MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 #include "moab/Core.hpp" 00002 #include "moab/SpatialLocator.hpp" 00003 #include "moab/Tree.hpp" 00004 #include "moab/HomXform.hpp" 00005 #include "moab/ScdInterface.hpp" 00006 #include "moab/CartVect.hpp" 00007 #include "moab/AdaptiveKDTree.hpp" 00008 #include "moab/BVHTree.hpp" 00009 #include "moab/ProgOptions.hpp" 00010 #include "moab/CpuTimer.hpp" 00011 00012 #ifdef MOAB_HAVE_MPI 00013 #include "moab_mpi.h" 00014 #endif 00015 00016 #include <cstdlib> 00017 #include <sstream> 00018 00019 using namespace moab; 00020 00021 ErrorCode test_locator( SpatialLocator& sl, int npoints, double& cpu_time, double& percent_outside ); 00022 ErrorCode create_hex_mesh( Interface& mb, Range& elems, int n, int dim ); 00023 00024 int main( int argc, char** argv ) 00025 { 00026 #ifdef MOAB_HAVE_MPI 00027 int fail = MPI_Init( &argc, &argv ); 00028 if( fail ) return fail; 00029 #else 00030 // silence the warning of parameters not used, in serial; there should be a smarter way :( 00031 argv[0] = argv[argc - argc]; 00032 #endif 00033 00034 int npoints = 100, dim = 3; 00035 int dints = 1, dleafs = 1, ddeps = 1, csints = 0; 00036 00037 ProgOptions po; 00038 po.addOpt< int >( "candidateplaneset,c", 00039 "Candidate plane set (0=SUBDIVISION,1=SUBDIV_SNAP,2=VERTEX_MEDIAN,3=VERTEX_SAMPLE", &csints ); 00040 po.addOpt< int >( "ints,i", "Number of doublings of intervals on each side of scd mesh", &dints ); 00041 po.addOpt< int >( "leaf,l", "Number of doublings of maximum number of elements per leaf", &dleafs ); 00042 po.addOpt< int >( "max_depth,m", "Number of 5-intervals on maximum depth of tree", &ddeps ); 00043 po.addOpt< int >( "npoints,n", "Number of query points", &npoints ); 00044 po.addOpt< int >( "dim,d", "Dimension of the mesh", &dim ); 00045 // po.addOpt<void>( "print,p", "Print tree details", &print_tree); 00046 po.parseCommandLine( argc, argv ); 00047 00048 std::vector< int > ints, deps, leafs; 00049 ints.push_back( 10 ); 00050 for( int i = 1; i < dints; i++ ) 00051 ints.push_back( 2 * ints[i - 1] ); 00052 deps.push_back( 30 ); 00053 for( int i = 1; i < ddeps; i++ ) 00054 deps.push_back( deps[i - 1] - 5 ); 00055 leafs.push_back( 6 ); 00056 for( int i = 1; i < dleafs; i++ ) 00057 leafs.push_back( 2 * leafs[i - 1] ); 00058 00059 ErrorCode rval = MB_SUCCESS; 00060 std::cout << "Tree_type" 00061 << " " 00062 << "Elems_per_leaf" 00063 << " " 00064 << "Tree_depth" 00065 << " " 00066 << "Ints_per_side" 00067 << " " 00068 << "N_elements" 00069 << " " 00070 << "search_time" 00071 << " " 00072 << "perc_outside" 00073 << " " 00074 << "initTime" 00075 << " " 00076 << "nodesVisited" 00077 << " " 00078 << "leavesVisited" 00079 << " " 00080 << "numTraversals" 00081 << " " 00082 << "leafObjectTests" << std::endl; 00083 00084 // outermost iteration: # elements 00085 for( std::vector< int >::iterator int_it = ints.begin(); int_it != ints.end(); ++int_it ) 00086 { 00087 Core mb; 00088 Range elems; 00089 rval = create_hex_mesh( mb, elems, *int_it, dim ); 00090 if( MB_SUCCESS != rval ) return rval; 00091 00092 // iteration: tree depth 00093 for( std::vector< int >::iterator dep_it = deps.begin(); dep_it != deps.end(); ++dep_it ) 00094 { 00095 00096 // iteration: tree max elems/leaf 00097 for( std::vector< int >::iterator leafs_it = leafs.begin(); leafs_it != leafs.end(); ++leafs_it ) 00098 { 00099 00100 // iteration: tree type 00101 for( int tree_tp = 0; tree_tp < 2; tree_tp++ ) 00102 { 00103 // create tree 00104 Tree* tree; 00105 if( 0 == tree_tp ) 00106 tree = new BVHTree( &mb ); 00107 else 00108 tree = new AdaptiveKDTree( &mb ); 00109 00110 std::ostringstream opts; 00111 opts << "MAX_DEPTH=" << *dep_it << ";MAX_PER_LEAF=" << *leafs_it; 00112 if( csints ) 00113 { 00114 if( opts.str().length() > 0 ) opts << ";"; 00115 opts << "PLANE_SET=" << csints; 00116 } 00117 FileOptions fo( opts.str().c_str() ); 00118 rval = tree->parse_options( fo ); 00119 if( MB_SUCCESS != rval ) return rval; 00120 SpatialLocator sl( &mb, elems, tree ); 00121 00122 // call evaluation 00123 double cpu_time, perc_outside; 00124 rval = test_locator( sl, npoints, cpu_time, perc_outside ); 00125 if( MB_SUCCESS != rval ) return rval; 00126 00127 std::cout << ( tree_tp == 0 ? "BVH" : "KD" ) << " " << *leafs_it << " " << *dep_it << " " << *int_it 00128 << " " << ( *int_it ) * ( *int_it ) * ( *int_it ) << " " << cpu_time << " " 00129 << perc_outside << " "; 00130 00131 tree->tree_stats().output_all_stats(); 00132 00133 } // tree_tp 00134 00135 } // max elems/leaf 00136 00137 } // max depth 00138 00139 } // # elements 00140 00141 #ifdef MOAB_HAVE_MPI 00142 fail = MPI_Finalize(); 00143 if( fail ) return fail; 00144 #endif 00145 00146 return 0; 00147 } 00148 00149 ErrorCode test_locator( SpatialLocator& sl, int npoints, double& cpu_time, double& percent_outside ) 00150 { 00151 BoundBox box = sl.local_box(); 00152 CartVect box_del = box.bMax - box.bMin; 00153 00154 std::vector< CartVect > test_pts( npoints ), test_res( npoints ); 00155 std::vector< EntityHandle > ents( npoints ); 00156 int* is_in = new int[npoints]; 00157 00158 double denom = 1.0 / (double)RAND_MAX; 00159 for( int i = 0; i < npoints; i++ ) 00160 { 00161 // generate a small number of random point to test 00162 double rx = (double)rand() * denom, ry = (double)rand() * denom, rz = (double)rand() * denom; 00163 test_pts[i] = box.bMin + CartVect( rx * box_del[0], ry * box_del[1], rz * box_del[2] ); 00164 } 00165 00166 CpuTimer ct; 00167 00168 // call spatial locator to locate points 00169 ErrorCode rval = sl.locate_points( test_pts[0].array(), npoints, &ents[0], test_res[0].array(), &is_in[0] ); 00170 if( MB_SUCCESS != rval ) 00171 { 00172 delete[] is_in; 00173 return rval; 00174 } 00175 00176 cpu_time = ct.time_elapsed(); 00177 00178 int num_out = std::count( is_in, is_in + npoints, false ); 00179 percent_outside = ( (double)num_out ) / npoints; 00180 delete[] is_in; 00181 00182 return rval; 00183 } 00184 00185 ErrorCode create_hex_mesh( Interface& mb, Range& elems, int n, int dim ) 00186 { 00187 ScdInterface* scdi; 00188 ErrorCode rval = mb.query_interface( scdi ); 00189 if( MB_SUCCESS != rval ) return rval; 00190 00191 HomCoord high( n - 1, -1, -1 ); 00192 if( dim > 1 ) high[1] = n - 1; 00193 if( dim > 2 ) high[2] = n - 1; 00194 ScdBox* new_box; 00195 rval = scdi->construct_box( HomCoord( 0, 0, 0 ), high, NULL, 0, new_box ); 00196 if( MB_SUCCESS != rval ) return rval; 00197 rval = mb.release_interface( scdi ); 00198 if( MB_SUCCESS != rval ) return rval; 00199 00200 rval = mb.get_entities_by_dimension( 0, dim, elems ); 00201 if( MB_SUCCESS != rval ) return rval; 00202 00203 return rval; 00204 }
