MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 #include "moab/Core.hpp" 00002 #include "moab/CpuTimer.hpp" 00003 #include "DataCoupler.hpp" 00004 #include "ElemUtil.hpp" 00005 #include "TestUtil.hpp" 00006 00007 #include <iostream> 00008 #include <iomanip> 00009 #include <sstream> 00010 #include <cassert> 00011 00012 #ifdef MOAB_HAVE_MPI 00013 #include "moab/ParallelComm.hpp" 00014 #include "MBParallelConventions.h" 00015 #endif 00016 00017 using namespace moab; 00018 00019 #define PRINT_LAST_ERROR \ 00020 if( MB_SUCCESS != result ) \ 00021 { \ 00022 std::string tmp_str; \ 00023 std::cout << "Failure; message:" << std::endl; \ 00024 mbImpl->get_last_error( tmp_str ); \ 00025 std::cout << tmp_str << std::endl; \ 00026 MPI_Abort( MPI_COMM_WORLD, result ); \ 00027 return result; \ 00028 } 00029 00030 // Print usage 00031 void print_usage( char** argv ) 00032 { 00033 std::cerr << "Usage: "; 00034 std::cerr << argv[0] 00035 << " -meshes <source_mesh> <target_mesh> -itag <interp_tag> [-gnorm <gnorm_tag>] " 00036 "[-ssnorm <ssnorm_tag> <ssnorm_selection>] [-ropts <roptions>] [-outfile " 00037 "<out_file> [-wopts <woptions>]] [-dbgout [<dbg_file>]]" 00038 << std::endl; 00039 std::cerr << " -meshes" << std::endl; 00040 std::cerr << " Read in mesh files <source_mesh> and <target_mesh>." << std::endl; 00041 std::cerr << " -itag" << std::endl; 00042 std::cerr << " Interpolate tag <interp_tag> from source mesh to target mesh." << std::endl; 00043 std::cerr << " -gnorm" << std::endl; 00044 std::cerr << " Normalize the value of tag <gnorm_tag> over then entire mesh and save to" << std::endl; 00045 std::cerr << " tag \"<gnorm_tag>_normf\" on the mesh set. Do this for all meshes." << std::endl; 00046 std::cerr << " -ssnorm" << std::endl; 00047 std::cerr << " Normalize the value of tag <ssnorm_tag> over subsets of a mesh and save to" << std::endl; 00048 std::cerr << " tag \"<ssnorm_tag>_normf\" on the Entity Set for each subset. Subsets " 00049 "are selected" 00050 << std::endl; 00051 std::cerr << " using criteria in <ssnorm_selection>. Do this for all meshes." << std::endl; 00052 std::cerr << " -ropts" << std::endl; 00053 std::cerr << " Read in the mesh files using options in <roptions>." << std::endl; 00054 std::cerr << " -outfile" << std::endl; 00055 std::cerr << " Write out target mesh to <out_file>." << std::endl; 00056 std::cerr << " -wopts" << std::endl; 00057 std::cerr << " Write out mesh files using options in <woptions>." << std::endl; 00058 std::cerr << " -dbgout" << std::endl; 00059 std::cerr << " Write stdout and stderr streams to the file \'<dbg_file>.txt\'." << std::endl; 00060 std::cerr << " -eps" << std::endl; 00061 std::cerr << " epsilon" << std::endl; 00062 std::cerr << " -meth <method> (0=CONSTANT, 1=LINEAR_FE, 2=QUADRATIC_FE, 3=SPECTRAL)" << std::endl; 00063 } 00064 00065 #ifdef MOAB_HAVE_HDF5 00066 00067 ErrorCode get_file_options( int argc, 00068 char** argv, 00069 std::vector< std::string >& meshFiles, 00070 DataCoupler::Method& method, 00071 std::string& interpTag, 00072 std::string& gNormTag, 00073 std::string& ssNormTag, 00074 std::vector< const char* >& ssTagNames, 00075 std::vector< const char* >& ssTagValues, 00076 std::string& readOpts, 00077 std::string& outFile, 00078 std::string& writeOpts, 00079 std::string& dbgFile, 00080 bool& help, 00081 double& epsilon ); 00082 00083 // ErrorCode get_file_options(int argc, char **argv, 00084 // std::vector<const char*> &filenames, 00085 // std::string &tag_name, 00086 // std::string &out_fname, 00087 // std::string &opts); 00088 00089 #ifdef MOAB_HAVE_MPI 00090 ErrorCode report_iface_ents( Interface* mbImpl, std::vector< ParallelComm* >& pcs, bool print_results ); 00091 #endif 00092 00093 ErrorCode test_interpolation( Interface* mbImpl, 00094 DataCoupler::Method method, 00095 std::string& interpTag, 00096 std::string& gNormTag, 00097 std::string& ssNormTag, 00098 std::vector< const char* >& ssTagNames, 00099 std::vector< const char* >& ssTagValues, 00100 std::vector< ParallelComm* >& pcs, 00101 double& instant_time, 00102 double& pointloc_time, 00103 double& interp_time, 00104 double& gnorm_time, 00105 double& ssnorm_time, 00106 double& toler ); 00107 00108 void reduceMax( double& v ) 00109 { 00110 double buf; 00111 00112 MPI_Barrier( MPI_COMM_WORLD ); 00113 MPI_Allreduce( &v, &buf, 1, MPI_DOUBLE, MPI_MAX, MPI_COMM_WORLD ); 00114 00115 v = buf; 00116 } 00117 00118 int main( int argc, char** argv ) 00119 { 00120 #ifdef MOAB_HAVE_MPI 00121 // Need to init MPI first, to tell how many procs and rank 00122 int err = MPI_Init( &argc, &argv ); 00123 if( err != 0 ) 00124 { 00125 std::cout << "MPI Initialization did not succeed.\n"; 00126 exit( 1 ); 00127 } 00128 #endif 00129 00130 std::vector< const char* > ssTagNames, ssTagValues; 00131 std::vector< std::string > meshFiles; 00132 std::string interpTag, gNormTag, ssNormTag, readOpts, outFile, writeOpts, dbgFile; 00133 DataCoupler::Method method = DataCoupler::CONSTANT; 00134 00135 ErrorCode result = MB_SUCCESS; 00136 bool help = false; 00137 double toler = 5.e-10; 00138 result = get_file_options( argc, argv, meshFiles, method, interpTag, gNormTag, ssNormTag, ssTagNames, ssTagValues, 00139 readOpts, outFile, writeOpts, dbgFile, help, toler ); 00140 00141 if( result != MB_SUCCESS || help ) 00142 { 00143 print_usage( argv ); 00144 #ifdef MOAB_HAVE_MPI 00145 err = MPI_Finalize(); 00146 if( err != 0 ) 00147 { 00148 std::cout << "MPI Initialization did not succeed.\n"; 00149 exit( 1 ); 00150 } 00151 #endif 00152 return 1; 00153 } 00154 00155 int nprocs = 1, rank = 0; 00156 00157 #ifdef MOAB_HAVE_MPI 00158 err = MPI_Comm_size( MPI_COMM_WORLD, &nprocs ); 00159 err = MPI_Comm_rank( MPI_COMM_WORLD, &rank ); 00160 std::vector< ParallelComm* > pcs( meshFiles.size() ); 00161 #endif 00162 00163 // Redirect stdout and stderr if dbgFile is not null 00164 if( !dbgFile.empty() ) 00165 { 00166 std::stringstream dfname; 00167 dfname << dbgFile << rank << ".txt"; 00168 if( !std::freopen( dfname.str().c_str(), "a", stdout ) ) return 2; 00169 if( !std::freopen( dfname.str().c_str(), "a", stderr ) ) return 2; 00170 } 00171 00172 // Create MOAB instance based on that 00173 Interface* mbImpl = new( std::nothrow ) Core(); 00174 if( NULL == mbImpl ) return 1; 00175 00176 // Read in mesh(es) 00177 00178 // Create root sets for each mesh using moab 00179 std::vector< EntityHandle > roots( meshFiles.size() ); 00180 00181 for( unsigned int i = 0; i < meshFiles.size(); i++ ) 00182 { 00183 std::string newReadopts; 00184 std::ostringstream extraOpt; 00185 #ifdef MOAB_HAVE_MPI 00186 pcs[i] = new ParallelComm( mbImpl, MPI_COMM_WORLD ); 00187 int index = pcs[i]->get_id(); 00188 extraOpt << ";PARALLEL_COMM=" << index; 00189 newReadopts = readOpts + extraOpt.str(); 00190 #endif 00191 00192 result = mbImpl->create_meshset( MESHSET_SET, roots[i] ); 00193 PRINT_LAST_ERROR; 00194 result = mbImpl->load_file( meshFiles[i].c_str(), &roots[i], newReadopts.c_str() ); 00195 PRINT_LAST_ERROR; 00196 } 00197 00198 #ifdef MOAB_HAVE_MPI 00199 result = report_iface_ents( mbImpl, pcs, true ); 00200 PRINT_LAST_ERROR; 00201 #endif 00202 00203 double instant_time = 0.0, pointloc_time = 0.0, interp_time = 0.0, gnorm_time = 0.0, ssnorm_time = 0.0; 00204 // Test interpolation and global normalization and subset normalization 00205 00206 result = test_interpolation( mbImpl, method, interpTag, gNormTag, ssNormTag, ssTagNames, ssTagValues, pcs, 00207 instant_time, pointloc_time, interp_time, gnorm_time, ssnorm_time, toler ); 00208 PRINT_LAST_ERROR; 00209 00210 reduceMax( instant_time ); 00211 reduceMax( pointloc_time ); 00212 reduceMax( interp_time ); 00213 00214 if( 0 == rank ) 00215 printf( "\nMax time : %g %g %g (inst loc interp -- %d procs)\n", instant_time, pointloc_time, interp_time, 00216 nprocs ); 00217 00218 // Output mesh 00219 if( !outFile.empty() ) 00220 { 00221 Range partSets; 00222 // Only save the target mesh 00223 partSets.insert( (EntityHandle)roots[1] ); 00224 std::string newwriteOpts = writeOpts; 00225 std::ostringstream extraOpt; 00226 #ifdef MOAB_HAVE_MPI 00227 extraOpt << ";PARALLEL_COMM=" << 1; 00228 newwriteOpts += extraOpt.str(); 00229 #endif 00230 result = mbImpl->write_file( outFile.c_str(), NULL, newwriteOpts.c_str(), partSets ); 00231 PRINT_LAST_ERROR; 00232 std::cout << "Wrote " << outFile << std::endl; 00233 std::cout << "mbcoupler_test complete." << std::endl; 00234 } 00235 00236 #ifdef MOAB_HAVE_MPI 00237 for( unsigned int i = 0; i < meshFiles.size(); i++ ) 00238 delete pcs[i]; 00239 #endif 00240 00241 delete mbImpl; 00242 // May be leaking iMeshInst, don't care since it's end of program. Remove above deletes? 00243 00244 #ifdef MOAB_HAVE_MPI 00245 err = MPI_Finalize(); 00246 #endif 00247 00248 return 0; 00249 } 00250 00251 #ifdef MOAB_HAVE_MPI 00252 ErrorCode report_iface_ents( Interface* mbImpl, std::vector< ParallelComm* >& pcs, const bool print_results ) 00253 { 00254 Range iface_ents[6]; 00255 ErrorCode result = MB_SUCCESS, tmp_result; 00256 00257 // Now figure out which vertices are shared 00258 for( unsigned int p = 0; p < pcs.size(); p++ ) 00259 { 00260 for( int i = 0; i < 4; i++ ) 00261 { 00262 tmp_result = pcs[p]->get_iface_entities( -1, i, iface_ents[i] ); 00263 00264 if( MB_SUCCESS != tmp_result ) 00265 { 00266 std::cerr << "get_iface_entities returned error on proc " << pcs[p]->proc_config().proc_rank() 00267 << "; message: " << std::endl; 00268 std::string last_error; 00269 result = mbImpl->get_last_error( last_error ); 00270 if( last_error.empty() ) 00271 std::cerr << "(none)" << std::endl; 00272 else 00273 std::cerr << last_error << std::endl; 00274 result = tmp_result; 00275 } 00276 if( 0 != i ) iface_ents[4].merge( iface_ents[i] ); 00277 } 00278 } 00279 00280 // Report # iface entities 00281 result = mbImpl->get_adjacencies( iface_ents[4], 0, false, iface_ents[5], Interface::UNION ); 00282 00283 int rank; 00284 MPI_Comm_rank( MPI_COMM_WORLD, &rank ); 00285 00286 if( print_results || iface_ents[0].size() != iface_ents[5].size() ) 00287 { 00288 std::cerr << "Proc " << rank << " iface entities: " << std::endl; 00289 for( int i = 0; i < 4; i++ ) 00290 std::cerr << " " << iface_ents[i].size() << " " << i << "d iface entities." << std::endl; 00291 std::cerr << " (" << iface_ents[5].size() << " verts adj to other iface ents)" << std::endl; 00292 } 00293 00294 return result; 00295 } 00296 #endif 00297 00298 // Check first character for a '-'. 00299 // Return true if one is found. False otherwise. 00300 bool check_for_flag( const char* str ) 00301 { 00302 if( '-' == str[0] ) 00303 return true; 00304 else 00305 return false; 00306 } 00307 00308 // New get_file_options() function with added possibilities for mbcoupler_test. 00309 ErrorCode get_file_options( int argc, 00310 char** argv, 00311 std::vector< std::string >& meshFiles, 00312 DataCoupler::Method& method, 00313 std::string& interpTag, 00314 std::string& gNormTag, 00315 std::string& ssNormTag, 00316 std::vector< const char* >& ssTagNames, 00317 std::vector< const char* >& ssTagValues, 00318 std::string& readOpts, 00319 std::string& outFile, 00320 std::string& writeOpts, 00321 std::string& dbgFile, 00322 bool& help, 00323 double& epsilon ) 00324 { 00325 // Initialize some of the outputs to null values indicating not present 00326 // in the argument list. 00327 gNormTag = ""; 00328 ssNormTag = ""; 00329 readOpts = "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION;PARTITION_DISTRIBUTE;PARALLEL_" 00330 "RESOLVE_SHARED_ENTS;PARALLEL_GHOSTS=3.0.1;CPUTIME"; 00331 outFile = ""; 00332 writeOpts = "PARALLEL=WRITE_PART;CPUTIME"; 00333 dbgFile = ""; 00334 std::string defaultDbgFile = argv[0]; // The executable name will be the default debug output file. 00335 00336 // These will indicate if we've gotten our required parameters at the end of parsing. 00337 bool haveMeshes = false; 00338 bool haveInterpTag = false; 00339 00340 // Loop over the values in argv pulling out an parsing each one 00341 int npos = 1; 00342 00343 if( argc > 1 && argv[1] == std::string( "-h" ) ) 00344 { 00345 help = true; 00346 return MB_SUCCESS; 00347 } 00348 00349 while( npos < argc ) 00350 { 00351 if( argv[npos] == std::string( "-meshes" ) ) 00352 { 00353 // Parse out the mesh filenames 00354 npos++; 00355 int numFiles = 2; 00356 meshFiles.resize( numFiles ); 00357 for( int i = 0; i < numFiles; i++ ) 00358 { 00359 if( ( npos < argc ) && ( !check_for_flag( argv[npos] ) ) ) 00360 meshFiles[i] = argv[npos++]; 00361 else 00362 { 00363 std::cerr << " ERROR - missing correct number of mesh filenames" << std::endl; 00364 return MB_FAILURE; 00365 } 00366 } 00367 00368 haveMeshes = true; 00369 } 00370 else if( argv[npos] == std::string( "-itag" ) ) 00371 { 00372 // Parse out the interpolation tag 00373 npos++; 00374 if( ( npos < argc ) && ( !check_for_flag( argv[npos] ) ) ) 00375 interpTag = argv[npos++]; 00376 else 00377 { 00378 std::cerr << " ERROR - missing <interp_tag>" << std::endl; 00379 return MB_FAILURE; 00380 } 00381 00382 haveInterpTag = true; 00383 } 00384 else if( argv[npos] == std::string( "-meth" ) ) 00385 { 00386 // Parse out the interpolation tag 00387 npos++; 00388 if( argv[npos][0] == '0' ) 00389 method = DataCoupler::CONSTANT; 00390 else if( argv[npos][0] == '1' ) 00391 method = DataCoupler::LINEAR_FE; 00392 else if( argv[npos][0] == '2' ) 00393 method = DataCoupler::QUADRATIC_FE; 00394 else if( argv[npos][0] == '3' ) 00395 method = DataCoupler::SPECTRAL; 00396 else 00397 { 00398 std::cerr << " ERROR - unrecognized method number " << method << std::endl; 00399 return MB_FAILURE; 00400 } 00401 npos++; 00402 } 00403 else if( argv[npos] == std::string( "-eps" ) ) 00404 { 00405 // Parse out the tolerance 00406 npos++; 00407 if( ( npos < argc ) && ( !check_for_flag( argv[npos] ) ) ) 00408 epsilon = atof( argv[npos++] ); 00409 else 00410 { 00411 std::cerr << " ERROR - missing <epsilon>" << std::endl; 00412 return MB_FAILURE; 00413 } 00414 } 00415 else if( argv[npos] == std::string( "-gnorm" ) ) 00416 { 00417 // Parse out the global normalization tag 00418 npos++; 00419 if( ( npos < argc ) && ( !check_for_flag( argv[npos] ) ) ) 00420 gNormTag = argv[npos++]; 00421 else 00422 { 00423 std::cerr << " ERROR - missing <gnorm_tag>" << std::endl; 00424 return MB_FAILURE; 00425 } 00426 } 00427 else if( argv[npos] == std::string( "-ssnorm" ) ) 00428 { 00429 // Parse out the subset normalization tag and selection criteria 00430 npos++; 00431 if( ( npos < argc ) && ( !check_for_flag( argv[npos] ) ) ) 00432 ssNormTag = argv[npos++]; 00433 else 00434 { 00435 std::cerr << " ERROR - missing <ssnorm_tag>" << std::endl; 00436 return MB_FAILURE; 00437 } 00438 00439 if( ( npos < argc ) && ( !check_for_flag( argv[npos] ) ) ) 00440 { 00441 char* opts = argv[npos++]; 00442 char sep1[1] = { ';' }; 00443 char sep2[1] = { '=' }; 00444 bool end_vals_seen = false; 00445 std::vector< char* > tmpTagOpts; 00446 00447 // First get the options 00448 for( char* i = strtok( opts, sep1 ); i; i = strtok( 0, sep1 ) ) 00449 tmpTagOpts.push_back( i ); 00450 00451 // Parse out the name and val or just name. 00452 for( unsigned int j = 0; j < tmpTagOpts.size(); j++ ) 00453 { 00454 char* e = strtok( tmpTagOpts[j], sep2 ); 00455 ssTagNames.push_back( e ); 00456 e = strtok( 0, sep2 ); 00457 if( e != NULL ) 00458 { 00459 // We have a value 00460 if( end_vals_seen ) 00461 { 00462 // ERROR we should not have a value after none are seen 00463 std::cerr << " ERROR - new value seen after end of values in " 00464 "<ssnorm_selection>" 00465 << std::endl; 00466 return MB_FAILURE; 00467 } 00468 // Otherwise get the value string from e and convert it to an int 00469 int* valp = new int; 00470 *valp = atoi( e ); 00471 ssTagValues.push_back( (const char*)valp ); 00472 } 00473 else 00474 { 00475 // Otherwise there is no '=' so push a null on the list 00476 end_vals_seen = true; 00477 ssTagValues.push_back( (const char*)0 ); 00478 } 00479 } 00480 } 00481 else 00482 { 00483 std::cerr << " ERROR - missing <ssnorm_selection>" << std::endl; 00484 return MB_FAILURE; 00485 } 00486 } 00487 else if( argv[npos] == std::string( "-ropts" ) ) 00488 { 00489 // Parse out the mesh file read options 00490 npos++; 00491 if( ( npos < argc ) && ( !check_for_flag( argv[npos] ) ) ) 00492 readOpts = argv[npos++]; 00493 else 00494 { 00495 std::cerr << " ERROR - missing <roptions>" << std::endl; 00496 return MB_FAILURE; 00497 } 00498 } 00499 else if( argv[npos] == std::string( "-outfile" ) ) 00500 { 00501 // Parse out the output file name 00502 npos++; 00503 if( ( npos < argc ) && ( !check_for_flag( argv[npos] ) ) ) 00504 outFile = argv[npos++]; 00505 else 00506 { 00507 std::cerr << " ERROR - missing <out_file>" << std::endl; 00508 return MB_FAILURE; 00509 } 00510 } 00511 else if( argv[npos] == std::string( "-wopts" ) ) 00512 { 00513 // Parse out the output file write options 00514 npos++; 00515 if( ( npos < argc ) && ( !check_for_flag( argv[npos] ) ) ) 00516 writeOpts = argv[npos++]; 00517 else 00518 { 00519 std::cerr << " ERROR - missing <woptions>" << std::endl; 00520 return MB_FAILURE; 00521 } 00522 } 00523 else if( argv[npos] == std::string( "-dbgout" ) ) 00524 { 00525 // Parse out the debug output file name. 00526 // If no name then use the default. 00527 npos++; 00528 if( ( npos < argc ) && ( !check_for_flag( argv[npos] ) ) ) 00529 dbgFile = argv[npos++]; 00530 else 00531 dbgFile = defaultDbgFile; 00532 } 00533 else 00534 { 00535 // Unrecognized parameter. Skip it and move along. 00536 std::cerr << " ERROR - Unrecognized parameter:" << argv[npos] << std::endl; 00537 std::cerr << " Skipping..." << std::endl; 00538 npos++; 00539 } 00540 } 00541 00542 if( !haveMeshes ) 00543 { 00544 meshFiles.resize( 2 ); 00545 meshFiles[0] = std::string( TestDir + "unittest/64bricks_1khex.h5m" ); 00546 meshFiles[1] = std::string( TestDir + "unittest/64bricks_12ktet.h5m" ); 00547 std::cout << "Mesh files not entered; using default files " << meshFiles[0] << " and " << meshFiles[1] 00548 << std::endl; 00549 } 00550 00551 if( !haveInterpTag ) 00552 { 00553 interpTag = "vertex_field"; 00554 std::cout << "Interpolation field name not given, using default of " << interpTag << std::endl; 00555 } 00556 00557 #ifdef MOAB_HAVE_HDF5 00558 if( 1 == argc ) 00559 { 00560 std::cout << "No arguments given; using output file dum.h5m." << std::endl; 00561 outFile = "dum.h5m"; 00562 } 00563 #endif 00564 00565 return MB_SUCCESS; 00566 } 00567 00568 // End new get_file_options() 00569 00570 ErrorCode test_interpolation( Interface* mbImpl, 00571 DataCoupler::Method method, 00572 std::string& interpTag, 00573 std::string& /* gNormTag */, 00574 std::string& /* ssNormTag */, 00575 std::vector< const char* >& /* ssTagNames */, 00576 std::vector< const char* >& /* ssTagValues */, 00577 std::vector< ParallelComm* >& pcs, 00578 double& instant_time, 00579 double& pointloc_time, 00580 double& interp_time, 00581 double& /* gnorm_time */, 00582 double& /* ssnorm_time */, 00583 double& toler ) 00584 { 00585 assert( method >= DataCoupler::CONSTANT && method <= DataCoupler::SPECTRAL ); 00586 00587 // Source is 1st mesh, target is 2nd 00588 Range src_elems, targ_elems, targ_verts; 00589 ErrorCode result = pcs[0]->get_part_entities( src_elems, 3 ); 00590 PRINT_LAST_ERROR; 00591 00592 CpuTimer timer; 00593 00594 // Instantiate a coupler, which also initializes the tree 00595 DataCoupler dc( mbImpl, src_elems, 0, pcs[0] ); 00596 00597 // Initialize spectral elements, if they exist 00598 // bool specSou = false, specTar = false; 00599 // result = mbc.initialize_spectral_elements((EntityHandle)roots[0], (EntityHandle)roots[1], 00600 // specSou, specTar); 00601 00602 instant_time = timer.time_since_birth(); 00603 00604 // Get points from the target mesh to interpolate 00605 // We have to treat differently the case when the target is a spectral mesh 00606 // In that case, the points of interest are the GL points, not the vertex nodes 00607 std::vector< double > vpos; // This will have the positions we are interested in 00608 int numPointsOfInterest = 0; 00609 #ifdef MOAB_HAVE_MPI 00610 result = pcs[1]->get_part_entities( targ_elems, 3 ); 00611 #endif 00612 PRINT_LAST_ERROR; 00613 00614 // First get all vertices adj to partition entities in target mesh 00615 if( DataCoupler::CONSTANT == method ) 00616 targ_verts = targ_elems; 00617 else 00618 result = mbImpl->get_adjacencies( targ_elems, 0, false, targ_verts, Interface::UNION ); 00619 PRINT_LAST_ERROR; 00620 00621 #ifdef MOAB_HAVE_MPI 00622 // Then get non-owned verts and subtract 00623 Range tmp_verts; 00624 result = pcs[1]->get_pstatus_entities( 0, PSTATUS_NOT_OWNED, tmp_verts ); 00625 PRINT_LAST_ERROR; 00626 targ_verts = subtract( targ_verts, tmp_verts ); 00627 #endif 00628 // Get position of these entities; these are the target points 00629 numPointsOfInterest = (int)targ_verts.size(); 00630 vpos.resize( 3 * targ_verts.size() ); 00631 result = mbImpl->get_coords( targ_verts, &vpos[0] ); 00632 PRINT_LAST_ERROR; 00633 00634 // Locate those points in the source mesh 00635 #ifdef MOAB_HAVE_MPI 00636 std::cout << "rank " << pcs[0]->proc_config().proc_rank(); 00637 #endif 00638 std::cout << " points of interest: " << numPointsOfInterest << "\n"; 00639 result = dc.locate_points( &vpos[0], numPointsOfInterest, toler ); 00640 PRINT_LAST_ERROR; 00641 00642 pointloc_time = timer.time_elapsed(); 00643 00644 // Now interpolate tag onto target points 00645 std::vector< double > field( numPointsOfInterest ); 00646 00647 result = dc.interpolate( method, interpTag, &field[0] ); 00648 PRINT_LAST_ERROR; 00649 00650 interp_time = timer.time_elapsed(); 00651 00652 // Set field values as tag on target vertices 00653 // Use original tag 00654 Tag tag; 00655 result = mbImpl->tag_get_handle( interpTag.c_str(), 1, MB_TYPE_DOUBLE, tag ); 00656 PRINT_LAST_ERROR; 00657 result = mbImpl->tag_set_data( tag, targ_verts, &field[0] ); 00658 PRINT_LAST_ERROR; 00659 00660 // Done 00661 return MB_SUCCESS; 00662 } 00663 00664 #else 00665 00666 int main( int /*argc*/, char** argv ) 00667 { 00668 print_usage( argv ); 00669 return 0; 00670 } 00671 00672 #endif
