MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /* 00002 * intx_on_sphere_test.cpp 00003 * 00004 * Created on: Oct 3, 2012 00005 * Author: iulian 00006 */ 00007 #include <iostream> 00008 #include <sstream> 00009 #include <ctime> 00010 #include <cstdlib> 00011 #include <cstdio> 00012 #include <cstring> 00013 #include "moab/Core.hpp" 00014 #ifdef MOAB_HAVE_MPI 00015 #include "moab/ParallelComm.hpp" 00016 #endif 00017 #include "moab/IntxMesh/Intx2MeshOnSphere.hpp" 00018 #include "moab/IntxMesh/IntxUtils.hpp" 00019 #include "TestUtil.hpp" 00020 #include "moab/ProgOptions.hpp" 00021 #include <cmath> 00022 00023 using namespace moab; 00024 00025 int main( int argc, char* argv[] ) 00026 { 00027 00028 std::string firstModel, secondModel, outputFile; 00029 00030 firstModel = TestDir + "unittest/mbcslam/lagrangeHomme.vtk"; 00031 secondModel = TestDir + "unittest/mbcslam/eulerHomme.vtk"; 00032 00033 ProgOptions opts; 00034 opts.addOpt< std::string >( "first,t", "first mesh filename (source)", &firstModel ); 00035 opts.addOpt< std::string >( "second,m", "second mesh filename (target)", &secondModel ); 00036 opts.addOpt< std::string >( "outputFile,o", "output intersection file", &outputFile ); 00037 00038 double R = 1.; // input 00039 double epsrel = 1.e-12; 00040 double boxeps = 1.e-4; 00041 outputFile = "intx.h5m"; 00042 opts.addOpt< double >( "radius,R", "radius for model intx", &R ); 00043 opts.addOpt< double >( "epsilon,e", "relative error in intx", &epsrel ); 00044 opts.addOpt< double >( "boxerror,b", "relative error for box boundaries", &boxeps ); 00045 00046 int output_fraction = 0; 00047 int write_files_rank = 0; 00048 int brute_force = 0; 00049 00050 opts.addOpt< int >( "outputFraction,f", "output fraction of areas", &output_fraction ); 00051 opts.addOpt< int >( "writeFiles,w", "write files of interest", &write_files_rank ); 00052 opts.addOpt< int >( "kdtreeOption,k", "use kd tree for intersection", &brute_force ); 00053 00054 opts.parseCommandLine( argc, argv ); 00055 int rank = 0, size = 1; 00056 #ifdef MOAB_HAVE_MPI 00057 MPI_Init( &argc, &argv ); 00058 MPI_Comm_rank( MPI_COMM_WORLD, &rank ); 00059 MPI_Comm_size( MPI_COMM_WORLD, &size ); 00060 #endif 00061 00062 // check command line arg second grid is red, arrival, first mesh is blue, departure 00063 // will will keep the 00064 std::string optsRead = ( size == 1 ? "" 00065 : std::string( "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION" ) + 00066 std::string( ";PARALLEL_RESOLVE_SHARED_ENTS" ) ); 00067 00068 // read meshes in 2 file sets 00069 ErrorCode rval; 00070 Core moab; 00071 Interface* mb = &moab; // global 00072 EntityHandle sf1, sf2, outputSet; 00073 00074 // create meshsets and load files 00075 00076 rval = mb->create_meshset( MESHSET_SET, sf1 );MB_CHK_ERR( rval ); 00077 rval = mb->create_meshset( MESHSET_SET, sf2 );MB_CHK_ERR( rval ); 00078 if( 0 == rank ) std::cout << "Loading mesh file " << firstModel << "\n"; 00079 rval = mb->load_file( firstModel.c_str(), &sf1, optsRead.c_str() );MB_CHK_ERR( rval ); 00080 if( 0 == rank ) std::cout << "Loading mesh file " << secondModel << "\n"; 00081 rval = mb->load_file( secondModel.c_str(), &sf2, optsRead.c_str() );MB_CHK_ERR( rval ); 00082 00083 if( 0 == rank ) 00084 { 00085 std::cout << "Radius: " << R << "\n"; 00086 std::cout << "relative eps: " << epsrel << "\n"; 00087 std::cout << "box eps: " << boxeps << "\n"; 00088 std::cout << " use kd tree for intersection: " << brute_force << "\n"; 00089 } 00090 rval = mb->create_meshset( MESHSET_SET, outputSet );MB_CHK_ERR( rval ); 00091 00092 // fix radius of both meshes, to be consistent with input R 00093 rval = moab::IntxUtils::ScaleToRadius( mb, sf1, R );MB_CHK_ERR( rval ); 00094 rval = moab::IntxUtils::ScaleToRadius( mb, sf2, R );MB_CHK_ERR( rval ); 00095 00096 #if 0 00097 // std::cout << "Fix orientation etc ..\n"; 00098 //IntxUtils; those calls do nothing for a good mesh 00099 rval = fix_degenerate_quads(mb, sf1);MB_CHK_ERR(rval); 00100 rval = fix_degenerate_quads(mb, sf2);MB_CHK_ERR(rval); 00101 00102 rval = positive_orientation(mb, sf1, R);MB_CHK_ERR(rval); 00103 rval = positive_orientation(mb, sf2, R);MB_CHK_ERR(rval); 00104 #endif 00105 00106 #ifdef MOAB_HAVE_MPI 00107 ParallelComm* pcomm = ParallelComm::get_pcomm( mb, 0 ); 00108 #endif 00109 Intx2MeshOnSphere worker( mb ); 00110 IntxAreaUtils areaAdaptor; 00111 00112 worker.set_error_tolerance( R * epsrel ); 00113 worker.set_box_error( boxeps ); 00114 #ifdef MOAB_HAVE_MPI 00115 worker.set_parallel_comm( pcomm ); 00116 #endif 00117 // worker.SetEntityType(moab::MBQUAD); 00118 worker.set_radius_source_mesh( R ); 00119 worker.set_radius_destination_mesh( R ); 00120 // worker.enable_debug(); 00121 00122 rval = worker.FindMaxEdges( sf1, sf2 );MB_CHK_ERR( rval ); 00123 00124 EntityHandle covering_set; 00125 #ifdef MOAB_HAVE_MPI 00126 if( size > 1 ) 00127 { 00128 Range local_verts; 00129 rval = worker.build_processor_euler_boxes( sf2, local_verts );MB_CHK_ERR( rval ); // output also the local_verts 00130 if( write_files_rank ) 00131 { 00132 std::stringstream outf; 00133 outf << "second_mesh" << rank << ".h5m"; 00134 rval = mb->write_file( outf.str().c_str(), 0, 0, &sf2, 1 );MB_CHK_ERR( rval ); 00135 } 00136 } 00137 if( size > 1 ) 00138 { 00139 double elapsed = MPI_Wtime(); 00140 rval = mb->create_meshset( moab::MESHSET_SET, covering_set );MB_CHK_SET_ERR( rval, "Can't create new set" ); 00141 rval = worker.construct_covering_set( sf1, covering_set );MB_CHK_ERR( rval ); // lots of communication if mesh is distributed very differently 00142 elapsed = MPI_Wtime() - elapsed; 00143 if( 0 == rank ) std::cout << "\nTime to communicate the mesh = " << elapsed << std::endl; 00144 // area fraction of the covering set that needed to be communicated from other processors 00145 // number of elements in the covering set communicated, compared to total number of elements 00146 // in the covering set 00147 if( output_fraction ) 00148 { 00149 EntityHandle comm_set; // set with elements communicated from other tasks 00150 rval = mb->create_meshset( MESHSET_SET, comm_set );MB_CHK_ERR( rval ); 00151 // see how much more different is compared to sf1 00152 rval = mb->unite_meshset( comm_set, covering_set );MB_CHK_ERR( rval ); // will have to subtract from covering set, initial set 00153 // subtract 00154 rval = mb->subtract_meshset( comm_set, sf1 );MB_CHK_ERR( rval ); 00155 // compute fractions 00156 double area_cov_set = areaAdaptor.area_on_sphere( mb, covering_set, R ); 00157 assert( area_cov_set > 0 ); 00158 double comm_area = areaAdaptor.area_on_sphere( mb, comm_set, R ); 00159 // more important is actually the number of elements communicated 00160 int num_cov_cells, num_comm_cells; 00161 rval = mb->get_number_entities_by_dimension( covering_set, 2, num_cov_cells );MB_CHK_ERR( rval ); 00162 rval = mb->get_number_entities_by_dimension( comm_set, 2, num_comm_cells );MB_CHK_ERR( rval ); 00163 double fraction_area = comm_area / area_cov_set; 00164 double fraction_num_cells = 00165 (double)num_comm_cells / num_cov_cells; // determine min, max, average of these fractions 00166 00167 double max_fraction_area, max_fraction_num_cells, min_fraction_area, min_fraction_num_cells; 00168 double average_fraction_area, average_fraction_num_cells; 00169 MPI_Reduce( &fraction_area, &max_fraction_area, 1, MPI_DOUBLE, MPI_MAX, 0, MPI_COMM_WORLD ); 00170 MPI_Reduce( &fraction_num_cells, &max_fraction_num_cells, 1, MPI_DOUBLE, MPI_MAX, 0, MPI_COMM_WORLD ); 00171 MPI_Reduce( &fraction_area, &min_fraction_area, 1, MPI_DOUBLE, MPI_MIN, 0, MPI_COMM_WORLD ); 00172 MPI_Reduce( &fraction_num_cells, &min_fraction_num_cells, 1, MPI_DOUBLE, MPI_MIN, 0, MPI_COMM_WORLD ); 00173 MPI_Reduce( &fraction_area, &average_fraction_area, 1, MPI_DOUBLE, MPI_SUM, 0, MPI_COMM_WORLD ); 00174 MPI_Reduce( &fraction_num_cells, &average_fraction_num_cells, 1, MPI_DOUBLE, MPI_SUM, 0, MPI_COMM_WORLD ); 00175 average_fraction_area /= size; 00176 average_fraction_num_cells /= size; 00177 if( rank == 0 ) 00178 { 00179 std::cout << " fraction area: min: " << min_fraction_area << " max: " << max_fraction_area 00180 << " average :" << average_fraction_area << " \n"; 00181 std::cout << " fraction num cells: min: " << min_fraction_num_cells 00182 << " max: " << max_fraction_num_cells << " average: " << average_fraction_num_cells << " \n"; 00183 } 00184 } 00185 if( write_files_rank ) 00186 { 00187 std::stringstream cof; 00188 cof << "covering_mesh" << rank << ".h5m"; 00189 rval = mb->write_file( cof.str().c_str(), 0, 0, &covering_set, 1 );MB_CHK_ERR( rval ); 00190 } 00191 } 00192 else 00193 #endif 00194 covering_set = sf1; 00195 00196 if( 0 == rank ) std::cout << "Computing intersections ..\n"; 00197 #ifdef MOAB_HAVE_MPI 00198 double elapsed = MPI_Wtime(); 00199 #endif 00200 if( brute_force ) 00201 { 00202 rval = worker.intersect_meshes_kdtree( covering_set, sf2, outputSet );MB_CHK_SET_ERR( rval, "failed to intersect meshes with slow method" ); 00203 } 00204 else 00205 { 00206 rval = worker.intersect_meshes( covering_set, sf2, outputSet );MB_CHK_SET_ERR( rval, "failed to intersect meshes" ); 00207 } 00208 #ifdef MOAB_HAVE_MPI 00209 elapsed = MPI_Wtime() - elapsed; 00210 if( 0 == rank ) std::cout << "\nTime to compute the intersection between meshes = " << elapsed << std::endl; 00211 #endif 00212 // the output set does not have the intx vertices on the boundary shared, so they will be 00213 // duplicated right now we write this file just for checking it looks OK 00214 00215 // compute total area with 2 methods 00216 // double initial_area = areaAdaptor.area_on_sphere_lHuiller(mb, sf1, R); 00217 // double area_method1 = areaAdaptor.area_on_sphere_lHuiller(mb, outputSet, R); 00218 // double area_method2 = areaAdaptor.area_on_sphere(mb, outputSet, R); 00219 00220 // std::cout << "initial area: " << initial_area << "\n"; 00221 // std::cout<< " area with l'Huiller: " << area_method1 << " with Girard: " << area_method2<< 00222 // "\n"; std::cout << " relative difference areas " << 00223 // fabs(area_method1-area_method2)/area_method1 << "\n"; std::cout << " relative error " << 00224 // fabs(area_method1-initial_area)/area_method1 << "\n"; 00225 00226 if( write_files_rank ) 00227 { 00228 std::stringstream outf; 00229 outf << "intersect" << rank << ".h5m"; 00230 rval = mb->write_file( outf.str().c_str(), 0, 0, &outputSet, 1 ); 00231 } 00232 double intx_area = areaAdaptor.area_on_sphere( mb, outputSet, R ); 00233 double arrival_area = areaAdaptor.area_on_sphere( mb, sf2, R ); 00234 std::cout << "On rank : " << rank << " arrival area: " << arrival_area << " intersection area:" << intx_area 00235 << " rel error: " << fabs( ( intx_area - arrival_area ) / arrival_area ) << "\n"; 00236 00237 #ifdef MOAB_HAVE_MPI 00238 #ifdef MOAB_HAVE_HDF5_PARALLEL 00239 rval = mb->write_file( outputFile.c_str(), 0, "PARALLEL=WRITE_PART", &outputSet, 1 );MB_CHK_SET_ERR( rval, "failed to write intx file" ); 00240 #else 00241 // write intx set on rank 0, in serial; we cannot write in parallel 00242 if( 0 == rank ) 00243 { 00244 rval = mb->write_file( outputFile.c_str(), 0, 0, &outputSet, 1 );MB_CHK_SET_ERR( rval, "failed to write intx file" ); 00245 } 00246 #endif 00247 MPI_Finalize(); 00248 #else 00249 rval = mb->write_file( outputFile.c_str(), 0, 0, &outputSet, 1 );MB_CHK_SET_ERR( rval, "failed to write intx file" ); 00250 #endif 00251 return 0; 00252 }
