MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 // MOAB includes 00002 #include "moab/ParallelComm.hpp" 00003 #include "MBParallelConventions.h" 00004 #include "moab/Core.hpp" 00005 #include "Coupler.hpp" 00006 #include "moab_mpi.h" 00007 #include "ElemUtil.hpp" 00008 #include "TestUtil.hpp" 00009 00010 // C++ includes 00011 #include <iostream> 00012 #include <iomanip> 00013 #include <sstream> 00014 #include <cassert> 00015 00016 using namespace moab; 00017 00018 /* 00019 Sample usages: 00020 1) P_0 interpolation: ./mbcoupler_test -meshes <src_mesh> <target_mesh> -itag <interp_tag> -meth 00021 0 -outfile <output> 2) P_1 interpolation: ./mbcoupler_test -meshes <src_mesh> <target_mesh> -itag 00022 <interp_tag> -meth 1 -outfile <output> 3) P_1 interpolation with epsilon control: ./mbcoupler_test 00023 -meshes <src_mesh> <target_mesh> -itag <interp_tag> -meth 1 -eps <tolerance for locating points; 00024 say 0.01> -outfile <output> 3) P_0 interpolation with global normalization: ./mbcoupler_test 00025 -meshes <src_mesh> <target_mesh> -itag <interp_tag> -meth 0 -gnorm <gnorm_tag_name> -outfile 00026 <output> 4) P_1 interpolation with subset normalization: ./mbcoupler_test -meshes <src_mesh> 00027 <target_mesh> -itag <interp_tag> -meth 1 -ssnorm <snorm_tag_name> <snorm_criteria: MATERIAL_SET> 00028 -outfile <output> 5) P_1 interpolation for meshes on sphere ./mbcoupler_test -meshes <src_mesh> 00029 <target_mesh> -itag <interp_tag> -meth 4 -outfile <output> 00030 */ 00031 00032 // Print usage 00033 void print_usage() 00034 { 00035 std::cerr << "Usage: "; 00036 std::cerr << "mbcoupler_test -meshes <source_mesh> <target_mesh> -itag <interp_tag> [-gnorm " 00037 "<gnorm_tag>] [-ssnorm <ssnorm_tag> <ssnorm_selection>] [-ropts <roptions>] " 00038 "[-outfile <out_file> [-wopts <woptions>]] [-dbgout [<dbg_file>]]" 00039 << std::endl; 00040 std::cerr << " -meshes" << std::endl; 00041 std::cerr << " Read in mesh files <source_mesh> and <target_mesh>." << std::endl; 00042 std::cerr << " -itag" << std::endl; 00043 std::cerr << " Interpolate tag <interp_tag> from source mesh to target mesh." << std::endl; 00044 std::cerr << " -gnorm" << std::endl; 00045 std::cerr << " Normalize the value of tag <gnorm_tag> over then entire mesh and save to" << std::endl; 00046 std::cerr << " tag \"<gnorm_tag>_normf\" on the mesh set. Do this for all meshes." << std::endl; 00047 std::cerr << " -ssnorm" << std::endl; 00048 std::cerr << " Normalize the value of tag <ssnorm_tag> over subsets of a mesh and save to" << std::endl; 00049 std::cerr << " tag \"<ssnorm_tag>_normf\" on the Entity Set for each subset. Subsets " 00050 "are selected" 00051 << std::endl; 00052 std::cerr << " using criteria in <ssnorm_selection>. Do this for all meshes." << std::endl; 00053 std::cerr << " -ropts" << std::endl; 00054 std::cerr << " Read in the mesh files using options in <roptions>." << std::endl; 00055 std::cerr << " -outfile" << std::endl; 00056 std::cerr << " Write out target mesh to <out_file>." << std::endl; 00057 std::cerr << " -wopts" << std::endl; 00058 std::cerr << " Write out mesh files using options in <woptions>." << std::endl; 00059 std::cerr << " -dbgout" << std::endl; 00060 std::cerr << " Write stdout and stderr streams to the file \'<dbg_file>.txt\'." << std::endl; 00061 std::cerr << " -eps" << std::endl; 00062 std::cerr << " epsilon" << std::endl; 00063 std::cerr << " -meth <method> (0=CONSTANT, 1=LINEAR_FE, 2=QUADRATIC_FE, 3=SPECTRAL, 4=SPHERICAL)" << std::endl; 00064 } 00065 00066 #ifdef MOAB_HAVE_HDF5 00067 00068 ErrorCode get_file_options( int argc, 00069 char** argv, 00070 int nprocs, 00071 int rank, 00072 std::vector< std::string >& meshFiles, 00073 Coupler::Method& method, 00074 std::string& interpTag, 00075 std::string& gNormTag, 00076 std::string& ssNormTag, 00077 std::vector< const char* >& ssTagNames, 00078 std::vector< const char* >& ssTagValues, 00079 std::string& readOpts, 00080 std::string& outFile, 00081 std::string& writeOpts, 00082 std::string& dbgFile, 00083 bool& help, 00084 double& epsilon ); 00085 00086 ErrorCode report_iface_ents( Interface* mbImpl, std::vector< ParallelComm* >& pcs, bool print_results ); 00087 00088 ErrorCode test_interpolation( Interface* mbImpl, 00089 Coupler::Method method, 00090 std::string& interpTag, 00091 std::string& gNormTag, 00092 std::string& ssNormTag, 00093 std::vector< const char* >& ssTagNames, 00094 std::vector< const char* >& ssTagValues, 00095 EntityHandle* roots, 00096 std::vector< ParallelComm* >& pcs, 00097 double& instant_time, 00098 double& pointloc_time, 00099 double& interp_time, 00100 double& gnorm_time, 00101 double& ssnorm_time, 00102 double& toler ); 00103 00104 void reduceMax( double& v ) 00105 { 00106 double buf; 00107 00108 MPI_Barrier( MPI_COMM_WORLD ); 00109 MPI_Allreduce( &v, &buf, 1, MPI_DOUBLE, MPI_MAX, MPI_COMM_WORLD ); 00110 00111 v = buf; 00112 } 00113 00114 int main( int argc, char** argv ) 00115 { 00116 // Need to init MPI first, to tell how many procs and rank 00117 int ierr = MPI_Init( &argc, &argv ); 00118 assert( MPI_SUCCESS == ierr ); 00119 00120 std::vector< const char* > ssTagNames, ssTagValues; 00121 std::vector< std::string > meshFiles; 00122 std::string interpTag, gNormTag, ssNormTag, readOpts, outFile, writeOpts, dbgFile; 00123 Coupler::Method method = Coupler::CONSTANT; 00124 00125 ErrorCode result; 00126 bool help = false; 00127 double toler = 5.e-10; 00128 int nprocs, rank; 00129 ierr = MPI_Comm_size( MPI_COMM_WORLD, &nprocs ); 00130 assert( MPI_SUCCESS == ierr ); 00131 ierr = MPI_Comm_rank( MPI_COMM_WORLD, &rank ); 00132 assert( MPI_SUCCESS == ierr ); 00133 00134 result = get_file_options( argc, argv, nprocs, rank, meshFiles, method, interpTag, gNormTag, ssNormTag, ssTagNames, 00135 ssTagValues, readOpts, outFile, writeOpts, dbgFile, help, toler ); 00136 00137 if( result != MB_SUCCESS || help ) 00138 { 00139 print_usage(); 00140 ierr = MPI_Finalize(); 00141 return ierr; 00142 } 00143 00144 // Redirect stdout and stderr if dbgFile is not null 00145 if( !dbgFile.empty() ) 00146 { 00147 std::stringstream dfname; 00148 dfname << dbgFile << rank << ".txt"; 00149 if( !std::freopen( dfname.str().c_str(), "a", stdout ) ) return -1; 00150 if( !std::freopen( dfname.str().c_str(), "a", stderr ) ) return -1; 00151 } 00152 00153 // Create MOAB instance based on that 00154 Interface* mbImpl = new( std::nothrow ) Core(); 00155 if( NULL == mbImpl ) return 1; 00156 00157 // Read in mesh(es) 00158 std::vector< ParallelComm* > pcs( meshFiles.size() ); 00159 00160 // Create root sets for each mesh using the iMesh API. Then pass these 00161 // to the load_file functions to be populated. 00162 EntityHandle* roots = (EntityHandle*)malloc( sizeof( EntityHandle ) * meshFiles.size() ); 00163 00164 for( unsigned int i = 0; i < meshFiles.size(); i++ ) 00165 { 00166 pcs[i] = new ParallelComm( mbImpl, MPI_COMM_WORLD ); 00167 int index = pcs[i]->get_id(); 00168 std::string newReadopts; 00169 std::ostringstream extraOpt; 00170 extraOpt << ";PARALLEL_COMM=" << index; 00171 newReadopts = readOpts + extraOpt.str(); 00172 00173 result = mbImpl->create_meshset( MESHSET_SET, roots[i] );MB_CHK_ERR( result ); 00174 00175 result = mbImpl->load_file( meshFiles[i].c_str(), &roots[i], newReadopts.c_str() );MB_CHK_ERR( result ); 00176 // result = rps[i]->load_file(meshFiles[i].c_str(), &roots[i], 00177 // FileOptions(readOpts.c_str()));MB_CHK_ERR(result); 00178 } 00179 00180 result = report_iface_ents( mbImpl, pcs, true );MB_CHK_ERR( result ); 00181 00182 double instant_time = 0.0, pointloc_time = 0.0, interp_time = 0.0, gnorm_time = 0.0, ssnorm_time = 0.0; 00183 // Test interpolation and global normalization and subset normalization 00184 00185 result = test_interpolation( mbImpl, method, interpTag, gNormTag, ssNormTag, ssTagNames, ssTagValues, roots, pcs, 00186 instant_time, pointloc_time, interp_time, gnorm_time, ssnorm_time, toler );MB_CHK_ERR( result ); 00187 00188 reduceMax( instant_time ); 00189 reduceMax( pointloc_time ); 00190 reduceMax( interp_time ); 00191 00192 if( 0 == rank ) 00193 printf( "\nMax time : %g %g %g (inst loc interp -- %d procs)\n", instant_time, pointloc_time, interp_time, 00194 nprocs ); 00195 00196 // Output mesh 00197 if( !outFile.empty() ) 00198 { 00199 Range partSets; 00200 // Only save the target mesh 00201 partSets.insert( (EntityHandle)roots[1] ); 00202 std::string newwriteOpts; 00203 std::ostringstream extraOpt; 00204 if( nprocs > 1 ) extraOpt << ";PARALLEL_COMM=" << 1; 00205 newwriteOpts = writeOpts + extraOpt.str(); 00206 result = mbImpl->write_file( outFile.c_str(), NULL, newwriteOpts.c_str(), partSets );MB_CHK_ERR( result ); 00207 if( 0 == rank ) 00208 { 00209 std::cout << "Wrote " << outFile << std::endl; 00210 std::cout << "mbcoupler_test complete." << std::endl; 00211 } 00212 } 00213 00214 free( roots ); 00215 00216 for( unsigned int i = 0; i < meshFiles.size(); i++ ) 00217 delete pcs[i]; 00218 00219 delete mbImpl; 00220 00221 ierr = MPI_Finalize(); 00222 assert( MPI_SUCCESS == ierr ); 00223 return 0; 00224 } 00225 00226 ErrorCode report_iface_ents( Interface* mbImpl, std::vector< ParallelComm* >& pcs, const bool print_results ) 00227 { 00228 Range iface_ents[6]; 00229 ErrorCode result = MB_SUCCESS, tmp_result; 00230 00231 // Now figure out which vertices are shared 00232 for( unsigned int p = 0; p < pcs.size(); p++ ) 00233 { 00234 for( int i = 0; i < 4; i++ ) 00235 { 00236 tmp_result = pcs[p]->get_iface_entities( -1, i, iface_ents[i] ); 00237 00238 if( MB_SUCCESS != tmp_result ) 00239 { 00240 std::cerr << "get_iface_entities returned error on proc " << pcs[p]->proc_config().proc_rank() 00241 << "; message: " << std::endl; 00242 std::string last_error; 00243 result = mbImpl->get_last_error( last_error ); 00244 if( last_error.empty() ) 00245 std::cerr << "(none)" << std::endl; 00246 else 00247 std::cerr << last_error << std::endl; 00248 result = tmp_result; 00249 } 00250 if( 0 != i ) iface_ents[4].merge( iface_ents[i] ); 00251 } 00252 } 00253 00254 // Report # iface entities 00255 result = mbImpl->get_adjacencies( iface_ents[4], 0, false, iface_ents[5], Interface::UNION );MB_CHK_ERR( result ); 00256 00257 int rank; 00258 MPI_Comm_rank( MPI_COMM_WORLD, &rank ); 00259 00260 if( print_results || iface_ents[0].size() != iface_ents[5].size() ) 00261 { 00262 std::cerr << "Proc " << rank << " iface entities: " << std::endl; 00263 for( int i = 0; i < 4; i++ ) 00264 std::cerr << " " << iface_ents[i].size() << " " << i << "d iface entities." << std::endl; 00265 std::cerr << " (" << iface_ents[5].size() << " verts adj to other iface ents)" << std::endl; 00266 } 00267 00268 return result; 00269 } 00270 00271 // Check first character for a '-'. 00272 // Return true if one is found. False otherwise. 00273 bool check_for_flag( const char* str ) 00274 { 00275 if( '-' == str[0] ) 00276 return true; 00277 else 00278 return false; 00279 } 00280 00281 // get_file_options() function with added possibilities for mbcoupler_test. 00282 ErrorCode get_file_options( int argc, 00283 char** argv, 00284 int nprocs, 00285 int rank, 00286 std::vector< std::string >& meshFiles, 00287 Coupler::Method& method, 00288 std::string& interpTag, 00289 std::string& gNormTag, 00290 std::string& ssNormTag, 00291 std::vector< const char* >& ssTagNames, 00292 std::vector< const char* >& ssTagValues, 00293 std::string& readOpts, 00294 std::string& outFile, 00295 std::string& writeOpts, 00296 std::string& dbgFile, 00297 bool& help, 00298 double& epsilon ) 00299 { 00300 // Initialize some of the outputs to null values indicating not present 00301 // in the argument list. 00302 gNormTag = ""; 00303 ssNormTag = ""; 00304 readOpts = ( nprocs > 1 ? "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION;PARTITION_DISTRIBUTE;" 00305 "PARALLEL_RESOLVE_SHARED_ENTS;PARALLEL_GHOSTS=3.0.1;CPUTIME" 00306 : "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION;PARTITION_DISTRIBUTE;" 00307 "PARALLEL_RESOLVE_SHARED_ENTS;CPUTIME" ); 00308 outFile = ""; 00309 writeOpts = ( nprocs > 1 ? "PARALLEL=WRITE_PART;CPUTIME" : "" ); 00310 dbgFile = ""; 00311 std::string defaultDbgFile = argv[0]; // The executable name will be the default debug output file. 00312 00313 // These will indicate if we've gotten our required parameters at the end of parsing. 00314 bool haveMeshes = false; 00315 bool haveInterpTag = false; 00316 00317 // Loop over the values in argv pulling out an parsing each one 00318 int npos = 1; 00319 00320 if( argc > 1 && argv[1] == std::string( "-h" ) ) 00321 { 00322 help = true; 00323 return MB_SUCCESS; 00324 } 00325 00326 while( npos < argc ) 00327 { 00328 if( argv[npos] == std::string( "-meshes" ) ) 00329 { 00330 // Parse out the mesh filenames 00331 npos++; 00332 int numFiles = 2; 00333 meshFiles.resize( numFiles ); 00334 for( int i = 0; i < numFiles; i++ ) 00335 { 00336 if( ( npos < argc ) && ( !check_for_flag( argv[npos] ) ) ) 00337 meshFiles[i] = argv[npos++]; 00338 else 00339 { 00340 std::cerr << " ERROR - missing correct number of mesh filenames" << std::endl; 00341 return MB_FAILURE; 00342 } 00343 } 00344 00345 haveMeshes = true; 00346 } 00347 else if( argv[npos] == std::string( "-itag" ) ) 00348 { 00349 // Parse out the interpolation tag 00350 npos++; 00351 if( ( npos < argc ) && ( !check_for_flag( argv[npos] ) ) ) 00352 interpTag = argv[npos++]; 00353 else 00354 { 00355 std::cerr << " ERROR - missing <interp_tag>" << std::endl; 00356 return MB_FAILURE; 00357 } 00358 00359 haveInterpTag = true; 00360 } 00361 else if( argv[npos] == std::string( "-meth" ) ) 00362 { 00363 // Parse out the interpolation tag 00364 npos++; 00365 if( argv[npos][0] == '0' ) 00366 method = Coupler::CONSTANT; 00367 else if( argv[npos][0] == '1' ) 00368 method = Coupler::LINEAR_FE; 00369 else if( argv[npos][0] == '2' ) 00370 method = Coupler::QUADRATIC_FE; 00371 else if( argv[npos][0] == '3' ) 00372 method = Coupler::SPECTRAL; 00373 else if( argv[npos][0] == '4' ) 00374 method = Coupler::SPHERICAL; 00375 else 00376 { 00377 std::cerr << " ERROR - unrecognized method number " << method << std::endl; 00378 return MB_FAILURE; 00379 } 00380 npos++; 00381 } 00382 else if( argv[npos] == std::string( "-eps" ) ) 00383 { 00384 // Parse out the tolerance 00385 npos++; 00386 if( ( npos < argc ) && ( !check_for_flag( argv[npos] ) ) ) 00387 epsilon = atof( argv[npos++] ); 00388 else 00389 { 00390 std::cerr << " ERROR - missing <epsilon>" << std::endl; 00391 return MB_FAILURE; 00392 } 00393 } 00394 else if( argv[npos] == std::string( "-gnorm" ) ) 00395 { 00396 // Parse out the global normalization tag 00397 npos++; 00398 if( ( npos < argc ) && ( !check_for_flag( argv[npos] ) ) ) 00399 gNormTag = argv[npos++]; 00400 else 00401 { 00402 std::cerr << " ERROR - missing <gnorm_tag>" << std::endl; 00403 return MB_FAILURE; 00404 } 00405 } 00406 else if( argv[npos] == std::string( "-ssnorm" ) ) 00407 { 00408 // Parse out the subset normalization tag and selection criteria 00409 npos++; 00410 if( ( npos < argc ) && ( !check_for_flag( argv[npos] ) ) ) 00411 ssNormTag = argv[npos++]; 00412 else 00413 { 00414 std::cerr << " ERROR - missing <ssnorm_tag>" << std::endl; 00415 return MB_FAILURE; 00416 } 00417 00418 if( ( npos < argc ) && ( !check_for_flag( argv[npos] ) ) ) 00419 { 00420 char* opts = argv[npos++]; 00421 char sep1[1] = { ';' }; 00422 char sep2[1] = { '=' }; 00423 bool end_vals_seen = false; 00424 std::vector< char* > tmpTagOpts; 00425 00426 // First get the options 00427 for( char* i = strtok( opts, sep1 ); i; i = strtok( 0, sep1 ) ) 00428 tmpTagOpts.push_back( i ); 00429 00430 // Parse out the name and val or just name. 00431 for( unsigned int j = 0; j < tmpTagOpts.size(); j++ ) 00432 { 00433 char* e = strtok( tmpTagOpts[j], sep2 ); 00434 ssTagNames.push_back( e ); 00435 e = strtok( 0, sep2 ); 00436 if( e != NULL ) 00437 { 00438 // We have a value 00439 if( end_vals_seen ) 00440 { 00441 // ERROR we should not have a value after none are seen 00442 std::cerr << " ERROR - new value seen after end of values in " 00443 "<ssnorm_selection>" 00444 << std::endl; 00445 return MB_FAILURE; 00446 } 00447 // Otherwise get the value string from e and convert it to an int 00448 int* valp = new int; 00449 *valp = atoi( e ); 00450 ssTagValues.push_back( (const char*)valp ); 00451 } 00452 else 00453 { 00454 // Otherwise there is no '=' so push a null on the list 00455 end_vals_seen = true; 00456 ssTagValues.push_back( (const char*)0 ); 00457 } 00458 } 00459 } 00460 else 00461 { 00462 std::cerr << " ERROR - missing <ssnorm_selection>" << std::endl; 00463 return MB_FAILURE; 00464 } 00465 } 00466 else if( argv[npos] == std::string( "-ropts" ) ) 00467 { 00468 // Parse out the mesh file read options 00469 npos++; 00470 if( ( npos < argc ) && ( !check_for_flag( argv[npos] ) ) ) 00471 readOpts = argv[npos++]; 00472 else 00473 { 00474 std::cerr << " ERROR - missing <roptions>" << std::endl; 00475 return MB_FAILURE; 00476 } 00477 } 00478 else if( argv[npos] == std::string( "-outfile" ) ) 00479 { 00480 // Parse out the output file name 00481 npos++; 00482 if( ( npos < argc ) && ( !check_for_flag( argv[npos] ) ) ) 00483 outFile = argv[npos++]; 00484 else 00485 { 00486 std::cerr << " ERROR - missing <out_file>" << std::endl; 00487 return MB_FAILURE; 00488 } 00489 } 00490 else if( argv[npos] == std::string( "-wopts" ) ) 00491 { 00492 // Parse out the output file write options 00493 npos++; 00494 if( ( npos < argc ) && ( !check_for_flag( argv[npos] ) ) ) 00495 writeOpts = argv[npos++]; 00496 else 00497 { 00498 std::cerr << " ERROR - missing <woptions>" << std::endl; 00499 return MB_FAILURE; 00500 } 00501 } 00502 else if( argv[npos] == std::string( "-dbgout" ) ) 00503 { 00504 // Parse out the debug output file name. 00505 // If no name then use the default. 00506 npos++; 00507 if( ( npos < argc ) && ( !check_for_flag( argv[npos] ) ) ) 00508 dbgFile = argv[npos++]; 00509 else 00510 dbgFile = defaultDbgFile; 00511 } 00512 else 00513 { 00514 // Unrecognized parameter. Skip it and move along. 00515 std::cerr << " ERROR - Unrecognized parameter:" << argv[npos] << std::endl; 00516 std::cerr << " Skipping..." << std::endl; 00517 npos++; 00518 } 00519 } 00520 00521 if( !haveMeshes ) 00522 { 00523 meshFiles.resize( 2 ); 00524 meshFiles[0] = std::string( TestDir + "unittest/64bricks_1khex.h5m" ); 00525 meshFiles[1] = std::string( TestDir + "unittest/64bricks_12ktet.h5m" ); 00526 if( 0 == rank ) 00527 std::cout << "Mesh files not entered; using default files " << meshFiles[0] << " and " << meshFiles[1] 00528 << std::endl; 00529 } 00530 00531 if( !haveInterpTag ) 00532 { 00533 interpTag = "vertex_field"; 00534 std::cout << "Interpolation field name not given, using default of " << interpTag << std::endl; 00535 } 00536 00537 #ifdef MOAB_HAVE_HDF5 00538 if( 1 == argc ) 00539 { 00540 std::stringstream dfname; 00541 dfname << "dum" << nprocs << ".h5m"; 00542 outFile = dfname.str(); 00543 if( 0 == rank ) std::cout << "No arguments given; using output file " << outFile << std::endl; 00544 } 00545 #endif 00546 00547 return MB_SUCCESS; 00548 } 00549 00550 // End get_file_options() 00551 00552 ErrorCode test_interpolation( Interface* mbImpl, 00553 Coupler::Method method, 00554 std::string& interpTag, 00555 std::string& gNormTag, 00556 std::string& ssNormTag, 00557 std::vector< const char* >& ssTagNames, 00558 std::vector< const char* >& ssTagValues, 00559 EntityHandle* roots, 00560 std::vector< ParallelComm* >& pcs, 00561 double& instant_time, 00562 double& pointloc_time, 00563 double& interp_time, 00564 double& gnorm_time, 00565 double& ssnorm_time, 00566 double& toler ) 00567 { 00568 assert( method >= Coupler::CONSTANT && method <= Coupler::SPHERICAL ); 00569 00570 // Source is 1st mesh, target is 2nd 00571 Range src_elems, targ_elems, targ_verts; 00572 ErrorCode result = pcs[0]->get_part_entities( src_elems, 3 );MB_CHK_ERR( result ); 00573 00574 double start_time = MPI_Wtime(); 00575 00576 // Instantiate a coupler, which does not initialize the tree yet 00577 Coupler mbc( mbImpl, pcs[0], src_elems, 0, false ); // do not initialize tree yet 00578 if( Coupler::SPHERICAL == method ) mbc.set_spherical(); 00579 mbc.initialize_tree(); // it is expensive, but do something different for spherical 00580 00581 // Initialize spectral elements, if they exist 00582 bool specSou = false, specTar = false; 00583 result = mbc.initialize_spectral_elements( roots[0], roots[1], specSou, specTar ); 00584 00585 instant_time = MPI_Wtime(); 00586 00587 // Get points from the target mesh to interpolate 00588 // We have to treat differently the case when the target is a spectral mesh 00589 // In that case, the points of interest are the GL points, not the vertex nodes 00590 std::vector< double > vpos; // This will have the positions we are interested in 00591 int numPointsOfInterest = 0; 00592 if( !specTar ) 00593 { // Usual case 00594 Range tmp_verts; 00595 00596 // First get all vertices adj to partition entities in target mesh 00597 result = pcs[1]->get_part_entities( targ_elems, 3 );MB_CHK_ERR( result ); 00598 if( Coupler::SPHERICAL == method ) result = pcs[1]->get_part_entities( targ_elems, 2 );MB_CHK_ERR( result ); // get the polygons/quads on a sphere. 00599 if( Coupler::CONSTANT == method ) 00600 targ_verts = targ_elems; 00601 else 00602 result = mbImpl->get_adjacencies( targ_elems, 0, false, targ_verts, Interface::UNION );MB_CHK_ERR( result ); 00603 00604 // Then get non-owned verts and subtract 00605 result = pcs[1]->get_pstatus_entities( 0, PSTATUS_NOT_OWNED, tmp_verts );MB_CHK_ERR( result ); 00606 targ_verts = subtract( targ_verts, tmp_verts ); 00607 // get position of these entities; these are the target points 00608 numPointsOfInterest = (int)targ_verts.size(); 00609 vpos.resize( 3 * targ_verts.size() ); 00610 result = mbImpl->get_coords( targ_verts, &vpos[0] );MB_CHK_ERR( result ); 00611 // Locate those points in the source mesh 00612 std::cout << "rank " << pcs[0]->proc_config().proc_rank() << " points of interest: " << numPointsOfInterest 00613 << "\n"; 00614 result = mbc.locate_points( &vpos[0], numPointsOfInterest, 0, toler );MB_CHK_ERR( result ); 00615 } 00616 else 00617 { 00618 // In this case, the target mesh is spectral, we want values 00619 // interpolated on the GL positions; for each element, get the GL points, and construct 00620 // CartVect!!! 00621 result = pcs[1]->get_part_entities( targ_elems, 3 );MB_CHK_ERR( result ); 00622 result = mbc.get_gl_points_on_elements( targ_elems, vpos, numPointsOfInterest );MB_CHK_ERR( result ); 00623 std::cout << "rank " << pcs[0]->proc_config().proc_rank() << " points of interest: " << numPointsOfInterest 00624 << "\n"; 00625 } 00626 00627 pointloc_time = MPI_Wtime(); 00628 00629 // Now interpolate tag onto target points 00630 std::vector< double > field( numPointsOfInterest ); 00631 00632 result = mbc.interpolate( method, interpTag, &field[0] );MB_CHK_ERR( result ); 00633 00634 interp_time = MPI_Wtime(); 00635 00636 // Do global normalization if specified 00637 if( !gNormTag.empty() ) 00638 { 00639 // Normalize the source mesh 00640 result = mbc.normalize_mesh( roots[0], gNormTag.c_str(), Coupler::VOLUME, 4 );MB_CHK_ERR( result ); 00641 00642 // Normalize the target mesh 00643 result = mbc.normalize_mesh( roots[1], gNormTag.c_str(), Coupler::VOLUME, 4 );MB_CHK_ERR( result ); 00644 } 00645 00646 gnorm_time = MPI_Wtime(); 00647 00648 // Do subset normalization if specified 00649 00650 if( !ssNormTag.empty() ) 00651 { 00652 00653 result = mbc.normalize_subset( roots[0], ssNormTag.c_str(), &ssTagNames[0], ssTagNames.size(), &ssTagValues[0], 00654 Coupler::VOLUME, 4 );MB_CHK_ERR( result ); 00655 00656 result = mbc.normalize_subset( roots[1], ssNormTag.c_str(), &ssTagNames[0], ssTagNames.size(), &ssTagValues[0], 00657 Coupler::VOLUME, 4 );MB_CHK_ERR( result ); 00658 } 00659 00660 ssnorm_time = MPI_Wtime(); 00661 00662 ssnorm_time -= gnorm_time; 00663 gnorm_time -= interp_time; 00664 interp_time -= pointloc_time; 00665 pointloc_time -= instant_time; 00666 instant_time -= start_time; 00667 00668 // Set field values as tag on target vertices 00669 if( specSou ) 00670 { 00671 // Create a new tag for the values on the target 00672 Tag tag; 00673 std::string newtag = interpTag + "_TAR"; 00674 result = mbImpl->tag_get_handle( newtag.c_str(), 1, MB_TYPE_DOUBLE, tag, MB_TAG_CREAT | MB_TAG_DENSE );MB_CHK_ERR( result ); 00675 result = mbImpl->tag_set_data( tag, targ_verts, &field[0] );MB_CHK_ERR( result ); 00676 } 00677 else 00678 { 00679 if( !specTar ) 00680 { 00681 // Use original tag 00682 Tag tag; 00683 result = mbImpl->tag_get_handle( interpTag.c_str(), 1, MB_TYPE_DOUBLE, tag );MB_CHK_ERR( result ); 00684 result = mbImpl->tag_set_data( tag, targ_verts, &field[0] );MB_CHK_ERR( result ); 00685 } 00686 else 00687 { 00688 // We have the field values computed at each GL points, on each element 00689 // in the target mesh 00690 // We need to create a new tag, on elements, of size _ntot, to hold 00691 // all those values. 00692 // So it turns out we need ntot. Maybe we can compute it from the 00693 // number of values computed, divided by number of elements 00694 int ntot = numPointsOfInterest / targ_elems.size(); 00695 Tag tag; 00696 std::string newtag = interpTag + "_TAR"; 00697 result = mbImpl->tag_get_handle( newtag.c_str(), ntot, MB_TYPE_DOUBLE, tag, MB_TAG_CREAT | MB_TAG_DENSE );MB_CHK_ERR( result ); 00698 result = mbImpl->tag_set_data( tag, targ_elems, &field[0] );MB_CHK_ERR( result ); 00699 } 00700 } 00701 00702 // Done 00703 return MB_SUCCESS; 00704 } 00705 00706 #else 00707 00708 int main( int /*argc*/, char** /*argv*/ ) 00709 { 00710 print_usage(); 00711 return 0; 00712 } 00713 00714 #endif
