MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /** 00002 * MOAB, a Mesh-Oriented datABase, is a software component for creating, 00003 * storing and accessing finite element mesh data. 00004 * 00005 * Copyright 2004 Sandia Corporation. Under the terms of Contract 00006 * DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government 00007 * retains certain rights in this software. 00008 * 00009 * This library is free software; you can redistribute it and/or 00010 * modify it under the terms of the GNU Lesser General Public 00011 * License as published by the Free Software Foundation; either 00012 * version 2.1 of the License, or (at your option) any later version. 00013 * 00014 */ 00015 00016 #ifndef MB_WRITE_UTIL_HPP 00017 #define MB_WRITE_UTIL_HPP 00018 00019 #ifndef IS_BUILDING_MB 00020 #error "WriteUtil.hpp isn't supposed to be included into an application" 00021 #endif 00022 00023 #include "moab/WriteUtilIface.hpp" 00024 00025 namespace moab 00026 { 00027 00028 class Core; 00029 00030 class WriteUtil : public WriteUtilIface 00031 { 00032 private: 00033 //! Pointer to the Core 00034 Core* mMB; 00035 00036 public: 00037 //! Constructor takes Core pointer 00038 WriteUtil( Core* mdb ); 00039 00040 //! Destructor 00041 ~WriteUtil() {} 00042 00043 //! Check if the specified file already exists. 00044 //! Returns MB_SUCCESS if file does not exist, MB_ALREADY_ALLOCATED 00045 //! if file does exist, or MB_FAILURE for some other error condition. 00046 virtual ErrorCode check_doesnt_exist( const char* file_name ); 00047 00048 //! Gather all entities in the mesh, or in the sets specified 00049 virtual ErrorCode gather_entities( 00050 Range& all_ents, /**< range in which entities are returned */ 00051 const EntityHandle* ent_sets = NULL, /**< entity sets whose contents are to be gathered */ 00052 const int num_sets = 0 /**< number of sets in list */ ); 00053 00054 //! Gets arrays for coordinate data from the MB 00055 ErrorCode get_node_coords( const int num_arrays, 00056 const int num_nodes, 00057 const Range& entities, 00058 Tag node_id_tag, 00059 const int start_node_id, 00060 std::vector< double* >& arrays ); 00061 00062 /** Get an array of coordinate values for nodes 00063 * 00064 * Given a range of node handles, retrieve a single or multiple coordinate 00065 * value(s) for each. 00066 * 00067 * Failure conditions: 00068 * - invalid entity handles (not vertices, non-existent entity, etc.) 00069 * - range is empty (<code>iter == end</code>) 00070 * - <code>output_array</code> is null 00071 * - insufficient space in <code>output_array</code> 00072 * 00073 *\param which_array The coordinate to retrieve (0->X, 1->Y, 2->Z, -1->all) 00074 *\param begin The first node handle. 00075 *\param end One past the last node handle. 00076 *\param output_size The size of <code>output_array</code>. 00077 *\param output_array The memory in which to write the node coordinates. 00078 *\author Jason Kraftcheck 00079 */ 00080 ErrorCode get_node_coords( const int which_array, 00081 Range::const_iterator begin, 00082 const Range::const_iterator& end, 00083 const size_t output_size, 00084 double* const output_array ); 00085 00086 /** Get connectivity for elements 00087 * 00088 * Get the connectivity list for a range of elements. 00089 * 00090 *\param num_elements Number of elements for which connectivity is needed 00091 *\param vertices_per_elem Number of vertices to retrieve for each 00092 * element. 00093 *\param node_id_tag A tag with integer values. 00094 *\param entities Entities being queried 00095 *\param element_id_tag If non-zero, elements are tagged with an id starting at start_element_id 00096 *\param start_element_id Starting id value for element_id_tag 00097 *\param add_sizes If true, writes size of connect array before connectivity in array 00098 */ 00099 ErrorCode get_element_connect( const int num_elements, 00100 const int verts_per_element, 00101 Tag node_id_tag, 00102 const Range& entities, 00103 Tag element_id_tag, 00104 int start_element_id, 00105 int* array, 00106 bool add_sizes = false ); 00107 00108 /** Get connectivity for elements 00109 * 00110 * Get the connectivity list for a range of elements. 00111 * 00112 * Failure cases: 00113 * - Passed range is empty (<code>begin == end</code>). 00114 * - <code>vertices_per_elem</code> is less than one 00115 * - <code>element_array</code> is null. 00116 * - The range contains invalid handles (non-existent entities, 00117 * not an element, etc.) 00118 * - Retrieving ID tag for an entity failed. 00119 * - Insufficient space in passed array. 00120 * 00121 *\param begin The first element handle 00122 *\param end One past the last element handle 00123 *\param vertices_per_elem Number of vertices to retrieve for each 00124 * element. If the element has more vertices, the 00125 * element connectivity will be truncated. If 00126 * <code>vertices_per_elem</code> is greater than the 00127 * number of nodes for an element, the data will be 00128 * padded with zeros. 00129 *\param node_id_tag A tag with integer values. 00130 *\param array_size The length of <code>element_array</code> 00131 *\param element_array The memory location at which to store the 00132 * connectivity list. 00133 *\param add_sizes If true, writes size of connect array before connectivity in array 00134 *\author Jason Kraftcheck 00135 */ 00136 ErrorCode get_element_connect( Range::const_iterator begin, 00137 const Range::const_iterator& end, 00138 const int vertices_per_elem, 00139 Tag node_id_tag, 00140 const size_t array_size, 00141 int* const element_array, 00142 bool add_sizes = false ); 00143 00144 /** Get connectivity for elements 00145 * 00146 * Get the connectivity list for a range of elements. 00147 * 00148 * Failure cases: 00149 * - Passed range is empty (<code>begin == end</code>). 00150 * - <code>vertices_per_elem</code> is less than one 00151 * - <code>element_array</code> is null. 00152 * - The range contains invalid handles (non-existent entities, 00153 * not an element, etc.) 00154 * - Insufficient space in passed array. 00155 * 00156 *\param begin The first element handle 00157 *\param end One past the last element handle 00158 *\param vertices_per_elem Number of vertices to retrieve for each 00159 * element. If the element has more vertices, the 00160 * element connectivity will be truncated. If 00161 * <code>vertices_per_elem</code> is greater than the 00162 * number of nodes for an element, the data will be 00163 * padded with zeros. 00164 *\param array_size The length of <code>element_array</code> 00165 *\param element_array The memory location at which to store the 00166 * connectivity list. 00167 *\author Jason Kraftcheck 00168 */ 00169 virtual ErrorCode get_element_connect( Range::const_iterator begin, 00170 const Range::const_iterator& end, 00171 const int vertices_per_elem, 00172 const size_t array_size, 00173 EntityHandle* const element_array ); 00174 00175 /** Get poly (polygon or polyhedron) connectivity size 00176 *\param begin First iterator in range of poly 00177 *\param end One past last in range of poly. 00178 *\param connectivity_size The length of the connectivity list 00179 * For the specified range of polyhedra. 00180 *\author Jason Kraftcheck 00181 */ 00182 virtual ErrorCode get_poly_connect_size( Range::const_iterator begin, 00183 const Range::const_iterator& end, 00184 int& connectivity_size ); 00185 00186 /** Get poly (polygon or polyhedron) connectivity. 00187 * 00188 * This function will add as many polys as possible to the 00189 * passed arrays given the sizes of those arrays. It will 00190 * then pass back position at which it stopped and the sizes 00191 * of the data written to the arrays. 00192 * 00193 *\param iter As input, the first element handle. 00194 * As output, one past the last element handle 00195 * for which data was written to the arrays. 00196 *\param end The iterator at which to stop. 00197 *\param node_id_tag A tag with integer values. 00198 *\param element_array_len As input, length of <code>element_array</code>. 00199 * As output, the number of entries written in that 00200 * array. 00201 *\param element_array The memory location at which to store the 00202 * connectivity list. 00203 *\param index_array_len As input, the length of <code>index_array</code>. 00204 * As output, the number of entries written in that 00205 * array. 00206 *\param index_array The memory location at which to store offsets. 00207 *\param index_offset Value to offset (add to) index values. As output 00208 * the input value plus the amount of data 00209 * written to the element array. (The value you 00210 * presumably want to pass to the next call.) 00211 *\author Jason Kraftcheck 00212 */ 00213 virtual ErrorCode get_poly_connect( Range::const_iterator& iter, 00214 const Range::const_iterator& end, 00215 const Tag node_id_tag, 00216 size_t& handle_array_len, 00217 int* const handle_array, 00218 size_t& index_array_len, 00219 int* const index_array, 00220 int& index_offset ); 00221 00222 //! Get a set of nodes that represent a set of elements 00223 ErrorCode gather_nodes_from_elements( const Range& elements, const Tag node_bit_mark_tag, Range& nodes ); 00224 00225 //! Assign ids to input elements starting with start_id, written to id_tag 00226 //! if zero, assigns to GLOBAL_ID_TAG_NAME 00227 ErrorCode assign_ids( Range& elements, Tag id_tag, const int start_id ); 00228 00229 /** Get explicit adjacencies 00230 * 00231 * Get explicit adjacences stored in database. 00232 * Does not create any explicit adjacencies or search for 00233 * implicit ones. 00234 * 00235 *\param entity The entity to retrieve adjacencies for. 00236 *\param id_tag The global ID tag 00237 *\param adj The output list of global IDs of adjacent entities. 00238 */ 00239 ErrorCode get_adjacencies( EntityHandle entity, Tag id_tag, std::vector< int >& adj ); 00240 00241 ErrorCode get_adjacencies( EntityHandle entity, const EntityHandle*& adj_array, int& num_adj ); 00242 00243 /**\brief Get list of tags to write. 00244 * 00245 * Get the list of tags to write to the file, possibly using 00246 * an optional user-specified tag list. This function consolidates 00247 * some common code for file writers to use to figure out what 00248 * tag data to write to the file. It provides the following features: 00249 * o filter list based on user-specified array of tag handles 00250 * o filter internal tags (those for which the name is prefixed with 00251 * two underscore characters) 00252 * o filter anonymous tags 00253 * o optionally filter variable-length tags. 00254 * 00255 *\author Jason Kraftcheck 00256 *\param result_list List of tag handles for which to write data 00257 *\param user_tag_list Optional array of tag handles passed by user 00258 * to write to file. 00259 *\param include_variable_length_tags If false, return only fixed-length 00260 * tags. 00261 */ 00262 virtual ErrorCode get_tag_list( std::vector< Tag >& result_list, 00263 const Tag* user_tag_list = 0, 00264 int user_tag_list_length = 0, 00265 bool include_variable_length_tags = true ); 00266 00267 /*\brief Get pointers to internal storage of entity data 00268 * 00269 * Get pointers to element connectivity or set content storage. 00270 *\param query_begin Start of range of entities for which to return results 00271 *\param query_end End of range of entities for which to return results. 00272 *\param output_pointer_array Result list of pointers. Points to either 00273 * element connectivity or set contents. Note: set contents 00274 * may be in range-compacted format. 00275 *\param lengths Optional per-entity length of list. If passed, then 00276 * always set, for each entity, to the number of values in the 00277 * array passed back in \c output_pointer_array 00278 *\param relation If entity is entity set, which set data to return 00279 * (contents array, parent array, or child array). If 00280 * entity is an element, then CONTENTS for complete connectivity 00281 * or TOPOLOGICAL for only corner vertices. 00282 *\param flags Optional per-entity flag values. If passed, then 00283 * always set to zero for elements and set to set creation 00284 * flags for entity sets. 00285 *\return MB_STRUCTURED_MESH if one or more input elements are stored as 00286 * structured mesh and therefore do not have explicit storage. 00287 * MB_TYPE_OUT_OF_RANGE if called for vertices. 00288 */ 00289 virtual ErrorCode get_entity_list_pointers( Range::const_iterator query_begin, 00290 Range::const_iterator query_end, 00291 EntityHandle const** output_pointer_array, 00292 EntityListType relation = CONTENTS, 00293 int* lengths = 0, 00294 unsigned char* flags = 0 ); 00295 00296 /*\brief Get pointers to internal storage of entity data 00297 * 00298 * Get pointers to element connectivity or set content storage. 00299 *\param entities Pointer to list of entities for which to return results 00300 *\param num_entities Number of entities in list 00301 *\param output_pointer_array Result list of pointers. Points to either 00302 * element connectivity or set contents. Note: set contents 00303 * may be in range-compacted format. 00304 *\param lengths Optional per-entity length of list. If passed, then 00305 * always set, for each entity, to the number of values in the 00306 * array passed back in \c output_pointer_array 00307 *\param relation If entity is entity set, which set data to return 00308 * (contents array, parent array, or child array). If 00309 * entity is an element, then CONTENTS for complete connectivity 00310 * or TOPOLOGICAL for only corner vertices. 00311 *\param flags Optional per-entity flag values. If passed, then 00312 * always set to zero for elements and set to set creation 00313 * flags for entity sets. 00314 *\return MB_STRUCTURED_MESH if one or more input elements are stored as 00315 * structured mesh and therefore do not have explicit storage. 00316 * MB_TYPE_OUT_OF_RANGE if called for vertices. 00317 */ 00318 virtual ErrorCode get_entity_list_pointers( EntityHandle const* entities, 00319 int num_entities, 00320 EntityHandle const** output_pointer_array, 00321 EntityListType relation = CONTENTS, 00322 int* lengths = 0, 00323 unsigned char* flags = 0 ); 00324 }; 00325 00326 } // namespace moab 00327 00328 #endif
