MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 #include <iostream> 00002 #include <moab/Core.hpp> 00003 #include "moab/ProgOptions.hpp" 00004 00005 using namespace moab; 00006 using namespace std; 00007 const char BRIEF_DESC[] = "Add higher order nodes to existing mesh, eg. hex8 to hex27 (default). " 00008 "Use available options as desired."; 00009 std::ostringstream LONG_DESC; 00010 00011 int main( int argc, char* argv[] ) 00012 { 00013 moab::Core* mb = new moab::Core(); 00014 moab::ErrorCode rval; 00015 bool edge = false; 00016 bool face = false; 00017 bool volume = false; 00018 00019 LONG_DESC << "mbhonodes tool reads a mesh file and adds higher order nodes." << std::endl 00020 << "Options to add higher order nodes on all volume or face or edge elements of the mesh " 00021 "are supported" 00022 << std::endl 00023 << "Example1: Use the following command to create hex mid volume nodes, in.h5m is a hex8 " 00024 "mesh" 00025 << std::endl 00026 << " -> mbhonodes -i in.h5m -o o.h5m -f -e" << std::endl 00027 << "Example2: Use the following command to create hex27 mesh o2.h5m, in.h5m is a hex8 mesh" << std::endl 00028 << " -> mbhonodes -i in.h5m -o o2.h5m" << std::endl; 00029 00030 ProgOptions opts( LONG_DESC.str(), BRIEF_DESC ); 00031 string inFileName = ""; 00032 opts.addRequiredArg< string >( "inFile,i", "Specify the output file name string", &inFileName ); 00033 #ifdef MOAB_HAVE_HDF5 00034 string outFileName = "outfile.h5m"; 00035 #else 00036 string outFileName = "outfile.vtk"; 00037 #endif 00038 opts.addOpt< string >( "outFile,o", "Specify the output file name string (default outfile.h5m)", &outFileName ); 00039 opts.addOpt< void >( "edge,e", "DO NOT create mid nodes along edge (default=true)", &edge ); 00040 opts.addOpt< void >( "face,f", "DO NOT create face mid nodes (default=true)", &face ); 00041 opts.addOpt< void >( "volume,v", "DO NOT create volume mid nodes (default=true)", &volume ); 00042 00043 opts.parseCommandLine( argc, argv ); 00044 00045 // load the input file 00046 rval = mb->load_mesh( inFileName.c_str() );MB_CHK_SET_ERR( rval, "Failed to write the mesh file" ); 00047 std::cout << "Read input mesh file: " << inFileName << std::endl; 00048 moab::Range entities; 00049 moab::EntityHandle meshset; 00050 00051 rval = mb->get_entities_by_type( 0, MBHEX, entities );MB_CHK_SET_ERR( rval, "Failed to get hex entities" ); 00052 rval = mb->create_meshset( MESHSET_SET, meshset );MB_CHK_SET_ERR( rval, "Failed to create meshset" ); 00053 rval = mb->add_entities( meshset, entities );MB_CHK_SET_ERR( rval, "Failed to add entitites to meshset" ); 00054 00055 rval = mb->convert_entities( meshset, !edge, !face, !volume );MB_CHK_SET_ERR( rval, "Failed to convert to higher dimension entities" ); 00056 00057 rval = mb->write_mesh( outFileName.c_str() );MB_CHK_SET_ERR( rval, "Failed to write the mesh file" ); 00058 std::cout << "Wrote mesh file: " << outFileName << std::endl; 00059 delete mb; 00060 }
