MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 //------------------------------------------------------------------------- 00002 // Filename : NCHelperMPAS.hpp 00003 // 00004 // Purpose : Climate NC file helper for MPAS grid 00005 // 00006 // Creator : Danqing Wu 00007 //------------------------------------------------------------------------- 00008 00009 #ifndef NCHELPERMPAS_HPP 00010 #define NCHELPERMPAS_HPP 00011 00012 #include "NCHelper.hpp" 00013 00014 namespace moab 00015 { 00016 #ifdef MOAB_HAVE_MPI 00017 class ParallelComm; 00018 #endif 00019 //! Child helper class for MPAS grid 00020 class NCHelperMPAS : public UcdNCHelper 00021 { 00022 public: 00023 NCHelperMPAS( ReadNC* readNC, int fileId, const FileOptions& opts, EntityHandle fileSet ); 00024 static bool can_read_file( ReadNC* readNC ); 00025 00026 private: 00027 //! Implementation of NCHelper::init_mesh_vals() 00028 virtual ErrorCode init_mesh_vals(); 00029 //! Implementation of NCHelper::check_existing_mesh() 00030 virtual ErrorCode check_existing_mesh(); 00031 //! Implementation of NCHelper::create_mesh() 00032 virtual ErrorCode create_mesh( Range& faces ); 00033 //! Implementation of NCHelper::get_mesh_type_name() 00034 virtual std::string get_mesh_type_name() 00035 { 00036 return "MPAS"; 00037 } 00038 00039 //! Implementation of UcdNCHelper::read_ucd_variables_to_nonset_allocate() 00040 virtual ErrorCode read_ucd_variables_to_nonset_allocate( std::vector< ReadNC::VarData >& vdatas, 00041 std::vector< int >& tstep_nums ); 00042 #ifdef MOAB_HAVE_PNETCDF 00043 //! Implementation of UcdNCHelper::read_ucd_variables_to_nonset_async() 00044 virtual ErrorCode read_ucd_variables_to_nonset_async( std::vector< ReadNC::VarData >& vdatas, 00045 std::vector< int >& tstep_nums ); 00046 #else 00047 //! Implementation of UcdNCHelper::read_ucd_variables_to_nonset() 00048 virtual ErrorCode read_ucd_variables_to_nonset( std::vector< ReadNC::VarData >& vdatas, 00049 std::vector< int >& tstep_nums ); 00050 #endif 00051 00052 #ifdef MOAB_HAVE_MPI 00053 //! Redistribute local cells after trivial partition (e.g. Zoltan partition, if applicable) 00054 ErrorCode redistribute_local_cells( int start_cell_index, ParallelComm * pco ); 00055 #endif 00056 00057 //! Create local vertices 00058 ErrorCode create_local_vertices( const std::vector< int >& vertices_on_local_cells, EntityHandle& start_vertex ); 00059 00060 //! Create local edges (optional) 00061 ErrorCode create_local_edges( EntityHandle start_vertex, const std::vector< int >& num_edges_on_local_cells ); 00062 00063 //! Create local cells without padding (cells are divided into groups based on the number of 00064 //! edges) 00065 ErrorCode create_local_cells( const std::vector< int >& vertices_on_local_cells, 00066 const std::vector< int >& num_edges_on_local_cells, 00067 EntityHandle start_vertex, 00068 Range& faces ); 00069 00070 //! Create local cells with padding (padded cells will have the same number of edges) 00071 ErrorCode create_padded_local_cells( const std::vector< int >& vertices_on_local_cells, 00072 EntityHandle start_vertex, 00073 Range& faces ); 00074 00075 //! Create gather set vertices 00076 ErrorCode create_gather_set_vertices( EntityHandle gather_set, EntityHandle& gather_set_start_vertex ); 00077 00078 //! Create gather set edges (optional) 00079 ErrorCode create_gather_set_edges( EntityHandle gather_set, EntityHandle gather_set_start_vertex ); 00080 00081 //! Create gather set cells without padding (cells are divided into groups based on the number 00082 //! of edges) 00083 ErrorCode create_gather_set_cells( EntityHandle gather_set, EntityHandle gather_set_start_vertex ); 00084 00085 //! Create gather set cells with padding (padded cells will have the same number of edges) 00086 ErrorCode create_padded_gather_set_cells( EntityHandle gather_set, EntityHandle gather_set_start_vertex ); 00087 00088 private: 00089 int maxEdgesPerCell; 00090 int numCellGroups; 00091 bool createGatherSet; 00092 std::map< EntityHandle, int > cellHandleToGlobalID; 00093 Range facesOwned; 00094 }; 00095 00096 } // namespace moab 00097 00098 #endif
