MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /* 00002 * Usage: MOAB intersection check tool, for intersection on a sphere or in plane 00003 * 00004 * mpiexec -np n ./mbintx_check -s <source mesh> -t <target mesh> -i <intx mesh> -o <source verif> 00005 * -q <target verif> 00006 * 00007 * after a run with mbtempest in parallel, that computes intersection, we can use this tool to 00008 * verify areas of intersection polygons, compared to areas of source, target elements 00009 * 00010 */ 00011 00012 #include <iostream> 00013 #include <cstdlib> 00014 #include <vector> 00015 #include <string> 00016 #include <sstream> 00017 #include <cassert> 00018 00019 #include "moab/Core.hpp" 00020 #include "moab/IntxMesh/IntxUtils.hpp" 00021 #include "moab/ProgOptions.hpp" 00022 #include "moab/CpuTimer.hpp" 00023 #include "DebugOutput.hpp" 00024 00025 #ifdef MOAB_HAVE_MPI 00026 // MPI includes 00027 #include "moab_mpi.h" 00028 #include "moab/ParallelComm.hpp" 00029 #include "MBParallelConventions.h" 00030 #endif 00031 00032 using namespace moab; 00033 00034 int main( int argc, char* argv[] ) 00035 { 00036 std::stringstream sstr; 00037 // Default area_method = lHuiller; Options: Girard, GaussQuadrature (if TR is available) 00038 const IntxAreaUtils::AreaMethod areaMethod = IntxAreaUtils::lHuiller; 00039 00040 int rank = 0, size = 1; 00041 #ifdef MOAB_HAVE_MPI 00042 MPI_Init( &argc, &argv ); 00043 MPI_Comm_rank( MPI_COMM_WORLD, &rank ); 00044 MPI_Comm_size( MPI_COMM_WORLD, &size ); 00045 #endif 00046 00047 std::string sourceFile, targetFile, intxFile; 00048 std::string source_verif( "outS.h5m" ), target_verif( "outt.h5m" ); 00049 int sphere = 1; 00050 int oldNamesParents = 1; 00051 double areaErrSource = -1; 00052 double areaErrTarget = -1; 00053 ProgOptions opts; 00054 00055 opts.addOpt< std::string >( "source,s", "source file ", &sourceFile ); 00056 opts.addOpt< std::string >( "target,t", "target file ", &targetFile ); 00057 opts.addOpt< std::string >( "intersection,i", "intersection file ", &intxFile ); 00058 opts.addOpt< std::string >( "verif_source,v", "output source verification ", &source_verif ); 00059 opts.addOpt< std::string >( "verif_target,w", "output target verification ", &target_verif ); 00060 opts.addOpt< double >( "threshold_source,m", "error source threshold ", &areaErrSource ); 00061 opts.addOpt< double >( "threshold_target,q", "error target threshold ", &areaErrTarget ); 00062 00063 opts.addOpt< int >( "sphere,p", "mesh on a sphere", &sphere ); 00064 opts.addOpt< int >( "old_convention,n", "old names for parent tags", &oldNamesParents ); 00065 00066 opts.parseCommandLine( argc, argv ); 00067 // load meshes in parallel if needed 00068 std::string opts_read = ( size == 1 ? "" 00069 : std::string( "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION" ) + 00070 std::string( ";PARALLEL_RESOLVE_SHARED_ENTS" ) ); 00071 00072 // read meshes in 3 file sets 00073 ErrorCode rval; 00074 Core moab; 00075 Interface* mb = &moab; // global 00076 EntityHandle sset, tset, ixset; 00077 00078 // create meshsets and load files 00079 rval = mb->create_meshset( MESHSET_SET, sset );MB_CHK_ERR( rval ); 00080 rval = mb->create_meshset( MESHSET_SET, tset );MB_CHK_ERR( rval ); 00081 rval = mb->create_meshset( MESHSET_SET, ixset );MB_CHK_ERR( rval ); 00082 if( 0 == rank ) std::cout << "Loading source file " << sourceFile << "\n"; 00083 rval = mb->load_file( sourceFile.c_str(), &sset, opts_read.c_str() );MB_CHK_SET_ERR( rval, "failed reading source file" ); 00084 if( 0 == rank ) std::cout << "Loading target file " << targetFile << "\n"; 00085 rval = mb->load_file( targetFile.c_str(), &tset, opts_read.c_str() );MB_CHK_SET_ERR( rval, "failed reading target file" ); 00086 00087 if( 0 == rank ) std::cout << "Loading intersection file " << intxFile << "\n"; 00088 rval = mb->load_file( intxFile.c_str(), &ixset, opts_read.c_str() );MB_CHK_SET_ERR( rval, "failed reading intersection file" ); 00089 double R = 1.; 00090 if( sphere ) 00091 { 00092 // fix radius of both meshes, to be consistent with radius 1 00093 rval = moab::IntxUtils::ScaleToRadius( mb, sset, R );MB_CHK_ERR( rval ); 00094 rval = moab::IntxUtils::ScaleToRadius( mb, tset, R );MB_CHK_ERR( rval ); 00095 } 00096 Range intxCells; 00097 rval = mb->get_entities_by_dimension( ixset, 2, intxCells );MB_CHK_ERR( rval ); 00098 00099 Range sourceCells; 00100 rval = mb->get_entities_by_dimension( sset, 2, sourceCells );MB_CHK_ERR( rval ); 00101 00102 Range targetCells; 00103 rval = mb->get_entities_by_dimension( tset, 2, targetCells );MB_CHK_ERR( rval ); 00104 00105 Tag sourceParentTag; 00106 Tag targetParentTag; 00107 if( oldNamesParents ) 00108 { 00109 rval = mb->tag_get_handle( "RedParent", targetParentTag );MB_CHK_SET_ERR( rval, "can't find target parent tag" ); 00110 rval = mb->tag_get_handle( "BlueParent", sourceParentTag );MB_CHK_SET_ERR( rval, "can't find source parent tag" ); 00111 } 00112 else 00113 { 00114 rval = mb->tag_get_handle( "TargetParent", targetParentTag );MB_CHK_SET_ERR( rval, "can't find target parent tag" ); 00115 rval = mb->tag_get_handle( "SourceParent", sourceParentTag );MB_CHK_SET_ERR( rval, "can't find source parent tag" ); 00116 } 00117 00118 // error sets, for better visualization 00119 EntityHandle errorSourceSet; 00120 rval = mb->create_meshset( MESHSET_SET, errorSourceSet );MB_CHK_ERR( rval ); 00121 EntityHandle errorTargetSet; 00122 rval = mb->create_meshset( MESHSET_SET, errorTargetSet );MB_CHK_ERR( rval ); 00123 00124 std::map< int, double > sourceAreas; 00125 std::map< int, double > targetAreas; 00126 00127 std::map< int, double > sourceAreasIntx; 00128 std::map< int, double > targetAreasIntx; 00129 00130 std::map< int, int > sourceNbIntx; 00131 std::map< int, int > targetNbIntx; 00132 00133 std::map< int, EntityHandle > sourceMap; 00134 std::map< int, EntityHandle > targetMap; 00135 00136 Tag gidTag = mb->globalId_tag(); 00137 00138 Tag areaTag; 00139 rval = mb->tag_get_handle( "OrigArea", 1, MB_TYPE_DOUBLE, areaTag, MB_TAG_DENSE | MB_TAG_CREAT );MB_CHK_ERR( rval ); 00140 00141 moab::IntxAreaUtils areaAdaptor( areaMethod ); 00142 Range non_convex_intx_cells; 00143 for( Range::iterator eit = sourceCells.begin(); eit != sourceCells.end(); ++eit ) 00144 { 00145 EntityHandle cell = *eit; 00146 const EntityHandle* verts; 00147 int num_nodes; 00148 rval = mb->get_connectivity( cell, verts, num_nodes );MB_CHK_ERR( rval ); 00149 if( MB_SUCCESS != rval ) return -1; 00150 std::vector< double > coords( 3 * num_nodes ); 00151 // get coordinates 00152 rval = mb->get_coords( verts, num_nodes, &coords[0] ); 00153 if( MB_SUCCESS != rval ) return -1; 00154 double area = areaAdaptor.area_spherical_polygon( &coords[0], num_nodes, R ); 00155 int sourceID; 00156 rval = mb->tag_get_data( gidTag, &cell, 1, &sourceID );MB_CHK_ERR( rval ); 00157 sourceAreas[sourceID] = area; 00158 rval = mb->tag_set_data( areaTag, &cell, 1, &area );MB_CHK_ERR( rval ); 00159 sourceMap[sourceID] = cell; 00160 } 00161 for( Range::iterator eit = targetCells.begin(); eit != targetCells.end(); ++eit ) 00162 { 00163 EntityHandle cell = *eit; 00164 const EntityHandle* verts; 00165 int num_nodes; 00166 rval = mb->get_connectivity( cell, verts, num_nodes );MB_CHK_ERR( rval ); 00167 if( MB_SUCCESS != rval ) return -1; 00168 std::vector< double > coords( 3 * num_nodes ); 00169 // get coordinates 00170 rval = mb->get_coords( verts, num_nodes, &coords[0] ); 00171 if( MB_SUCCESS != rval ) return -1; 00172 double area = areaAdaptor.area_spherical_polygon( &coords[0], num_nodes, R ); 00173 int targetID; 00174 rval = mb->tag_get_data( gidTag, &cell, 1, &targetID );MB_CHK_ERR( rval ); 00175 targetAreas[targetID] = area; 00176 rval = mb->tag_set_data( areaTag, &cell, 1, &area );MB_CHK_ERR( rval ); 00177 targetMap[targetID] = cell; 00178 } 00179 00180 for( Range::iterator eit = intxCells.begin(); eit != intxCells.end(); ++eit ) 00181 { 00182 EntityHandle cell = *eit; 00183 const EntityHandle* verts; 00184 int num_nodes; 00185 rval = mb->get_connectivity( cell, verts, num_nodes );MB_CHK_ERR( rval ); 00186 if( MB_SUCCESS != rval ) return -1; 00187 std::vector< double > coords( 3 * num_nodes ); 00188 // get coordinates 00189 rval = mb->get_coords( verts, num_nodes, &coords[0] ); 00190 if( MB_SUCCESS != rval ) return -1; 00191 int check_sign = 1; 00192 double intx_area = areaAdaptor.area_spherical_polygon( &coords[0], num_nodes, R, &check_sign ); 00193 00194 rval = mb->tag_set_data( areaTag, &cell, 1, &intx_area ); 00195 ;MB_CHK_ERR( rval ); 00196 int sourceID, targetID; 00197 rval = mb->tag_get_data( sourceParentTag, &cell, 1, &sourceID );MB_CHK_ERR( rval ); 00198 rval = mb->tag_get_data( targetParentTag, &cell, 1, &targetID );MB_CHK_ERR( rval ); 00199 00200 std::map< int, double >::iterator sit = sourceAreasIntx.find( sourceID ); 00201 if( sit == sourceAreasIntx.end() ) 00202 { 00203 sourceAreasIntx[sourceID] = intx_area; 00204 sourceNbIntx[sourceID] = 1; 00205 } 00206 else 00207 { 00208 sourceAreasIntx[sourceID] += intx_area; 00209 sourceNbIntx[sourceID]++; 00210 } 00211 00212 std::map< int, double >::iterator tit = targetAreasIntx.find( targetID ); 00213 if( tit == targetAreasIntx.end() ) 00214 { 00215 targetAreasIntx[targetID] = intx_area; 00216 targetNbIntx[targetID] = 1; 00217 } 00218 else 00219 { 00220 targetAreasIntx[targetID] += intx_area; 00221 targetNbIntx[targetID]++; 00222 } 00223 if( intx_area < 0 ) 00224 { 00225 std::cout << "negative intx area: " << intx_area << " n:" << num_nodes << " parents: " << sourceID << " " 00226 << targetID << "\n"; 00227 } 00228 if( check_sign < 0 ) 00229 { 00230 non_convex_intx_cells.insert( cell ); 00231 std::cout << " non-convex polygon: " << intx_area << " n:" << num_nodes << " parents: " << sourceID << " " 00232 << targetID << "\n"; 00233 } 00234 } 00235 Tag diffTag; 00236 rval = mb->tag_get_handle( "AreaDiff", 1, MB_TYPE_DOUBLE, diffTag, MB_TAG_DENSE | MB_TAG_CREAT );MB_CHK_ERR( rval ); 00237 00238 Tag countIntxCellsTag; 00239 rval = mb->tag_get_handle( "CountIntx", 1, MB_TYPE_INTEGER, countIntxCellsTag, MB_TAG_DENSE | MB_TAG_CREAT );MB_CHK_ERR( rval ); 00240 00241 for( Range::iterator eit = sourceCells.begin(); eit != sourceCells.end(); ++eit ) 00242 { 00243 EntityHandle cell = *eit; 00244 00245 int sourceID; 00246 rval = mb->tag_get_data( gidTag, &cell, 1, &sourceID );MB_CHK_ERR( rval ); 00247 double areaDiff = sourceAreas[sourceID]; 00248 std::map< int, double >::iterator sit = sourceAreasIntx.find( sourceID ); 00249 int countIntxCells = 0; 00250 if( sit != sourceAreasIntx.end() ) 00251 { 00252 areaDiff -= sourceAreasIntx[sourceID]; 00253 countIntxCells = sourceNbIntx[sourceID]; 00254 } 00255 rval = mb->tag_set_data( diffTag, &cell, 1, &areaDiff ); 00256 rval = mb->tag_set_data( countIntxCellsTag, &cell, 1, &countIntxCells ); 00257 // add to errorSourceSet set if needed 00258 if( ( areaErrSource > 0 ) && ( fabs( areaDiff ) > areaErrSource ) ) 00259 { 00260 rval = mb->add_entities( errorSourceSet, &cell, 1 );MB_CHK_ERR( rval ); 00261 } 00262 } 00263 if( 0 == rank ) std::cout << "write source verification file " << source_verif << "\n"; 00264 rval = mb->write_file( source_verif.c_str(), 0, 0, &sset, 1 );MB_CHK_ERR( rval ); 00265 if( areaErrSource > 0 ) 00266 { 00267 Range sourceErrorCells; 00268 rval = mb->get_entities_by_handle( errorSourceSet, sourceErrorCells );MB_CHK_ERR( rval ); 00269 EntityHandle errorSourceIntxSet; 00270 rval = mb->create_meshset( MESHSET_SET, errorSourceIntxSet );MB_CHK_ERR( rval ); 00271 if( !sourceErrorCells.empty() ) 00272 { 00273 // add the intx cells that have these as source parent 00274 std::vector< int > sourceIDs; 00275 sourceIDs.resize( sourceErrorCells.size() ); 00276 rval = mb->tag_get_data( gidTag, sourceErrorCells, &sourceIDs[0] );MB_CHK_SET_ERR( rval, "can't get source IDs" ); 00277 std::sort( sourceIDs.begin(), sourceIDs.end() ); 00278 for( Range::iterator eit = intxCells.begin(); eit != intxCells.end(); ++eit ) 00279 { 00280 EntityHandle cell = *eit; 00281 int sourceID; 00282 rval = mb->tag_get_data( sourceParentTag, &cell, 1, &sourceID );MB_CHK_ERR( rval ); 00283 std::vector< int >::iterator j = std::lower_bound( sourceIDs.begin(), sourceIDs.end(), sourceID ); 00284 if( ( j != sourceIDs.end() ) && ( *j == sourceID ) ) 00285 { 00286 rval = mb->add_entities( errorSourceIntxSet, &cell, 1 ); 00287 ;MB_CHK_ERR( rval ); 00288 } 00289 } 00290 std::string filtersource = std::string( "filt_" ) + source_verif; 00291 rval = mb->write_file( filtersource.c_str(), 0, 0, &errorSourceSet, 1 ); 00292 std::string filterIntxsource = std::string( "filtIntx_" ) + source_verif; 00293 rval = mb->write_file( filterIntxsource.c_str(), 0, 0, &errorSourceIntxSet, 1 ); 00294 } 00295 } 00296 00297 for( Range::iterator eit = targetCells.begin(); eit != targetCells.end(); ++eit ) 00298 { 00299 EntityHandle cell = *eit; 00300 00301 int targetID; 00302 rval = mb->tag_get_data( gidTag, &cell, 1, &targetID );MB_CHK_ERR( rval ); 00303 double areaDiff = targetAreas[targetID]; 00304 int countIntxCells = 0; 00305 std::map< int, double >::iterator sit = targetAreasIntx.find( targetID ); 00306 if( sit != targetAreasIntx.end() ) 00307 { 00308 areaDiff -= targetAreasIntx[targetID]; 00309 countIntxCells = targetNbIntx[targetID]; 00310 } 00311 00312 rval = mb->tag_set_data( diffTag, &cell, 1, &areaDiff ); 00313 rval = mb->tag_set_data( countIntxCellsTag, &cell, 1, &countIntxCells ); 00314 // add to errorTargetSet set if needed 00315 if( ( areaErrTarget > 0 ) && ( fabs( areaDiff ) > areaErrTarget ) ) 00316 { 00317 rval = mb->add_entities( errorTargetSet, &cell, 1 );MB_CHK_ERR( rval ); 00318 } 00319 } 00320 if( 0 == rank ) std::cout << "write target verification file " << target_verif << "\n"; 00321 rval = mb->write_file( target_verif.c_str(), 0, 0, &tset, 1 );MB_CHK_ERR( rval ); 00322 if( areaErrTarget > 0 ) 00323 { 00324 Range targetErrorCells; 00325 rval = mb->get_entities_by_handle( errorTargetSet, targetErrorCells );MB_CHK_ERR( rval ); 00326 if( !targetErrorCells.empty() ) 00327 { 00328 EntityHandle errorTargetIntxSet; 00329 rval = mb->create_meshset( MESHSET_SET, errorTargetIntxSet );MB_CHK_ERR( rval ); 00330 // add the intx cells that have these as target parent 00331 std::vector< int > targetIDs; 00332 targetIDs.resize( targetErrorCells.size() ); 00333 rval = mb->tag_get_data( gidTag, targetErrorCells, &targetIDs[0] );MB_CHK_SET_ERR( rval, "can't get target IDs" ); 00334 std::sort( targetIDs.begin(), targetIDs.end() ); 00335 for( Range::iterator eit = intxCells.begin(); eit != intxCells.end(); ++eit ) 00336 { 00337 EntityHandle cell = *eit; 00338 int targetID; 00339 rval = mb->tag_get_data( targetParentTag, &cell, 1, &targetID );MB_CHK_ERR( rval ); 00340 std::vector< int >::iterator j = std::lower_bound( targetIDs.begin(), targetIDs.end(), targetID ); 00341 if( ( j != targetIDs.end() ) && ( *j == targetID ) ) 00342 { 00343 rval = mb->add_entities( errorTargetIntxSet, &cell, 1 ); 00344 ;MB_CHK_ERR( rval ); 00345 } 00346 } 00347 std::string filterTarget = std::string( "filt_" ) + target_verif; 00348 rval = mb->write_file( filterTarget.c_str(), 0, 0, &errorTargetSet, 1 ); 00349 std::string filterIntxtarget = std::string( "filtIntx_" ) + target_verif; 00350 rval = mb->write_file( filterIntxtarget.c_str(), 0, 0, &errorTargetIntxSet, 1 ); 00351 } 00352 } 00353 00354 if( !non_convex_intx_cells.empty() ) 00355 { 00356 00357 sourceCells.clear(); 00358 targetCells.clear(); 00359 for( Range::iterator it = non_convex_intx_cells.begin(); it != non_convex_intx_cells.end(); it++ ) 00360 { 00361 EntityHandle cellIntx = *it; 00362 int sourceID, targetID; 00363 rval = mb->tag_get_data( sourceParentTag, &cellIntx, 1, &sourceID );MB_CHK_ERR( rval ); 00364 rval = mb->tag_get_data( targetParentTag, &cellIntx, 1, &targetID );MB_CHK_ERR( rval ); 00365 sourceCells.insert( sourceMap[sourceID] ); 00366 targetCells.insert( targetMap[targetID] ); 00367 } 00368 EntityHandle nonConvexSet; 00369 rval = mb->create_meshset( MESHSET_SET, nonConvexSet );MB_CHK_ERR( rval ); 00370 rval = mb->add_entities( nonConvexSet, non_convex_intx_cells ); 00371 rval = mb->write_file( "nonConvex.h5m", 0, 0, &nonConvexSet, 1 );MB_CHK_ERR( rval ); 00372 00373 EntityHandle sSet; 00374 rval = mb->create_meshset( MESHSET_SET, sSet );MB_CHK_ERR( rval ); 00375 rval = mb->add_entities( sSet, sourceCells ); 00376 rval = mb->write_file( "nonConvexSource.h5m", 0, 0, &sSet, 1 );MB_CHK_ERR( rval ); 00377 EntityHandle tSet; 00378 rval = mb->create_meshset( MESHSET_SET, tSet );MB_CHK_ERR( rval ); 00379 rval = mb->add_entities( tSet, targetCells ); 00380 rval = mb->write_file( "nonConvexTarget.h5m", 0, 0, &tSet, 1 );MB_CHK_ERR( rval ); 00381 rval = mb->add_entities( nonConvexSet, sourceCells ); 00382 rval = mb->add_entities( nonConvexSet, targetCells ); 00383 rval = mb->write_file( "nonConvexAll.h5m", 0, 0, &nonConvexSet, 1 );MB_CHK_ERR( rval ); 00384 } 00385 return 0; 00386 }
