MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /** 00002 * MOAB, a Mesh-Oriented datABase, is a software component for creating, 00003 * storing and accessing finite element mesh data. 00004 * 00005 * Copyright 2004 Sandia Corporation. Under the terms of Contract 00006 * DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government 00007 * retains certain rights in this software. 00008 * 00009 * This library is free software; you can redistribute it and/or 00010 * modify it under the terms of the GNU Lesser General Public 00011 * License as published by the Free Software Foundation; either 00012 * version 2.1 of the License, or (at your option) any later version. 00013 * 00014 */ 00015 00016 #include "Tqdcfr.hpp" 00017 #include "moab/Core.hpp" 00018 #include "moab/Range.hpp" 00019 #include "moab/FileOptions.hpp" 00020 #include "TestUtil.hpp" 00021 #include <iostream> 00022 #include <string> 00023 00024 #ifdef MOAB_HAVE_MPI 00025 #include "moab_mpi.h" 00026 #endif 00027 00028 using namespace moab; 00029 00030 int main( int argc, char* argv[] ) 00031 { 00032 #ifdef MOAB_HAVE_MPI 00033 MPI_Init( &argc, &argv ); 00034 #endif 00035 // Check command line arg 00036 std::string def_file( TestDir + "unittest/io/brick_cubit10.2.cub" ); 00037 const char* file = def_file.c_str(); 00038 if( argc < 2 ) 00039 { 00040 std::cout << "Usage: tqdcfr <cub_file_name>" << std::endl; 00041 // exit(1); 00042 } 00043 else 00044 file = argv[1]; 00045 00046 Core* my_impl = new Core(); 00047 Tqdcfr* my_tqd = new Tqdcfr( my_impl ); 00048 FileOptions opts( NULL ); 00049 00050 ErrorCode result = my_tqd->load_file( file, 0, opts, 0, 0 ); 00051 00052 if( MB_SUCCESS == result ) 00053 std::cout << "Success." << std::endl; 00054 else 00055 { 00056 std::cout << "load_file returned error:" << std::endl; 00057 std::string errs; 00058 result = my_impl->get_last_error( errs ); 00059 if( MB_SUCCESS == result ) 00060 std::cout << errs << std::endl; 00061 else 00062 std::cout << "(no message)" << std::endl; 00063 } 00064 00065 delete my_tqd; 00066 delete my_impl; 00067 00068 // now check for multiple procs 00069 my_impl = new Core; 00070 my_tqd = new Tqdcfr( my_impl ); 00071 00072 result = my_tqd->load_file( file, 0, opts, 0, 0 ); 00073 00074 if( MB_SUCCESS == result ) 00075 std::cout << "Success." << std::endl; 00076 else 00077 { 00078 std::cout << "load_file returned error:" << std::endl; 00079 std::string errstr; 00080 result = my_impl->get_last_error( errstr ); 00081 if( MB_SUCCESS == result ) 00082 std::cout << errstr << std::endl; 00083 else 00084 std::cout << "(no message)" << std::endl; 00085 } 00086 00087 delete my_tqd; 00088 delete my_impl; 00089 00090 #ifdef MOAB_HAVE_MPI 00091 int nprocs, rank; 00092 MPI_Comm_size( MPI_COMM_WORLD, &nprocs ); 00093 MPI_Comm_rank( MPI_COMM_WORLD, &rank ); 00094 00095 // create MOAB instance based on that 00096 my_impl = new Core; //(rank, nprocs); 00097 if( NULL == my_impl ) return 1; 00098 00099 std::string options = "PARALLEL=READ_DELETE;PARTITION=MATERIAL_SET;PARTITION_DISTRIBUTE"; 00100 std::cout << "Testing parallel..." << std::endl; 00101 00102 result = my_impl->load_file( file, 0, options.c_str() ); 00103 00104 if( MB_SUCCESS == result ) 00105 std::cout << "Success." << std::endl; 00106 else 00107 { 00108 std::cout << "load_file returned error:" << std::endl; 00109 std::string errstr; 00110 result = my_impl->get_last_error( errstr ); 00111 if( MB_SUCCESS == result ) 00112 std::cout << errstr << std::endl; 00113 else 00114 std::cout << "(no message)" << std::endl; 00115 } 00116 00117 delete my_impl; // done with the read 00118 MPI_Finalize(); 00119 #endif 00120 00121 return result; 00122 }
