MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /** 00002 * MOAB, a Mesh-Oriented datABase, is a software component for creating, 00003 * storing and accessing finite element mesh data. 00004 * 00005 * Copyright 2004 Sandia Corporation. Under the terms of Contract 00006 * DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government 00007 * retains certain rights in this software. 00008 * 00009 * This library is free software; you can redistribute it and/or 00010 * modify it under the terms of the GNU Lesser General Public 00011 * License as published by the Free Software Foundation; either 00012 * version 2.1 of the License, or (at your option) any later version. 00013 * 00014 */ 00015 00016 #ifndef VAR_LEN_SPARSE_TAG_HPP 00017 #define VAR_LEN_SPARSE_TAG_HPP 00018 00019 #ifndef IS_BUILDING_MB 00020 #error "VarLenSparseTag.hpp isn't supposed to be included into an application" 00021 #endif 00022 00023 #ifdef WIN32 00024 #pragma warning( disable : 4786 ) 00025 #endif 00026 00027 #include "moab/MOABConfig.h" 00028 #define STRINGIFY_( X ) #X 00029 #define STRINGIFY( X ) STRINGIFY_( X ) 00030 #ifdef MOAB_HAVE_UNORDERED_MAP 00031 #include STRINGIFY( MOAB_HAVE_UNORDERED_MAP ) 00032 #else 00033 #include <map> 00034 #endif 00035 #include <vector> 00036 00037 #include "TagInfo.hpp" 00038 #include "VarLenTag.hpp" 00039 #include <cstdlib> 00040 00041 namespace moab 00042 { 00043 00044 //! Sparse tag variable-length data 00045 class VarLenSparseTag : public TagInfo 00046 { 00047 public: 00048 VarLenSparseTag( const char* name, DataType type, const void* default_value, int default_value_bytes ); 00049 00050 ~VarLenSparseTag(); 00051 00052 virtual TagType get_storage_type() const; 00053 00054 /**\brief Remove/clear tag data for all entities 00055 * 00056 * Remove tag values from entities. 00057 * 00058 *\param delete_pending If true, then release any global 00059 * data associated with the tag in preparation for deleting 00060 * the tag itself. 00061 * 00062 *\Note Invalidates tag if \c tag_delete_pending is true. The only 00063 * valid method that can be invoked that is is the destructor. 00064 * 00065 *\param seqman Pointer to mesh entity database 00066 */ 00067 virtual ErrorCode release_all_data( SequenceManager* seqman, Error* error_handler, bool delete_pending ); 00068 00069 /**\brief Get tag value for passed entities 00070 * 00071 * Get tag values for specified entities. 00072 * 00073 *\Note Will fail for variable-length data. 00074 *\param seqman Pointer to mesh entity database 00075 *\param entities Entity handles for which to retrieve tag data 00076 *\param num_entities Length of \c entities array 00077 *\param data Pointer to memory in which to store consecutive tag values, 00078 * one for each passed entity. 00079 */ 00080 virtual ErrorCode get_data( const SequenceManager* seqman, 00081 Error* error_handler, 00082 const EntityHandle* entities, 00083 size_t num_entities, 00084 void* data ) const; 00085 00086 /**\brief Get tag value for passed entities 00087 * 00088 * Get tag values for specified entities. 00089 * 00090 *\Note Will fail for variable-length data. 00091 *\param seqman Pointer to mesh entity database 00092 *\param entities Entity handles for which to retrieve tag data 00093 *\param data Pointer to memory in which to store consecutive tag values, 00094 * one for each passed entity. 00095 */ 00096 virtual ErrorCode get_data( const SequenceManager* seqman, 00097 Error* error_handler, 00098 const Range& entities, 00099 void* data ) const; 00100 00101 /**\brief Get tag value for passed entities 00102 * 00103 * Get tag values for specified entities. 00104 * 00105 *\param seqman Pointer to mesh entity database 00106 *\param entities Entity handles for which to retrieve tag data 00107 *\param num_entities Length of \c entities array 00108 *\param data_ptrs Array of pointers to tag values, one pointer 00109 * for each passed entity. 00110 *\param data_lengths One value for each entity specifying the 00111 * length of the tag value for the corresponding 00112 * entity. 00113 */ 00114 virtual ErrorCode get_data( const SequenceManager* seqman, 00115 Error* error_handler, 00116 const EntityHandle* entities, 00117 size_t num_entities, 00118 const void** data_ptrs, 00119 int* data_lengths ) const; 00120 00121 /**\brief Get tag value for passed entities 00122 * 00123 * Get tag values for specified entities. 00124 * 00125 *\param seqman Pointer to mesh entity database 00126 *\param entities Entity handles for which to retrieve tag data 00127 *\param data_ptrs Array of pointers to tag values, one pointer 00128 * for each passed entity. 00129 *\param data_lengths One value for each entity specifying the 00130 * length of the tag value for the corresponding 00131 * entity. 00132 */ 00133 virtual ErrorCode get_data( const SequenceManager* seqman, 00134 Error* error_handler, 00135 const Range& entities, 00136 const void** data_ptrs, 00137 int* data_lengths ) const; 00138 00139 /**\brief Set tag value for passed entities 00140 * 00141 * Store tag data or update stored tag values 00142 *\Note Will fail for variable-length data. 00143 *\param seqman Pointer to mesh entity database 00144 *\param entities Entity handles for which to store tag data 00145 *\param num_entities Length of \c entities array 00146 *\param data Pointer to memory holding consecutive tag values, 00147 * one for each passed entity. 00148 */ 00149 virtual ErrorCode set_data( SequenceManager* seqman, 00150 Error* error_handler, 00151 const EntityHandle* entities, 00152 size_t num_entities, 00153 const void* data ); 00154 00155 /**\brief Set tag value for passed entities 00156 * 00157 * Store tag data or update stored tag values 00158 *\Note Will fail for variable-length data. 00159 *\param seqman Pointer to mesh entity database 00160 *\param entities Entity handles for which to store tag data 00161 *\param data Pointer to memory holding consecutive tag values, 00162 * one for each passed entity. 00163 */ 00164 virtual ErrorCode set_data( SequenceManager* seqman, 00165 Error* error_handler, 00166 const Range& entities, 00167 const void* data ); 00168 00169 /**\brief Set tag value for passed entities 00170 * 00171 * Store tag data or update stored tag values 00172 * 00173 *\param seqman Pointer to mesh entity database 00174 *\param entities Entity handles for which to store tag data 00175 *\param num_entities Length of \c entities array 00176 *\param data_ptrs Array of pointers to tag values, one pointer 00177 * for each passed entity. 00178 *\param data_lengths One value for each entity specifying the 00179 * length of the tag value for the corresponding 00180 * entity. Array is required for variable-length 00181 * tags and is ignored for fixed-length tags. 00182 */ 00183 virtual ErrorCode set_data( SequenceManager* seqman, 00184 Error* error_handler, 00185 const EntityHandle* entities, 00186 size_t num_entities, 00187 void const* const* data_ptrs, 00188 const int* data_lengths ); 00189 00190 /**\brief Set tag value for passed entities 00191 * 00192 * Store tag data or update stored tag values 00193 * 00194 *\param seqman Pointer to mesh entity database 00195 *\param entities Entity handles for which to store tag data 00196 *\param data_ptrs Array of pointers to tag values, one pointer 00197 * for each passed entity. 00198 *\param data_lengths One value for each entity specifying the 00199 * length of the tag value for the corresponding 00200 * entity. Array is required for variable-length 00201 * tags and is ignored for fixed-length tags. 00202 */ 00203 virtual ErrorCode set_data( SequenceManager* seqman, 00204 Error* error_handler, 00205 const Range& entities, 00206 void const* const* data_ptrs, 00207 const int* data_lengths ); 00208 00209 /**\brief Set tag value for passed entities 00210 * 00211 * Store tag data or update stored tag values. 00212 * 00213 *\param seqman Pointer to mesh entity database 00214 *\param entities Entity handles for which to store tag data 00215 *\param num_entities Length of \c entities array 00216 *\param value_ptr Pointer to a single tag value which is to be 00217 * stored for each of the passed entities. 00218 *\param value_len Length of tag value in bytes. Ignored for 00219 * fixed-length tags. Required for variable- 00220 * length tags. 00221 */ 00222 virtual ErrorCode clear_data( SequenceManager* seqman, 00223 Error* error_handler, 00224 const EntityHandle* entities, 00225 size_t num_entities, 00226 const void* value_ptr, 00227 int value_len = 0 ); 00228 00229 /**\brief Set tag value for passed entities 00230 * 00231 * Store tag data or update stored tag values. 00232 * 00233 *\param seqman Pointer to mesh entity database 00234 *\param entities Entity handles for which to store tag data 00235 *\param value_ptr Pointer to a single tag value which is to be 00236 * stored for each of the passed entities. 00237 *\param value_len Length of tag value in bytes. Ignored for 00238 * fixed-length tags. Required for variable- 00239 * length tags. 00240 */ 00241 virtual ErrorCode clear_data( SequenceManager* seqman, 00242 Error* error_handler, 00243 const Range& entities, 00244 const void* value_ptr, 00245 int value_len = 0 ); 00246 00247 /**\brief Remove/clear tag data for entities 00248 * 00249 * Remove tag values from entities. 00250 * 00251 *\param seqman Pointer to mesh entity database 00252 *\param entities Entity handles for which to store tag data 00253 *\param num_entities Length of \c entities array 00254 */ 00255 virtual ErrorCode remove_data( SequenceManager* seqman, 00256 Error* error_handler, 00257 const EntityHandle* entities, 00258 size_t num_entities ); 00259 00260 /**\brief Remove/clear tag data for entities 00261 * 00262 * Remove tag values from entities. 00263 * 00264 *\param seqman Pointer to mesh entity database 00265 *\param entities Entity handles for which to store tag data 00266 */ 00267 virtual ErrorCode remove_data( SequenceManager* seqman, Error* error_handler, const Range& entities ); 00268 00269 /**\brief Access tag data via direct pointer into contiguous blocks 00270 * 00271 * Iteratively obtain direct access to contiguous blocks of tag 00272 * storage. This function cannot be used with bit tags because 00273 * of the compressed bit storage. This function cannot be used 00274 * with variable length tags because it does not provide a mechanism 00275 * to determine the length of the value for each entity. This 00276 * function may be used with sparse tags, but if it is used, it 00277 * will return data for a single entity at a time. 00278 * 00279 *\param iter As input, the first entity for which to return 00280 * data. As output, one past the last entity for 00281 * which data was returned. 00282 *\param end One past the last entity for which data is desired 00283 *\param data_ptr Output: pointer to tag storage. 00284 * 00285 *\Note If this function is called for entities for which no tag value 00286 * has been set, but for which a default value exists, it will 00287 * force the allocation of explicit storage for each such entity 00288 * even though MOAB would normally not explicitly store tag values 00289 * for such entities. 00290 */ 00291 virtual ErrorCode tag_iterate( SequenceManager* seqman, 00292 Error* error_handler, 00293 Range::iterator& iter, 00294 const Range::iterator& end, 00295 void*& data_ptr, 00296 bool allocate = true ); 00297 00298 /**\brief Get all tagged entities 00299 * 00300 * Get the list of entities for which the a tag value has been set, 00301 * or a close approximation if the tag storage scheme cannot 00302 * accurately determine exactly which entities have explicit values. 00303 * 00304 *\param seqman Pointer to entity storage database 00305 *\param output_entities Results *appended* to this range 00306 *\param type Optional entity type. If specified, search is 00307 * limited to entities of specified type. 00308 *\param intersect Optional intersect list. If specified, 00309 * search is restricted to entities in this list. 00310 */ 00311 virtual ErrorCode get_tagged_entities( const SequenceManager* seqman, 00312 Range& output_entities, 00313 EntityType type = MBMAXTYPE, 00314 const Range* intersect = 0 ) const; 00315 00316 /**\brief Count all tagged entities 00317 * 00318 * Count the entities for which the a tag value has been set, 00319 * or a close approximation if the tag storage scheme cannot 00320 * accurately determine exactly which entities have explicit values. 00321 * 00322 *\param seqman Pointer to entity storage database 00323 *\param output_count This is *incremented* for each detected entity. 00324 *\param type Optional entity type. If specified, search is 00325 * limited to entities of specified type. 00326 *\param intersect Optional intersect list. If specified, 00327 * search is restricted to entities in this list. 00328 */ 00329 virtual ErrorCode num_tagged_entities( const SequenceManager* seqman, 00330 size_t& output_count, 00331 EntityType type = MBMAXTYPE, 00332 const Range* intersect = 0 ) const; 00333 00334 /**\brief Get all tagged entities with tag value 00335 * 00336 * Get the list of entities which have the specified tag value. 00337 * 00338 *\param seqman Pointer to entity storage database 00339 *\param output_entities Results *appended* to this range 00340 *\param value Pointer to tag value 00341 *\param value_bytes Size of tag value in bytes. 00342 *\param type Optional entity type. If specified, search is 00343 * limited to entities of specified type. 00344 *\param intersect_entities Optional intersect list. If specified, 00345 * search is restricted to entities in this list. 00346 */ 00347 virtual ErrorCode find_entities_with_value( const SequenceManager* seqman, 00348 Error* error_handler, 00349 Range& output_entities, 00350 const void* value, 00351 int value_bytes = 0, 00352 EntityType type = MBMAXTYPE, 00353 const Range* intersect_entities = 0 ) const; 00354 00355 /**\brief Check if entity is tagged */ 00356 virtual bool is_tagged( const SequenceManager*, EntityHandle h ) const; 00357 00358 /**\brief Get memory use for tag data. 00359 * 00360 */ 00361 virtual ErrorCode get_memory_use( const SequenceManager* seqman, 00362 unsigned long& total, 00363 unsigned long& per_entity ) const; 00364 00365 //! get number of entities 00366 unsigned long get_number_entities() 00367 { 00368 return mData.size(); 00369 } 00370 00371 //! map of entity id and tag data 00372 #ifdef MOAB_HAVE_UNORDERED_MAP 00373 typedef MOAB_UNORDERED_MAP_NS::unordered_map< EntityHandle, VarLenTag > MapType; 00374 #else 00375 typedef std::map< EntityHandle, VarLenTag > MapType; 00376 #endif 00377 00378 private: 00379 VarLenSparseTag( const VarLenSparseTag& ); 00380 VarLenSparseTag& operator=( const VarLenSparseTag& ); 00381 00382 //! get the variable-length data for an entity id 00383 inline ErrorCode get_data_ptr( Error* error_handler, 00384 EntityHandle entity_handle, 00385 const void*& data, 00386 int& size ) const; 00387 00388 MapType mData; 00389 }; 00390 00391 } // namespace moab 00392 00393 #endif // VAR_LEN_SPARSE_TAG_HPP
