MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /** 00002 * \class moab::Coupler 00003 * \author Tim Tautges 00004 * 00005 * \brief This class couples data between meshes. 00006 * 00007 * The coupler interpolates solution data at a set of points. Data 00008 * being interpolated resides on a source mesh, in a tag. 00009 * Applications calling this coupler send in entities, usually points 00010 * or vertices, and receive back the tag value interpolated at those 00011 * points. Entities in the source mesh containing those points 00012 * do not have to reside on the same processor. 00013 * 00014 * To use, an application should: 00015 * - instantiate this coupler by calling the constructor collectively 00016 * on all processors in the communicator 00017 * - call locate_points, which locates the points to be interpolated and 00018 * (optionally) caches the results in this object 00019 * - call interpolate, which does the interpolation 00020 * 00021 * Multiple interpolations can be done after locating the points. 00022 * 00023 */ 00024 #ifndef COUPLER_HPP 00025 #define COUPLER_HPP 00026 00027 #include "moab/Range.hpp" 00028 #include "moab/Interface.hpp" 00029 #include "moab/CartVect.hpp" 00030 #include "moab/TupleList.hpp" 00031 00032 #include <sstream> 00033 00034 namespace moab 00035 { 00036 00037 class ParallelComm; 00038 00039 class AdaptiveKDTree; 00040 00041 class TupleList; 00042 00043 class Coupler 00044 { 00045 public: 00046 enum Method 00047 { 00048 CONSTANT, 00049 LINEAR_FE, 00050 QUADRATIC_FE, 00051 SPECTRAL, 00052 SPHERICAL 00053 }; 00054 00055 enum IntegType 00056 { 00057 VOLUME 00058 }; 00059 00060 /* Constructor 00061 * Constructor, which also optionally initializes the coupler 00062 * \param pc ParallelComm object to be used with this coupler, representing the union 00063 * of processors containing source and target meshes 00064 * \param local_elems Local elements in the source mesh 00065 * \param coupler_id Id of this coupler, should be the same over all procs 00066 * \param init_tree If true, initializes kdtree inside the constructor 00067 */ 00068 Coupler( Interface* impl, 00069 ParallelComm* pc, 00070 Range& local_elems, 00071 int coupler_id, 00072 bool init_tree = true, 00073 int max_ent_dim = 3 ); 00074 00075 /* Destructor 00076 */ 00077 virtual ~Coupler(); 00078 00079 /** 00080 * \brief Initialize the kdtree, locally and across communicator 00081 */ 00082 ErrorCode initialize_tree(); 00083 00084 /* \brief Locate points on the source mesh 00085 * This function finds the element/processor/natural coordinates for the 00086 * source mesh element containing each point, optionally storing the results 00087 * on the target mesh processor. Relative tolerance is compared to bounding 00088 * box diagonal length. Tolerance is compared to [-1,1] parametric extent 00089 * in the reference element. 00090 * \param xyz Point locations (interleaved) being located 00091 * \param num_points Number of points in xyz 00092 * \param rel_eps Relative tolerance for the non-linear iteration inside a given element 00093 * \param abs_eps Absolute tolerance for the non-linear iteration inside a given element 00094 * \param tl Tuple list containing the results, with each tuple 00095 * consisting of (p, i), p = proc, i = index on that proc 00096 * \param store_local If true, stores the tuple list in targetPts 00097 */ 00098 ErrorCode locate_points( double* xyz, 00099 unsigned int num_points, 00100 double rel_eps = 0.0, 00101 double abs_eps = 0.0, 00102 TupleList* tl = NULL, 00103 bool store_local = true ); 00104 00105 /* \brief Locate entities on the source mesh 00106 * This function finds the element/processor/natural coordinates for the 00107 * source mesh element containing each entity, optionally storing the results 00108 * on the target mesh processor. Location of each target mesh entity passed in 00109 * is its centroid (for non-vertices, the avg of its vertex positions). 00110 * Relative tolerance is compared to bounding 00111 * box diagonal length. Tolerance is compared to [-1,1] parametric extent 00112 * in the reference element. 00113 * \param ents Entities being located 00114 * \param rel_eps Relative tolerance for the non-linear iteration inside a given element 00115 * \param abs_eps Absolute tolerance for the non-linear iteration inside a given element 00116 * \param tl Tuple list containing the results, with each tuple 00117 * consisting of (p, i), p = proc, i = index on that proc 00118 * \param store_local If true, stores the tuple list in targetPts 00119 * 00120 */ 00121 ErrorCode locate_points( Range& ents, 00122 double rel_eps = 0.0, 00123 double abs_eps = 0.0, 00124 TupleList* tl = NULL, 00125 bool store_local = true ); 00126 00127 /* \brief Interpolate data from the source mesh onto points 00128 * All entities/points or, if tuple_list is input, only those points 00129 * are interpolated from the source mesh. Application should 00130 * allocate enough memory in interp_vals to hold interpolation results. 00131 * 00132 * If normalization is requested, technique used depends on the coupling 00133 * method. 00134 * 00135 * \param method Interpolation/normalization method 00136 * \param tag Tag on source mesh holding data to be interpolated 00137 * \param interp_vals Memory holding interpolated data 00138 * \param tl Tuple list of points to be interpolated, in format used by targetPts 00139 * (see documentation for targetPts below); if NULL, all locations 00140 * in targetPts are interpolated 00141 * \param normalize If true, normalization is done according to method 00142 */ 00143 ErrorCode interpolate( Coupler::Method method, 00144 Tag tag, 00145 double* interp_vals, 00146 TupleList* tl = NULL, 00147 bool normalize = true ); 00148 00149 /* \brief Interpolate data from the source mesh onto points 00150 * All entities/points or, if tuple_list is input, only those points 00151 * are interpolated from the source mesh. Application should 00152 * allocate enough memory in interp_vals to hold interpolation results. 00153 * 00154 * If normalization is requested, technique used depends on the coupling 00155 * method. 00156 * 00157 * \param methods Interpolation/normalization method 00158 * \param tag_name Name of tag on source mesh holding data to be interpolated 00159 * \param interp_vals Memory holding interpolated data 00160 * \param tl Tuple list of points to be interpolated, in format used by targetPts 00161 * (see documentation for targetPts below); if NULL, all locations 00162 * in targetPts are interpolated 00163 * \param normalize If true, normalization is done according to method 00164 */ 00165 ErrorCode interpolate( Coupler::Method method, 00166 const std::string& tag_name, 00167 double* interp_vals, 00168 TupleList* tl = NULL, 00169 bool normalize = true ); 00170 00171 /* \brief Interpolate data from multiple tags 00172 * All entities/points or, if tuple_list is input, only those points 00173 * are interpolated from the source mesh. Application should 00174 * allocate enough memory in interp_vals to hold interpolation results. 00175 * 00176 * In this variant, multiple tags, possibly with multiple interpolation 00177 * methods, are specified. Sum of values in points_per_method should be 00178 * the number of points in tl or, if NULL, targetPts. 00179 * 00180 * If normalization is requested, technique used depends on the coupling 00181 * method. 00182 * 00183 * \param methods Vector of Interpolation/normalization methods 00184 * \param tag_names Names of tag being interpolated for each method 00185 * \param points_per_method Number of points for each method 00186 * \param num_methods Length of vectors in previous 3 arguments 00187 * \param interp_vals Memory holding interpolated data 00188 * \param tl Tuple list of points to be interpolated; if NULL, all locations 00189 * stored in this object are interpolated 00190 * \param normalize If true, normalization is done according to method 00191 */ 00192 ErrorCode interpolate( Coupler::Method* methods, 00193 const std::string* tag_names, 00194 int* points_per_method, 00195 int num_methods, 00196 double* interp_vals, 00197 TupleList* tl = NULL, 00198 bool normalize = true ); 00199 00200 /* \brief Interpolate data from multiple tags 00201 * All entities/points or, if tuple_list is input, only those points 00202 * are interpolated from the source mesh. Application should 00203 * allocate enough memory in interp_vals to hold interpolation results. 00204 * 00205 * In this variant, multiple tags, possibly with multiple interpolation 00206 * methods, are specified. Sum of values in points_per_method should be 00207 * the number of points in tl or, if NULL, targetPts. 00208 * 00209 * If normalization is requested, technique used depends on the coupling 00210 * method. 00211 * 00212 * \param methods Vector of Interpolation/normalization methods 00213 * \param tag_names Names of tag being interpolated for each method 00214 * \param points_per_method Number of points for each method 00215 * \param num_methods Length of vectors in previous 3 arguments 00216 * \param interp_vals Memory holding interpolated data 00217 * \param tl Tuple list of points to be interpolated; if NULL, all locations 00218 * stored in this object are interpolated 00219 * \param normalize If true, normalization is done according to method 00220 */ 00221 ErrorCode interpolate( Coupler::Method* methods, 00222 Tag* tag_names, 00223 int* points_per_method, 00224 int num_methods, 00225 double* interp_vals, 00226 TupleList* tl = NULL, 00227 bool normalize = true ); 00228 00229 /* \brief Normalize a field over an entire mesh 00230 * A field existing on the vertices of elements of a mesh is integrated 00231 * over all elements in the mesh. The integrated value is normalized 00232 * and the normalization factor is saved to a new tag 00233 * on the mesh entity set. 00234 * 00235 * \param root_set Entity Set representing the entire mesh 00236 * \param norm_tag Tag containing field data to integrate 00237 * \param integ_type Type of integration to perform 00238 * \param num_integ_pts The number of Gaussian integration points to use in each dimension 00239 */ 00240 ErrorCode normalize_mesh( EntityHandle root_set, 00241 const char* norm_tag, 00242 Coupler::IntegType integ_type, 00243 int num_integ_pts ); 00244 00245 /* \brief Normalize a field over subsets of entities 00246 * A field existing on the vertices of elements of a mesh is integrated 00247 * over subsets of elements identified by the tags and values. The integrated 00248 * values are normalized and the normalization factor is saved to a new tag 00249 * on the entity sets which contain the elements of a subset. 00250 * 00251 * \param root_set Entity Set from the mesh from which to select subsets 00252 * \param norm_tag Tag containing field data to integrate 00253 * \param tag_names Array of tag names used for selecting element subsets 00254 * \param num_tags Number of tag names 00255 * \param tag_values Array of tag values passed as strings; the array will be 00256 * the same length as that for tag names however some entries may be 00257 * NULL indicating that tag should be matched for existence and not value 00258 * \param integ_type Type of integration to perform 00259 * \param num_integ_pts The number of Gaussian integration points to use in each dimension 00260 */ 00261 ErrorCode normalize_subset( EntityHandle root_set, 00262 const char* norm_tag, 00263 const char** tag_names, 00264 int num_tags, 00265 const char** tag_values, 00266 Coupler::IntegType integ_type, 00267 int num_integ_pts ); 00268 00269 /* \brief Normalize a field over subsets of entities 00270 * A field existing on the vertices of elements of a mesh is integrated 00271 * over subsets of elements identified by the tags and values. The integrated 00272 * values are normalized and the normalization factor is saved to a new tag 00273 * on the entity sets which contain the elements of a subset. 00274 * 00275 * \param root_set Entity Set from the mesh from which to select subsets 00276 * \param norm_tag Tag containing field data to integrate 00277 * \param tag_handles Array of tag handles used for selecting element subsets 00278 * \param num_tags Number of tag handles 00279 * \param tag_values Array of tag values passed as strings; the array will be 00280 * the same length as that for tag handles however some entries may be 00281 * NULL indicating that tag should be matched for existence and not value 00282 * \param integ_type Type of integration to perform 00283 * \param num_integ_pts The number of Gaussian integration points to use in each dimension 00284 */ 00285 ErrorCode normalize_subset( EntityHandle root_set, 00286 const char* norm_tag, 00287 Tag* tag_handles, 00288 int num_tags, 00289 const char** tag_values, 00290 Coupler::IntegType integ_type, 00291 int num_integ_pts ); 00292 00293 /* \brief Retrieve groups of entities matching tags and values(if present) 00294 * Retrieve a vector of vectors of entity handles matching the 00295 * tags and values. The entity set passed is used as the search domain. 00296 * 00297 * \param norm_tag Tag containing field data to integrate 00298 * \param entity_sets Pointer to vector of vectors of entity set handles 00299 * \param entity_groups Pointer to vector of vectors of entity handles from each entity set 00300 * \param integ_type Type of integration to perform 00301 * \param num_integ_pts The number of Gaussian integration points to use in each dimension 00302 */ 00303 ErrorCode do_normalization( const char* norm_tag, 00304 std::vector< std::vector< EntityHandle > >& entity_sets, 00305 std::vector< std::vector< EntityHandle > >& entity_groups, 00306 Coupler::IntegType integ_type, 00307 int num_integ_pts ); 00308 00309 /* \brief Retrieve groups of entities matching tags and values(if present) 00310 * Retrieve a vector of vectors of entity handles matching the 00311 * tags and values. The entity set passed is used as the search domain. 00312 * 00313 * \param root_set Set from which to search for matching entities 00314 * \param tag_names Array of tag names used to select entities 00315 * \param tag_values Array of tag values used to select entities 00316 * \param num_tags Number of tag names 00317 * \param entity_sets Pointer to vector of vectors of entity set handles found in the search 00318 * \param entity_groups Pointer to vector of vectors of entity handles from each entity set 00319 */ 00320 ErrorCode get_matching_entities( EntityHandle root_set, 00321 const char** tag_names, 00322 const char** tag_values, 00323 int num_tags, 00324 std::vector< std::vector< EntityHandle > >* entity_sets, 00325 std::vector< std::vector< EntityHandle > >* entity_groups ); 00326 00327 /* \brief Retrieve groups of entities matching tags and values(if present) 00328 * Retrieve a vector of vectors of entity handles matching the 00329 * tags and values. The entity set passed is used as the search domain. 00330 * 00331 * \param root_set Set from which to search for matching entities 00332 * \param tag_handles Array of tag handles used to select entities 00333 * \param tag_values Array of tag values used to select entities 00334 * \param num_tags Number of tag handles 00335 * \param entity_sets Pointer to vector of vectors of entity set handles found in the search 00336 * \param entity_groups Pointer to vector of vectors of entity handles from each entity set 00337 */ 00338 ErrorCode get_matching_entities( EntityHandle root_set, 00339 Tag* tag_handles, 00340 const char** tag_values, 00341 int num_tags, 00342 std::vector< std::vector< EntityHandle > >* entity_sets, 00343 std::vector< std::vector< EntityHandle > >* entity_groups ); 00344 00345 /* \brief Return an array of tuples of tag values for each Entity Set 00346 * A list of n-tuples will be constructed with 1 n-tuple for each Entity Set. 00347 * The n-tuple will have an component for each tag given. It is assumed all 00348 * of the tags are integer tags. 00349 * 00350 * \param ent_sets Array of Entity Set handles to use for retrieving tag data 00351 * \param num_sets Number of Entity Sets 00352 * \param tag_names Array of tag names 00353 * \param num_tags Number of tag names 00354 * \param tuples The returned tuple_list structure 00355 */ 00356 ErrorCode create_tuples( Range& ent_sets, const char** tag_names, unsigned int num_tags, TupleList** tuples ); 00357 00358 /* \brief Return an array of tuples of tag values for each Entity Set 00359 * A list of n-tuples will be constructed with 1 n-tuple for each Entity Set. 00360 * The n-tuple will have an component for each tag given. It is assumed all 00361 * of the tags are integer tags. 00362 * 00363 * \param ent_sets Array of Entity Set handles to use for retrieving tag data 00364 * \param num_sets Number of Entity Sets 00365 * \param tag_handles Array of tag handles 00366 * \param num_tags Number of tag handles 00367 * \param tuples The returned tuple_list structure 00368 */ 00369 ErrorCode create_tuples( Range& ent_sets, Tag* tag_handles, unsigned int num_tags, TupleList** tuples ); 00370 00371 /* \brief Consolidate an array of n-tuples lists into one n-tuple list with no duplicates 00372 * An array of list of n-tuples are consolidated into a single list of n-tuples 00373 * with all duplicates removed. Only integer columns in the tuple_list are assumed to 00374 * be used. 00375 * 00376 * \param all_tuples Array of tuple_lists to consolidate to one 00377 * \param num_tuples Number of tuple_lists 00378 * \param unique_tuples The consolidated tuple_list with no duplicates 00379 */ 00380 ErrorCode consolidate_tuples( TupleList** all_tuples, unsigned int num_tuples, TupleList** unique_tuples ); 00381 00382 /* \brief Calculate integrated field values for groups of entities 00383 * An integrated field value, as defined by the field function, 00384 * is calculated for each group of entities passed in. 00385 * 00386 * \param groups The vector contains vectors of entity handles, each representing a group 00387 * \param integ_vals The integrated field values for each group 00388 * \param norm_tag The tag name of the vertex-based field to be integrated 00389 * \param num_integ_pts The number of Gaussian integration points to use in each dimension 00390 * \param integ_type Type of integration to perform 00391 */ 00392 ErrorCode get_group_integ_vals( std::vector< std::vector< EntityHandle > >& groups, 00393 std::vector< double >& integ_vals, 00394 const char* norm_tag, 00395 int num_integ_pts, 00396 Coupler::IntegType integ_type ); 00397 00398 /* \brief Apply a normalization factor to group of entities 00399 * Multiply a normalization factor with the value of norm_tag for each vertex 00400 * of each entity in a group. Save the value back to norm_tag on each vertex. 00401 * 00402 * \param entity_sets The vector contains vectors of entity set handles, each containing the 00403 * members of a group \param norm_factors The normalization factors for each group \param 00404 * norm_tag The tag to be normalized on each group \param integ_type Type of integration to 00405 * perform 00406 */ 00407 ErrorCode apply_group_norm_factor( std::vector< std::vector< EntityHandle > >& entity_sets, 00408 std::vector< double >& norm_factors, 00409 const char* norm_tag, 00410 Coupler::IntegType integ_type ); 00411 00412 /* 00413 * this method will look at source (and target sets?) sets, and look for the SEM_DIMS tag 00414 * if it exists, it will trigger a spectral element caching, with the order specified 00415 */ 00416 ErrorCode initialize_spectral_elements( EntityHandle rootSource, 00417 EntityHandle rootTarget, 00418 bool& specSou, 00419 bool& specTar ); 00420 00421 /* 00422 * this method will put in an array, interleaved, the points of interest for coupling 00423 * with a target mesh (so where do we need to compute the field of interest) 00424 */ 00425 ErrorCode get_gl_points_on_elements( Range& targ_elems, std::vector< double >& vpos, int& numPointsOfInterest ); 00426 00427 /* Get functions */ 00428 00429 inline Interface* mb_impl() const 00430 { 00431 return mbImpl; 00432 } 00433 inline AdaptiveKDTree* my_tree() const 00434 { 00435 return myTree; 00436 } 00437 inline EntityHandle local_root() const 00438 { 00439 return localRoot; 00440 } 00441 inline const std::vector< double >& all_boxes() const 00442 { 00443 return allBoxes; 00444 } 00445 inline ParallelComm* my_pc() const 00446 { 00447 return myPc; 00448 } 00449 inline const Range& target_ents() const 00450 { 00451 return targetEnts; 00452 } 00453 inline int my_id() const 00454 { 00455 return myId; 00456 } 00457 inline const Range& my_range() const 00458 { 00459 return myRange; 00460 } 00461 inline TupleList* mapped_pts() const 00462 { 00463 return mappedPts; 00464 } 00465 inline int num_its() const 00466 { 00467 return numIts; 00468 } 00469 // used for spherical tests 00470 inline void set_spherical( bool arg1 = true ) 00471 { 00472 spherical = arg1; 00473 } 00474 00475 private: 00476 // Given a coordinate position, find all entities containing 00477 // the point and the natural coords in those ents 00478 ErrorCode nat_param( double xyz[3], 00479 std::vector< EntityHandle >& entities, 00480 std::vector< CartVect >& nat_coords, 00481 double epsilon = 0.0 ); 00482 00483 ErrorCode interp_field( EntityHandle elem, CartVect nat_coord, Tag tag, double& field ); 00484 00485 ErrorCode constant_interp( EntityHandle elem, Tag tag, double& field ); 00486 00487 ErrorCode test_local_box( double* xyz, 00488 int from_proc, 00489 int remote_index, 00490 int index, 00491 bool& point_located, 00492 double rel_eps = 0.0, 00493 double abs_eps = 0.0, 00494 TupleList* tl = NULL ); 00495 00496 /* \brief MOAB instance 00497 */ 00498 Interface* mbImpl; 00499 00500 /* \brief Kdtree for local mesh 00501 */ 00502 AdaptiveKDTree* myTree; 00503 00504 /* \brief Local root of the kdtree 00505 */ 00506 EntityHandle localRoot; 00507 00508 /* \brief Min/max bounding boxes for all proc tree roots 00509 */ 00510 std::vector< double > allBoxes; 00511 00512 /* \brief ParallelComm object for this coupler 00513 */ 00514 ParallelComm* myPc; 00515 00516 /* \brief Id of this coupler 00517 */ 00518 int myId; 00519 00520 /* \brief Range of source elements 00521 */ 00522 Range myRange; 00523 00524 /* \brief Range of target entities 00525 */ 00526 Range targetEnts; 00527 00528 /* \brief List of locally mapped tuples 00529 * Tuples contain the following: 00530 * n = # mapped points 00531 * vul[i] = local handle of mapped entity 00532 * vr[3*i..3*i+2] = natural coordinates in mapped entity 00533 */ 00534 TupleList* mappedPts; 00535 00536 /* \brief Tuple list of target points and interpolated data 00537 * Tuples contain the following: 00538 * n = # target points 00539 * vi[3*i] = remote proc mapping target point 00540 * vi[3*i+1] = local index of target point 00541 * vi[3*i+2] = remote index of target point 00542 */ 00543 TupleList* targetPts; 00544 00545 /* \brief Number of iterations of tree building before failing 00546 * 00547 */ 00548 int numIts; 00549 00550 // Entity dimension 00551 int max_dim; 00552 00553 // A cached spectral element for source and target, separate 00554 // Assume that their number of GL points (order + 1) does not change 00555 // If it does change, we need to reinitialize it 00556 void* _spectralSource; 00557 void* _spectralTarget; 00558 moab::Tag _xm1Tag, _ym1Tag, _zm1Tag; 00559 int _ntot; 00560 00561 // spherical coupling 00562 bool spherical; 00563 }; 00564 00565 inline ErrorCode Coupler::interpolate( Coupler::Method method, 00566 Tag tag, 00567 double* interp_vals, 00568 TupleList* tl, 00569 bool normalize ) 00570 { 00571 int num_pts = ( tl ? tl->get_n() : targetPts->get_n() ); 00572 return interpolate( &method, &tag, &num_pts, 1, interp_vals, tl, normalize ); 00573 } 00574 00575 } // namespace moab 00576 00577 #endif
