Tag mMatSetIdTag; 00149 00150 Tag mEntityMark; // used to say whether an entity will be exported 00151 00152 ErrorCode gather_mesh_information( MeshInfo& mesh_info, 00153 std::vector< MaterialSetData >& matset_info, 00154 std::vector< NeumannSetData >& neuset_info, 00155 std::vector< DirichletSetData >& dirset_info, 00156 std::vector< EntityHandle >& matsets, 00157 std::vector< EntityHandle >& neusets, 00158 std::vector< EntityHandle >& dirsets ); 00159 00160 ErrorCode initialize_file( MeshInfo& mesh_info ); 00161 00162 ErrorCode write_nodes( const int num_nodes, const Range& nodes, const int dimension ); 00163 00164 ErrorCode write_matsets( MeshInfo& mesh_info, 00165 std::vector< MaterialSetData >& matset_data, 00166 std::vector< NeumannSetData >& neuset_data ); 00167 00168 ErrorCode get_valid_sides( Range& elems, const int sense, WriteSLAC::NeumannSetData& sideset_data ); 00169 00170 void reset_matset( std::vector< MaterialSetData >& matset_info ); 00171 00172 ErrorCode get_neuset_elems( EntityHandle neuset, int current_sense, Range& forward_elems, Range& reverse_elems ); 00173 00174 ErrorCode gather_interior_exterior( MeshInfo& mesh_info, 00175 std::vector< MaterialSetData >& matset_data, 00176 std::vector< NeumannSetData >& neuset_data ); 00177 }; 00178 00179 } // namespace moab 00180 00181 #endif
